Hey there,
just updated my hardware (new mainboard, cpu, ram) recently. Sliding the volume in gnome does not update the sound volume properly. I recognized when sliding that the name of the audio device being altered does not match the name of the audio devices I am using.
Slider being used on not used audio device:
Expected audio devices:
I tried disabling extensions, but this does not affect the behavior.
System Info:
Discard all samples (playback) or generate zero samples (capture)
sysdefault
Default Audio Device
lavrate
Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pipewire
PipeWire Sound Server
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
Default ALSA Output (currently PipeWire Media Server)
usbstream:CARD=HD5001
Microsoft® LifeCam HD-5001
USB Stream Output
sysdefault:CARD=USB
Scarlett 2i2 USB, USB Audio
front:CARD=USB,DEV=0
Front output / input
surround21:CARD=USB,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=USB,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=USB,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=USB,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=USB,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=USB,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=USB,DEV=0
IEC958 (S/PDIF) Digital Audio Output
usbstream:CARD=USB
Scarlett 2i2 USB
USB Stream Output
hdmi:CARD=HDMI,DEV=0
HDA ATI HDMI, C32HG7x
HDMI Audio Output
hdmi:CARD=HDMI,DEV=1
HDA ATI HDMI, LG Ultra HD
HDMI Audio Output
hdmi:CARD=HDMI,DEV=2
HDA ATI HDMI, HDMI 2
HDMI Audio Output
hdmi:CARD=HDMI,DEV=3
HDA ATI HDMI, HDMI 3
HDMI Audio Output
usbstream:CARD=HDMI
HDA ATI HDMI
USB Stream Output
hdmi:CARD=Generic_1,DEV=0
HD-Audio Generic, HDMI 0
HDMI Audio Output
hdmi:CARD=Generic_1,DEV=1
HD-Audio Generic, HDMI 1
HDMI Audio Output
hdmi:CARD=Generic_1,DEV=2
HD-Audio Generic, HDMI 2
HDMI Audio Output
hdmi:CARD=Generic_1,DEV=3
HD-Audio Generic, HDMI 3
HDMI Audio Output
usbstream:CARD=Generic_1
HD-Audio Generic
USB Stream Output
front:CARD=Generic
surround21:CARD=Generic
surround40:CARD=Generic
surround41:CARD=Generic
surround50:CARD=Generic
surround51:CARD=Generic
surround71:CARD=Generic
HD-Audio Generic
USB Stream Output
sysdefault:CARD=M4
MOMENTUM 4, USB Audio
front:CARD=M4,DEV=0
surround21:CARD=M4,DEV=0
surround40:CARD=M4,DEV=0
surround41:CARD=M4,DEV=0
surround50:CARD=M4,DEV=0
surround51:CARD=M4,DEV=0
surround71:CARD=M4,DEV=0
iec958:CARD=M4,DEV=0
usbstream:CARD=M4
MOMENTUM 4
USB Stream Output
sysdefault:CARD=S7
SteelSeries Arctis 7, USB Audio
front:CARD=S7,DEV=0
surround21:CARD=S7,DEV=0
surround40:CARD=S7,DEV=0
surround41:CARD=S7,DEV=0
surround50:CARD=S7,DEV=0
surround51:CARD=S7,DEV=0
surround71:CARD=S7,DEV=0
iec958:CARD=S7,DEV=0
iec958:CARD=S7,DEV=1
SteelSeries Arctis 7, USB Audio #1
usbstream:CARD=S7
USB Stream Output
sysdefault:CARD=Audio
USB Audio, USB Audio
front:CARD=Audio,DEV=0
surround21:CARD=Audio,DEV=0
surround40:CARD=Audio,DEV=0
surround41:CARD=Audio,DEV=0
surround50:CARD=Audio,DEV=0
surround51:CARD=Audio,DEV=0
surround71:CARD=Audio,DEV=0
iec958:CARD=Audio,DEV=0
iec958:CARD=Audio,DEV=1
USB Audio, USB Audio #1
usbstream:CARD=Audio
USB Audio
USB Stream Output
General System:
Kernel: 6.1.71-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64
root=UUID=97edd2bb-94d6-46d3-a872-5fc965ae2865 rw rootflags=subvol=@ quiet
splash apparmor=1 security=apparmor udev.log_priority=3
Desktop: GNOME v: 45.3 tk: GTK v: 3.24.39 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 45.0.1 Distro: Manjaro Linux
base: Arch Linux
Type: Desktop Mobo: ASRock model: B650E Taichi Lite
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.28
date: 07/28/2023
System RAM: total: 64 GiB available: 61.92 GiB used: 6.16 GiB (9.9%)
Device-1: Channel-A DIMM 0 type: no module installed
Device-2: Channel-A DIMM 1 type: N/A size: 32 GiB speed: spec: 4800 MT/s
actual: 6000 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
data: 64 total: 64 manufacturer: N/A part-no: 6400 C32 Series
serial: <filter>
Device-3: Channel-B DIMM 0 type: no module installed
Device-4: Channel-B DIMM 1 type: N/A size: 32 GiB speed: spec: 4800 MT/s
serial: <filter>
Info: model: AMD Ryzen 9 7950X3D bits: 64 type: MT MCP arch: Zen 4 gen: 5
level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
model-id: 0x61 (97) stepping: 2 microcode: 0xA601203
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 16 MiB desc: 16x1024 KiB
L3: 128 MiB desc: 1x32 MiB, 1x96 MiB
Speed (MHz): avg: 3048 high: 4200 min/max: 3000/5759 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2988 2: 3000
3: 3000 4: 3000 5: 2880 6: 3368 7: 3000 8: 3000 9: 2935 10: 2878 11: 2877
12: 2873 13: 3000 14: 2876 15: 2873 16: 3000 17: 4200 18: 3000 19: 3000
20: 3000 21: 3000 22: 3000 23: 3000 24: 2850 25: 3000 26: 3000 27: 3000
28: 3000 29: 4200 30: 3000 31: 2880 32: 2878 bogomips: 268931
Flags: 3dnowprefetch abm adx aes amd_lbr_v2 aperfmperf apic arat avic avx
avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni avx512_vpopcntdq
avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt
gfni ht hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku
pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good
sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3
v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
wbnoinvd wdt x2apic x2avic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spec_rstack_overflow mitigation: safe RET, no microcode
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX] vendor: ASRock
driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm)
built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-1,DP-2,DP-3 off: HDMI-A-1 empty: none bus-ID: 03:00.0
chip-ID: 1002:744c class-ID: 0300
Device-2: AMD Raphael driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none empty: DP-4, DP-5, DP-6, HDMI-A-2 bus-ID: 50:00.0
chip-ID: 1002:164e class-ID: 0300 temp: 49.0 C
Device-3: Microsoft Microsoft LifeCam HD-5001
driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 5-1.1:3 chip-ID: 045e:076e class-ID: 0102
Display: wayland server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3
compositor: gnome-shell driver: X: loaded: nvidia gpu: amdgpu display-ID: 0
Monitor-1: DP-1 model: Samsung C32HG7x serial: <filter> built: 2017
res: 2560x1440 dpi: 93 gamma: 1.2 size: 697x392mm (27.44x15.43")
diag: 800mm (31.5") ratio: 16:9 modes: max: 2560x1440 min: 720x400
Monitor-2: DP-2 model: LG (GoldStar) Ultra HD serial: <filter> built: 2017
res: 3840x2160 dpi: 163 gamma: 1.2 size: 600x340mm (23.62x13.39")
diag: 690mm (27.2") ratio: 16:9 modes: max: 3840x2160 min: 640x480
Monitor-3: DP-3 model: Philips PHL 273V7 serial: <filter> built: 2018
res: 1920x1080 dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23")
diag: 686mm (27") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-4: HDMI-A-1 model: Sony TV 00 serial: <filter> built: 2020
res: 3840x2160 dpi: 80 gamma: 1.2 size: 1218x685mm (47.95x26.97")
diag: 1397mm (55") ratio: 16:9 modes: max: 3840x2160 min: 640x480
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.3.3-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7900 XT (radeonsi
navi31 LLVM 16.0.6 DRM 3.49 6.1.71-1-MANJARO) device-ID: 1002:744c
memory: 19.53 GiB unified: no display-ID: :0.0
API: Vulkan v: 1.3.274 layers: 5 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XT (RADV NAVI31) driver: mesa radv v: 23.3.3-manjaro1.1
device-ID: 1002:744c surfaces: xcb,xlib,wayland device: 1
type: integrated-gpu name: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO)
driver: mesa radv v: 23.3.3-manjaro1.1 device-ID: 1002:164e
Device-1: AMD Navi 31 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab30
class-ID: 0403
Device-2: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 50:00.1
chip-ID: 1002:1640 class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 50:00.6 chip-ID: 1022:15e3
class-ID: 0403
Device-4: Sonova Consumer Hearing MOMENTUM 4
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-3.1:4 chip-ID: 3542:1000 class-ID: 0300
serial: <filter>
Device-5: Generic USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:6
chip-ID: 26ce:0a06 class-ID: 0300
Device-6: Microsoft Microsoft LifeCam HD-5001
Device-7: Focusrite-Novation Focusrite Scarlett 2i2 2nd Gen
driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 5-1.2:4 chip-ID: 1235:8202 class-ID: 0102
Device-8: SteelSeries ApS Arctis 7 driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-1.4:6
chip-ID: 1038:12ad class-ID: 0300
API: ALSA v: k6.1.71-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz vendor: Rivet Networks
driver: iwlwifi v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 link-max:
gen: 2 speed: 5 GT/s bus-ID: 49:00.0 chip-ID: 8086:2725 class-ID: 0280
IF: wlp73s0 state: down mac: <filter>
Device-2: Realtek Killer E3000 2.5GbE vendor: ASRock driver: r8169
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 link-max: gen: 2
speed: 5 GT/s port: a000 bus-ID: 4a:00.0 chip-ID: 10ec:3000 class-ID: 0200
IF: enp74s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-7:5 chip-ID: 8087:0032
class-ID: e001
Local Storage: total: 6.35 TiB used: 1.75 TiB (27.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: TeamGroup
model: T-FORCE TM8FP7002T size: 1.82 TiB block-size: physical: 512 B
fw-rev: EGFM15.2 temp: 50.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung model: SSD 960 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B7QCXE7 temp: 48.9 C
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3000DM008-2DM166
size: 2.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC26 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SSD PLUS 1000GB
size: 931.52 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 00RL scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: SanDisk model: SSD PLUS 480GB
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 04RL scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 760.54 GiB (40.8%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 97edd2bb-94d6-46d3-a872-5fc965ae2865
used: 616 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 0272-20F0
ID-3: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 760.54 GiB (40.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 97edd2bb-94d6-46d3-a872-5fc965ae2865
ID-4: /run/media/thomas/Daten raw-size: 447.13 GiB
size: 447.13 GiB (100.00%) used: 333.75 GiB (74.6%) fs: btrfs dev: /dev/sdc1
maj-min: 8:33 label: Daten uuid: bf9f763f-b123-4e64-afa5-b89812c14ccc
ID-5: /run/media/thomas/Games raw-size: 931.51 GiB
size: 931.51 GiB (100.00%) used: 702.42 GiB (75.4%) fs: btrfs dev: /dev/sdb1
maj-min: 8:17 label: Games uuid: 497ca50b-75ca-4c7a-ba5f-aad8aeda9f74
ID-6: /var/cache raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
ID-7: /var/log raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
ID-1: swap-1 type: file size: 16 GiB used: 0 KiB (0.0%) priority: -2
file: /swap
ID-1: /dev/nvme1n1p1 maj-min: 259:4 size: 100 MiB fs: vfat label: N/A
uuid: 3603-6811
ID-2: /dev/nvme1n1p2 maj-min: 259:5 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme1n1p3 maj-min: 259:6 size: 465.14 GiB fs: ntfs label: N/A
uuid: 848E04628E044F5C
ID-4: /dev/nvme1n1p4 maj-min: 259:7 size: 515 MiB fs: ntfs label: N/A
uuid: 9A7086FF7086E0FD
ID-5: /dev/sda1 maj-min: 8:1 size: 2.73 TiB fs: ntfs label: Daten
uuid: 7B99722B0150EBAA
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Hub-4: 3-3:2 info: Cambridge Silicon Radio ports: 4 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 500mA chip-ID: 0a12:4010
Device-1: 3-3.1:4 info: Sonova Consumer Hearing MOMENTUM 4 type: HID,audio
driver: hid-generic,snd-usb-audio,usbhid interfaces: 5 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 3542:1000
class-ID: 0300 serial: <filter>
Hub-5: 3-4:3 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
chip-ID: 174c:2074 class-ID: 0900
Device-1: 3-7:5 info: Intel AX210 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0032 class-ID: e001
Device-2: 3-8:6 info: Generic USB Audio type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 7 rev: 2.0
Device-3: 3-9:7 info: ROCCAT Kone Pro type: mouse,HID
driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1e7d:2c88 class-ID: 0300
Device-4: 3-11:8 info: Ducky One 3 TKL type: HID,keyboard,mouse
driver: hid-generic,usbhid interfaces: 5 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 3233:8011 class-ID: 0300
serial: <filter>
Hub-6: 4-0:1 info: super-speed hub ports: 5 rev: 3.1
Hub-7: 4-4:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
chip-ID: 174c:3074 class-ID: 0900
Hub-8: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-9: 5-1:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
Device-1: 5-1.1:3 info: Microsoft Microsoft LifeCam HD-5001
type: video,audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0
Device-2: 5-1.2:4 info: Focusrite-Novation Focusrite Scarlett 2i2 2nd Gen
type: audio driver: snd-usb-audio interfaces: 4 rev: 2.0
Device-3: 5-1.3:5 info: Brother Industries DCP-J562DW
type: printer,mass storage driver: usb-storage,usblp interfaces: 3 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 2mA
chip-ID: 04f9:0380 class-ID: 0806 serial: <filter>
Device-4: 5-1.4:6 info: SteelSeries ApS Arctis 7 type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 1.1
Hub-10: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-11: 6-1:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
Hub-12: 7-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-13: 8-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-14: 9-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Device-1: 9-1:2 info: ASRock LED Controller type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 26ce:01a2 class-ID: 0300
serial: <filter>
Hub-15: 10-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
System Temperatures: cpu: 55.5 C mobo: N/A
Fan Speeds (rpm): N/A
GPU: device: amdgpu temp: 49.0 C device: amdgpu temp: 56.0 C mem: 66.0 C
fan: 0 watts: 36.00
Processes: 648 Power: uptime: 14m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 0 hibernate: platform
avail: shutdown,reboot,suspend,test_resume image: 24.76 GiB
daemons: upowerd, power-profiles-daemon, gsd-power Init: systemd v: 255
Packages: 2123 pm: pacman pkgs: 2088 libs: 491 tools: gnome-software,pamac
pm: flatpak pkgs: 35 Compilers: clang: 16.0.6 gcc: 13.2.1 alt: 12 Shell: Zsh
v: 5.9 running-in: gnome-terminal inxi: 3.3.32```
