(gnome-boxes:148694): Gtk-WARNING **: 02:36:03.544: GtkFlowBox with a model will ignore sort and filter functions
(gnome-boxes:148694): Gtk-WARNING **: 02:36:03.545: GtkListBox with a model will ignore sort and filter functions
(gnome-boxes:148694): Boxes-WARNING **: 02:36:03.910: libvirt-machine.vala:275: Failed to connection to system libvirt: Unable to open qemu+unix:///system: Failed to connect socket to '/var/run/libvirt/libvirt-sock-ro': No such file or directory
(gnome-boxes:148694): Boxes-WARNING **: 02:36:03.965: libvirt-machine.vala:83: Failed to disable 3D Acceleration
(gnome-boxes:148694): Boxes-WARNING **: 02:36:03.968: libvirt-broker.vala:70: Failed to update domain 'manjaro-gnom-3': Failed to set domain configuration: XML error: Invalid PCI address 0000:04:00.0. slot must be >= 1
(gnome-boxes:148694): Boxes-CRITICAL **: 02:36:04.003: boxes_vm_importer_get_source_media: assertion 'self != NULL' failed
Segmentation fault (core dumped)
This, after the latest Stable updates. I cannot figure out what’s the issue. libvirt is installed…
