For a couple of weeks I see Gnome Terminal randomly crash during my work on Manjaro Gnome. I use the terminal quite frequently and there are dozens of tabs open all the time, switch to Firefox and back, … work as usual. Then suddenly the entire terminal application window is gone…
No way I can tell what caused this or how I could reproduce it. I do install the usual Manjaro updates regularly, so I assume some bug has sneaked into my system.
Has anyone else experienced this recently?
What logfile should I look into to figure out what might have caused this?
Hi @mcnesium,
You can check the log file with journactl
. Run the following:
journalctl --priority=3 --since='5m ago'
To view the Error and Warning logs since 5 minutes ago.
The --since
argument can be adjusted according to needs. See
man journalctl
for more information.
Thanks for the reply. By now I found some interesting details:
I use Night Theme Switcher to toggle Matcha light and dark themes. It seems like this disturbes some Gnome apps. Steps to reproduce:
- Switch to light theme
- Start Evolution
- Move evolution out of the view, e.g. alt-tab to Firefox
- Switch to dark theme
- alt-tab to Evolution
Unexpected observation:
- Evolution crashes, window closes
dmesg
output:
[18690.094763] evolution[35763]: segfault at 34400000662 ip 00007f113ff1a026 sp 00007ffca9d40a60 error 4 in libgdk-3.so.0.2404.27[7f113fee6000+7b000]
[18690.094802] Code: 03 00 00 4d 8b 72 50 8b 45 4c 4d 85 f6 0f 84 21 02 00 00 41 8b 16 39 d0 0f 83 b6 03 00 00 48 c1 e0 03 49 8b 56 08 45 8b 6a 58 <48> 8b 3c 02 31 d2 8b 47 08 41 f7 f5 31 d2 89 44 24 08 8b 47 0c 41
[18690.094963] audit: type=1701 audit(1646672434.011:255): auid=1000 uid=1000 gid=1000 ses=4 subj==unconfined pid=35763 comm="evolution" exe="/usr/bin/evolution" sig=11 res=1
While I was trying to reproduce this with Evolution, I saw that the same happened with Gnome Calendar, while Evolution did not crash this time:
[19343.240431] gnome-calendar[1455]: segfault at 21 ip 00007f58ffb1c026 sp 00007ffe07da8370 error 4 in libgdk-3.so.0.2404.27[7f58ffae8000+7b000]
[19343.240472] Code: 03 00 00 4d 8b 72 50 8b 45 4c 4d 85 f6 0f 84 21 02 00 00 41 8b 16 39 d0 0f 83 b6 03 00 00 48 c1 e0 03 49 8b 56 08 45 8b 6a 58 <48> 8b 3c 02 31 d2 8b 47 08 41 f7 f5 31 d2 89 44 24 08 8b 47 0c 41
[19343.240555] audit: type=1701 audit(1646673087.157:272): auid=1000 uid=1000 gid=1000 ses=4 subj==unconfined pid=1455 comm="gnome-calendar" exe="/usr/bin/gnome-calendar" sig=11 res=1
Output of journalctl
in the details:
Mär 07 18:11:28 x270.man7.local systemd-coredump[38328]: Process 1455 (gnome-calendar) of user 1000 dumped core.
Module linux-vdso.so.1 with build-id 6b9d310405fa67cec64cf2141c45e4f33bb3a570
Module libnss_myhostname.so.2 with build-id 4951b5811470eaf99882e4891f149237b82ca605
Module libnss_resolve.so.2 with build-id 514ce3b5a709858e5730fa89b486d66f04304431
Module libnss_mdns4_minimal.so.2 with build-id a6fde528b667185a18aca5be61727fb369423647
Module libnss_mymachines.so.2 with build-id 0822868ed745fc3713fc9645834e142c6e109cdf
Module p11-kit-trust.so with build-id 8b539aa1d5ee1ffc32e4c6f71c132e40e09ffbb7
Module libgmp.so.10 with build-id e58d34ab389d1b649c24195c2d145e3ff2e58290
Module libhogweed.so.6 with build-id 2d70cff7b1841b4d9ca4e8e7726cd4b944c07fdc
Module libnettle.so.8 with build-id 9a878e513c02007598fcf1e2e286c2203f13536e
Module libgnutls.so.30 with build-id 50f3a52ba3db67b822fd5888790238eb548b64aa
Module libgiognutls.so with build-id e426feaba3e89d613558c96f332225483a6dbcd5
Module libgiognomeproxy.so with build-id 4310e8ddef22af3d8cba800e0901bfbafe5f76fd
Module libgioremote-volume-monitor.so with build-id f2f66164d1e8f84b4cec939881fc55e9d8aa5a30
Module im-wayland.so with build-id 89638856a505ec8004bef7e91ced685df0e648ce
Module librsvg-2.so.2 with build-id ee2b5961f905a5f62b70dc6222968aaca76a0d81
Module libpixbufloader-svg.so with build-id d31f1f5a38b6d6ef3a41361bd59a05b82bf8900d
Module module-credentials-goa.so with build-id 0018e19ac73f19c99cd8082b31dd6c71f3c88099
Module libcamelimapx.so with build-id bbc9e1c689ee624096af30247933c4b8c2cdc075
Module libcamelpop3.so with build-id e04dfa9d35b1bb5ae78687006530a16b8ff1eb48
Module libcamelsmtp.so with build-id 4f5e9e148747af50010db1b6cbf6b64251f798cc
Module libcamellocal.so with build-id 6d915e1d5fc1cd6341eb3912c3637c512ce18154
Module libcamelnntp.so with build-id 7fd5590cb16bb434550a64baeb9000178216616a
Module libcamelsendmail.so with build-id cde7faaf048be293bacca6ffb8f771ce51fcc894
Module libgvfscommon.so with build-id 643d4362b74f55b036829781680105545e0e1ad9
Module libgvfsdbus.so with build-id 80d171a1b9e2e4327b393f38166fc31d2925365d
Module libdconfsettings.so with build-id 7a4ba7af122c4d11168004a9ea6def330f02089f
Module libssl.so.1.1 with build-id 1024424ab33a3767da03f4fdb1fc1b02479f160f
Module libssh2.so.1 with build-id a4adfe44cc7ebd295b3b783361acc3dcfcea1d50
Module libnghttp2.so.14 with build-id f2738fead8e6593084b4fb8756f460aa8cf5535a
Module libcurl.so.4 with build-id d4dec3d9f8c789ec28d441f2a3f73d532809e6ef
Module libdebuginfod.so.1 with build-id 484bf6722af582e62aed8e671c75ec9a3fd4725c
Module libudev.so.1 with build-id cf0e9710c7cebd21a13840b2bc2329213cfd0192
Module libelf.so.1 with build-id 4cf96cb4785e1ca233693ae17fa0d62971ee09c2
Module libtss2-sys.so.1 with build-id 1498ac4b48b90c1d3ac0f5f8f4d27d667bfc4771
Module libcrypto.so.1.1 with build-id 4c926b672d97886b123e03a008387aecf0786de4
Module libplds4.so with build-id e915f74a1aff6a20d65b5f03f5ee2e0197153a33
Module libplc4.so with build-id 44dcd42fb72cc8aab586dbf4000293590bb19e67
Module libnssutil3.so with build-id 0d2b2fb3fdde7ea1ed8f4c95493516473435cdba
Module libcap.so.2 with build-id eb6dae97527fc89dbb0d5bb581a15acd02ae9f56
Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
Module libzstd.so.1 with build-id 72f3511cba7db578f6a2647925f35664da6c838b
Module libevdev.so.2 with build-id b62ae69f839f1b6b06ef2c1df19f25ff09b0d824
Module libgbm.so.1 with build-id b1e71b2fbf996e9e3f95978d5fb1c35257fc739d
Module libdrm.so.2 with build-id 00816f0a71c7e4e388c10db6245dbb9c031732a9
Module libgudev-1.0.so.0 with build-id a9f734ea9206d637d5aacfbd86298c91cdc1a33a
Module libX11-xcb.so.1 with build-id 0db4f94d8ae31b8dc9a83f825a9171656f1e532c
Module libgstallocators-1.0.so.0 with build-id fdd65845af43c0cc2f9a6424bd741b455fcad7c4
Module liborc-0.4.so.0 with build-id a95fb07ab70adc17bb91684e07695723aac3a4b8
Module libdw.so.1 with build-id b3bec074a401dcc3869642c270153cfee807d575
Module libunwind.so.8 with build-id e7f3b22127b00d8b14b2560df707cbbeb0134861
Module libwoff2common.so.1.0.2 with build-id 366330fae3eb439543a00a3b2e9a0cf92f3cf36c
Module libGLdispatch.so.0 with build-id 501765b3a78d668860fa54229b18107473aeda4c
Module libgpg-error.so.0 with build-id 82524ee3d1c4c2244d7cfdcc1e6eea5f9855f6c6
Module libblkid.so.1 with build-id 9e4bb910a2e63ba71cae0e3b89c07fdd45033ff2
Module libkeyutils.so.1 with build-id ac405ddd17be10ce538da3211415ee50c8f8df79
Module libkrb5support.so.0 with build-id adf65240a4d2aba772d7a0772b4d015469934113
Module libcom_err.so.2 with build-id 358b783c9b3d12ba8248519ea2e7f3da4c4e0297
Module libk5crypto.so.3 with build-id eb8220b8f36675aac769450be4cb6bb7f97ec38a
Module libkrb5.so.3 with build-id 72d26767c5cb1097db75a5f5bff88860233c902b
Module libbrotlicommon.so.1 with build-id a4ba3f4b4571c8272343b621da812a6e24a202a7
Module libidn2.so.0 with build-id 1ce2b50ad9f9821c2c629b521cf5a3c99593d332
Module libunistring.so.2 with build-id 015ac6d6bcb60b7d8bea31a80d1941b06e8636ab
Module libicudata.so.70 with build-id e1dcc2a88cfaafed882d09c90c668af0eed4efed
Module liblzma.so.5 with build-id 8b615460aa230708c5183f16bede67aa0437d95e
Module libtss2-tctildr.so.0 with build-id d45a42b5bc06ce0bc08516ee688eb690cd8c5c91
Module libtss2-rc.so.0 with build-id 683cdb1ae9b98aca4ccd4080b6f418bdd95d7b59
Module libtss2-mu.so.0 with build-id ddbc7a4374d0d9ccb2132b2d7497074920f6b65c
Module libtss2-esys.so.0 with build-id 964b48ed1a288f436f7b22b1d5d765765238bde4
Module libXdmcp.so.6 with build-id 8ca0792d23c8b8b4c0864297512349292bea5955
Module libXau.so.6 with build-id 1c67764663e07bec24d8951e5fd93f4d165979ff
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libdatrie.so.1 with build-id 6fe3b6ece2c8e7d11869fa051375128d8f808f58
Module libstemmer.so.0 with build-id aa44a40dfb223020ed8e49cd2d28fc3887128463
Module libatspi.so.0 with build-id de251156cf6f2f447c5e2b8721bd913d79995d4f
Module libdbus-1.so.3 with build-id 74f2ab9c60512f3a93c932c3f627564d42e0b11e
Module libtiff.so.5 with build-id e8d89a0fb0847641ddb75c5f03fa89d68155a75d
Module libexpat.so.1 with build-id 63a4ee083a938cbb472c2c4d32e1050474c94382
Module libgraphite2.so.3 with build-id 47761dc11e553f519cde97ed9ee985be12ccdae2
Module libdl.so.2 with build-id bb9bd2657bfba9f60bd34d2050cc63a7eb024bc4
Module libnspr4.so with build-id c5d12234f7975d11a11e67646533657d014d9540
Module libnss3.so with build-id d2548c5d414574f214f87e4fd328d7a8bfc06931
Module libsmime3.so with build-id 78817b6406663629f3586cf4ff6dc4c32faa6785
Module libssl3.so with build-id a66542b0b26361679b5ebc0b5f06c53ad48f373b
Module libsystemd.so.0 with build-id c9e19a3f6e503f05f60867b9240c1d59bf6c605e
Module libseccomp.so.2 with build-id 54179323d84e1b713b7547ba0b3f8310e65eec93
Module libmanette-0.2.so.0 with build-id 6c718d9a8a98d931bd32676fc58b6ff0bb75bb15
Module libwayland-server.so.0 with build-id 645526447334b85a6f4bf5a8b37737b27696365f
Module liblcms2.so.2 with build-id c01e5649a38dbf37768d02dc751b52de0dcbd141
Module libhyphen.so.0 with build-id bf921c6bbb4feaa536e29f1ae72d3a9e79b6f98e
Module libtasn1.so.6 with build-id ee3429ca5e94718aea4fe5249fc859e0cd88e4e9
Module libenchant-2.so.2 with build-id e4a8762d6921a02e21b856c3bbadb0c5dca0b9ad
Module libwebp.so.7 with build-id 0add7a572705244ed810b7e722cce7da0dcfb62c
Module libwebpdemux.so.2 with build-id 7bc15ac239db643015e169a2c6cc822156eb999a
Module libopenjp2.so.7 with build-id 0a329c12468c33c92ecbc3968f4dc9c79cc5db96
Module libjpeg.so.8 with build-id 879ca18a2f58c25d77ba881db3a44a5676ef6c7d
Module libgstfft-1.0.so.0 with build-id 6e5f88ef2c3e23b8a3272f81bdd7e8edda12f5d2
Module libgstgl-1.0.so.0 with build-id 19d7cc9b76e94ceca84fec4959dcbfcbdf5c1f6a
Module libgstvideo-1.0.so.0 with build-id 3b10019c3797943fa10dc8c79d447f6f0876f708
Module libgsttag-1.0.so.0 with build-id 2648f9ba4b31debd4b6d00a567b1af57c8c05c17
Module libgstaudio-1.0.so.0 with build-id b046ef285c14cf85de520eb1c6e3de6c488afb01
Module libgstpbutils-1.0.so.0 with build-id 175062b238b37aa8a055f6a5861a0a4027189042
Module libgstreamer-1.0.so.0 with build-id acdeaf18c4a618e21e3344d3ae2ce61477ec7ed7
Module libgstbase-1.0.so.0 with build-id fff56d5dfb4c6508703c89da2afe5d098de72d4a
Module libgstapp-1.0.so.0 with build-id 3fdbbf29e3d3dbe94cc43b0fe5f168951d087f45
Module libharfbuzz-icu.so.0 with build-id d4af51b0f4178327c6bb3f504dd95f7283b8fb2f
Module libwoff2dec.so.1.0.2 with build-id f305ec18581a18e8c83f5c3f5bcbe188eeb1b34c
Module libGLX.so.0 with build-id 2a08836c6e6126ce9ff4496b6aacaf29ae9b4e7b
Module libOpenGL.so.0 with build-id f09885433fcfb48c54d308f1c8fbe2898b5e9ceb
Module libxslt.so.1 with build-id 333f4419a38bfb5d4bc10f73aa2364847d683b38
Module libjavascriptcoregtk-4.0.so.18 with build-id 70f28e6f71855c957f0de08598750544722d096f
Module libnotify.so.4 with build-id 8fad144d33915b1a1ed751381093ca2bbc650e31
Module libEGL.so.1 with build-id 686c2e4036c01a3a72349ed0dd04f7c434af14ce
Module libWPEBackend-fdo-1.0.so.1 with build-id 51b6a64f4376734859801e1a5d0c0afc4a03fd9a
Module libwpe-1.0.so.1 with build-id a5071b3ce80868bfb98ea919ecc1797ae96345cc
Module libgcrypt.so.20 with build-id db45f5d5e0f7af1e77324fea1885f974619ad268
Module libp11-kit.so.0 with build-id cc372ea3c28c4d3dfc633b4d2e933c8584d2af16
Module libgck-1.so.0 with build-id ca9ebe7526948662d82bc12a84e3e939c8665076
Module ld-linux-x86-64.so.2 with build-id c09c6f50f6bcec73c64a0b4be77eadb8f7202410
Module libgeocode-glib.so.0 with build-id c03785a11f33bdf44117e4ecd62ab55164eb0d59
Module libffi.so.8 with build-id f90d8b734f6de9b25faedb8cbfab7054dafc0a42
Module libresolv.so.2 with build-id 46ffdf3d477a170314060c26927470d7399bc900
Module libmount.so.1 with build-id 765508fe9812e693ac41fd3d0aedd65d7a78b287
Module libgssapi_krb5.so.2 with build-id e6e098ad51ce7bdd3dbe902d7b0f69a90f8a9e08
Module libbrotlidec.so.1 with build-id 45defc036e918e0140a72f1fbce6e7692d38241d
Module libpsl.so.5 with build-id 0229a201aaf5652186c9fdc192ebe52baf19d7f1
Module libsqlite3.so.0 with build-id 132f0de53d66f5245cd1b1c863e1ec81f32ddebe
Module libstdc++.so.6 with build-id 88ad4eff81a00c684abfe0f863e87434123d8943
Module libgdata.so.22 with build-id 022ff7ef1669f2d0cfe63c13a2992fc506a65fd7
Module libjson-glib-1.0.so.0 with build-id 5865be5fcc01b48a0a113e0145ec45529bff89a6
Module libicuuc.so.70 with build-id 2e245c2bf12f95fd8ab79b3a4be99524677cbd70
Module libicui18n.so.70 with build-id 95af755fca990df26753a7d720b8e3ae24270e42
Module libxml2.so.2 with build-id 34aa03d6fadb52a051964f0e50a977efaea9482e
Module libsecret-1.so.0 with build-id 56982ddb5f2ffaaef5c89862f2037331b70d40e0
Module libedbus-private.so with build-id e0f471674a80c68efc691eaa56a19c97cb7ace56
Module libical.so.3 with build-id aa4a324cfcd06615ccd285eef75773f21789601f
Module libpixman-1.so.0 with build-id 341f793dcada3a48a306a793d265a517e3f2e7d6
Module libxcb-shm.so.0 with build-id fb797f299a446f559a95afcc168227482cc800d1
Module libxcb-render.so.0 with build-id a37bdb37744b508be9dd29fd9ccb9bb0170d43e5
Module libxcb.so.1 with build-id 0d1ef11740a5daad2ee331e812a51aa6574af222
Module libXrender.so.1 with build-id 97e0b9ab6ba96ebc86527cc2b3c3078aad8616b3
Module libfreetype.so.6 with build-id 26c5f833068ff72660d1975cbc2074c3eb47fad8
Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
Module libz.so.1 with build-id 0c1459c56513efd5d53eb3868290e9afee6a6a26
Module libthai.so.0 with build-id a7ac5010b4275c49308021200d23690533952702
Module libXinerama.so.1 with build-id dbb6adece34ea2766d3efcd628af8f9757344dd6
Module libXrandr.so.2 with build-id d4e869b5c72541e1de8f96b456248987ea52d51b
Module libXcomposite.so.1 with build-id f1bb5ffb6203ab2907ac044a204ce3902a79f1c1
Module libXdamage.so.1 with build-id a1d867e093c16944b2c0083be98050ef35c9e5c2
Module libXcursor.so.1 with build-id eb6315bcd7526aaf51b0a1307efdc587cea0a152
Module libXext.so.6 with build-id d70f24beb4fad748d6becffdcc13e51be0a2ebfa
Module libwayland-egl.so.1 with build-id 791e39283cdcc5a08cfd091b8cd4c59869a11278
Module libwayland-cursor.so.0 with build-id 79d7e67af210407c2afe92ba8c189c8648a6474c
Module libwayland-client.so.0 with build-id 0a237f2fd096bada4ca381eec5d64474c4078be4
Module libxkbcommon.so.0 with build-id 3a9338b2085f0af41217bc0a90ffcc941938a16e
Module librt.so.1 with build-id 4761858b348db8303e872e515aa8d56c046c921c
Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
Module libtracker-sparql-3.0.so.0 with build-id b0eee5a9b660fed5221ea15139e9608282320503
Module libcloudproviders.so.0 with build-id ed1d9c9e60be4e858ad148484767249be1edf95f
Module libatk-bridge-2.0.so.0 with build-id 1161ebbcc5aa791075dfa026671875e5417287bd
Module libX11.so.6 with build-id 5ba5798d193c0065014b8c6252a0678671c8d478
Module libXi.so.6 with build-id 16603be937a02a7e61b0b0395d064be7efd86f49
Module libepoxy.so.0 with build-id b6357fc6b748c512f90339433d74502b9d0621dc
Module libatk-1.0.so.0 with build-id aacaa40363d304858b654728a893bc212a4ca119
Module libgdk_pixbuf-2.0.so.0 with build-id ca4beb15a30de8d8767f7bca8222038c61b58b36
Module libcairo-gobject.so.2 with build-id abbf5a8a182ea1b8b7d68540df5c2e25c0bdae0c
Module libfribidi.so.0 with build-id 79124bad061c2aab4ec89f25d067363d5b781114
Module libfontconfig.so.1 with build-id 9fdeb38479c4090d673efc2e8cb60176efe65da1
Module libpangoft2-1.0.so.0 with build-id 9b0353693557b4fb68124a9dffac9b07678d86a1
Module libharfbuzz.so.0 with build-id 716df25c59c91f456ae107457e4250f7c32bde1b
Module libgmodule-2.0.so.0 with build-id 5da4523e8d6b5c244a0193e27093d1e61f6ac9e4
Module libpthread.so.0 with build-id 7fa8b52fae071a370ba4ca32bf9490a30aff31c4
Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
Module libcamel-1.2.so.63 with build-id 3010e0799aeac1b820bc67932862f6806828c248
Module libwebkit2gtk-4.0.so.37 with build-id 9cec742c3edf032d71ada97a59d8c7aa3e404f6d
Module libgcr-ui-3.so.1 with build-id 006e66da017675f8ef3c853804bc100d3c1fe0d8
Module libgcr-base-3.so.1 with build-id bab2a7e7ca01d7c569d1665eeefe0c43f15a2287
Module libc.so.6 with build-id 85766e9d8458b16e9c7ce6e07c712c02b8471dbc
Module libgcc_s.so.1 with build-id 5d817452a709ca3a213341555ddcf446ecee37fa
Module libm.so.6 with build-id 596b63a006a4386dcab30912d2b54a7a61827b07
Module libgeoclue-2.so.0 with build-id 86b00112262812a2580fa21e7c253b13d2b9f921
Module libgweather-3.so.16 with build-id 9be1ba30a84edd5babf44c7b748589db8a622b13
Module libgoa-1.0.so.0 with build-id 0b5006e17b5987ec0ace731889532365c8563267
Module libhandy-1.so.0 with build-id fa74e1154b327e4622b580cbc28fb20fd8003211
Module libdazzle-1.0.so.0 with build-id cdfd20a991682373baebe0ef88689899266ec615
Module libgobject-2.0.so.0 with build-id 6d7ff6c8e4e9c12caa92cf25a74d3ecdd9461c36
Module libgio-2.0.so.0 with build-id c4e89ca22afc7f17db176d2063fe379dbc88d99b
Module libsoup-2.4.so.1 with build-id 678dafa54638a6d0ab73f810643f9a23d988db00
Module libedataserver-1.2.so.26 with build-id eff3708b5a9d2f23576b01a24f85765cf9c61395
Module libical-glib.so.3 with build-id ce771069ff93b459a669ed675ac4ad9ff5833ce2
Module libecal-2.0.so.1 with build-id 92701b491e18df193f9058a5e06801f9e782069d
Module libcairo.so.2 with build-id 06820af9cf79c2deb207d9533a61caf04e67a8ad
Module libpango-1.0.so.0 with build-id f7a7e74f7ade4cbcf3840f685d760da19b0dc38c
Module libpangocairo-1.0.so.0 with build-id a47bf17ab99c1840764fca52a2d772800d81d6e1
Module libgdk-3.so.0 with build-id 0d1048ff040bb420bc2b7da992590559226a1beb
Module libgtk-3.so.0 with build-id 237211b929fd493858b4269bbf63f407c24e0fb4
Module libglib-2.0.so.0 with build-id 24e675eddd4654b470e0a892f4a4aec012b04160
Module libedataserverui-1.2.so.3 with build-id 4c7ace6666f62b1ac32a113179cf372502c87ac1
Module gnome-calendar with build-id 850732d6445976c417c3d9642863d8bef92525dd
Stack trace of thread 1455:
#0 0x00007f58ffb1c026 n/a (libgdk-3.so.0 + 0x5e026)
#1 0x00007f58ffb0dedb n/a (libgdk-3.so.0 + 0x4fedb)
#2 0x00007f58ffb10acc n/a (libgdk-3.so.0 + 0x52acc)
#3 0x00007f58ffb23a86 n/a (libgdk-3.so.0 + 0x65a86)
#4 0x00007f58f99e9d4a n/a (libffi.so.8 + 0x6d4a)
#5 0x00007f58f99e9267 n/a (libffi.so.8 + 0x6267)
#6 0x00007f58fa9ad323 n/a (libwayland-client.so.0 + 0xa323)
#7 0x00007f58fa9a95ab n/a (libwayland-client.so.0 + 0x65ab)
#8 0x00007f58fa9aaf4c wl_display_dispatch_queue_pending (libwayland-client.so.0 + 0x7f4c)
#9 0x00007f58ffb1fd59 n/a (libgdk-3.so.0 + 0x61d59)
#10 0x00007f58ffaeeffb gdk_display_get_event (libgdk-3.so.0 + 0x30ffb)
#11 0x00007f58ffb293b8 n/a (libgdk-3.so.0 + 0x6b3b8)
#12 0x00007f59003c3f13 g_main_context_dispatch (libglib-2.0.so.0 + 0x54f13)
#13 0x00007f590041a0d9 n/a (libglib-2.0.so.0 + 0xab0d9)
#14 0x00007f59003c1485 g_main_context_iteration (libglib-2.0.so.0 + 0x52485)
#15 0x00007f58ff5fd6ee g_application_run (libgio-2.0.so.0 + 0xdb6ee)
#16 0x000055e22998c525 main (gnome-calendar + 0x20525)
#17 0x00007f58fefb6310 __libc_start_call_main (libc.so.6 + 0x2d310)
#18 0x00007f58fefb63c1 __libc_start_main@@GLIBC_2.34 (libc.so.6 + 0x2d3c1)
#19 0x000055e22998c60e _start (gnome-calendar + 0x2060e)
Stack trace of thread 1514:
#0 0x00007f58ff08f2af __poll (libc.so.6 + 0x1062af)
#1 0x00007f590041a066 n/a (libglib-2.0.so.0 + 0xab066)
#2 0x00007f59003c1485 g_main_context_iteration (libglib-2.0.so.0 + 0x52485)
#3 0x00007f5900503ebe n/a (libdconfsettings.so + 0x5ebe)
#4 0x00007f59003f3845 n/a (libglib-2.0.so.0 + 0x84845)
#5 0x00007f58ff0165c2 start_thread (libc.so.6 + 0x8d5c2)
#6 0x00007f58ff09b584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 1636:
#2 0x00007f59003c3463 g_main_loop_run (libglib-2.0.so.0 + 0x54463)
#3 0x00007f58ff7f43c3 n/a (libedataserver-1.2.so.26 + 0x673c3)
Stack trace of thread 1504:
#3 0x00007f59003c14d2 n/a (libglib-2.0.so.0 + 0x524d2)
Stack trace of thread 1937:
#3 0x000055e2299bfbc7 n/a (gnome-calendar + 0x53bc7)
Stack trace of thread 1647:
#3 0x00007f58ff8d161b n/a (libecal-2.0.so.1 + 0x1a61b)
Stack trace of thread 1942:
Stack trace of thread 2698:
Stack trace of thread 1940:
Stack trace of thread 2691:
Stack trace of thread 2700:
Stack trace of thread 2689:
Stack trace of thread 2693:
Stack trace of thread 2701:
Stack trace of thread 1506:
#3 0x00007f58ff62a15c n/a (libgio-2.0.so.0 + 0x10815c)
Stack trace of thread 1936:
Stack trace of thread 2703:
What is going on here?
… and I just saw Gnome Terminal crash again just a moment ago without me switching themes!
dmesg:
[24692.530160] gnome-terminal-[34764]: segfault at 400000004 ip 00007f0146871026 sp 00007fffae877260 error 4 in libgdk-3.so.0.2404.27[7f014683d000+7b000]
[24692.530181] Code: 03 00 00 4d 8b 72 50 8b 45 4c 4d 85 f6 0f 84 21 02 00 00 41 8b 16 39 d0 0f 83 b6 03 00 00 48 c1 e0 03 49 8b 56 08 45 8b 6a 58 <48> 8b 3c 02 31 d2 8b 47 08 41 f7 f5 31 d2 89 44 24 08 8b 47 0c 41
[24692.530246] audit: type=1701 audit(1646678436.464:375): auid=1000 uid=1000 gid=1000 ses=4 subj==unconfined pid=34764 comm="gnome-terminal-" exe="/usr/lib/gnome-terminal-server" sig=11 res=1
journalctl:
Mär 07 19:40:36 x270.man7.local systemd-coredump[48822]: Process 34764 (gnome-terminal-) of user 1000 dumped core.
Module libpcre2-8.so.0 with build-id 7ade7d8b44c84833a41fe87f30330ce17458808a
Module libvte-2.91.so.0 with build-id f6eaa1d2ca49727140f7ad69a6e8157dca9a8aaf
Module libuuid.so.1 with build-id cc94de1b28210d2b06109bd76c198c80f518aad6
Module libdconf.so.1 with build-id 4e1bd6ba12d7f2997624fe360181059f73e5c84a
Module gnome-terminal-server with build-id 1ac764e0e51670ba9eff962682b62cdb6a96247b
Stack trace of thread 34764:
#0 0x00007f0146871026 n/a (libgdk-3.so.0 + 0x5e026)
#1 0x00007f0146862edb n/a (libgdk-3.so.0 + 0x4fedb)
#2 0x00007f0146864193 n/a (libgdk-3.so.0 + 0x51193)
#3 0x00007f01468406b0 n/a (libgdk-3.so.0 + 0x2d6b0)
#4 0x00007f0147118f13 g_main_context_dispatch (libglib-2.0.so.0 + 0x54f13)
#5 0x00007f014716f0d9 n/a (libglib-2.0.so.0 + 0xab0d9)
#6 0x00007f0147116485 g_main_context_iteration (libglib-2.0.so.0 + 0x52485)
#7 0x00007f01473376ee g_application_run (libgio-2.0.so.0 + 0xdb6ee)
#8 0x000055b78ef8d6a0 n/a (gnome-terminal-server + 0x156a0)
#9 0x00007f01461ad310 __libc_start_call_main (libc.so.6 + 0x2d310)
#10 0x00007f01461ad3c1 __libc_start_main@@GLIBC_2.34 (libc.so.6 + 0x2d3c1)
#11 0x000055b78ef8d8de n/a (gnome-terminal-server + 0x158de)
Stack trace of thread 34777:
#0 0x00007f01462862af __poll (libc.so.6 + 0x1062af)
#1 0x00007f014716f066 n/a (libglib-2.0.so.0 + 0xab066)
#2 0x00007f0147118463 g_main_loop_run (libglib-2.0.so.0 + 0x54463)
#3 0x00007f014736415c n/a (libgio-2.0.so.0 + 0x10815c)
#4 0x00007f0147148845 n/a (libglib-2.0.so.0 + 0x84845)
#5 0x00007f014620d5c2 start_thread (libc.so.6 + 0x8d5c2)
#6 0x00007f0146292584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 34773:
#2 0x00007f0147116485 g_main_context_iteration (libglib-2.0.so.0 + 0x52485)
#3 0x00007f01471164d2 n/a (libglib-2.0.so.0 + 0x524d2)
Stack trace of thread 34776:
#3 0x00007f014745debe n/a (libdconfsettings.so + 0x5ebe)
Some assertion was triggered in mutter. Check the journal for what message was outputted. That’ll probably give more insight than this stracktrace. Debug symbols would help as well.
