Hi all, I’ve recently switched to Gnome as I heard Wayland currently has (slightly) better support for eGPUs (KDE and Gnome). I was having issues with KDE Plasma on xOrg and tried KDE Plasma’s Wayland implementation which was still problematic (no way of setting primary GPU as far as I could tell) whereas Gnome had this.
With that additional udev rule, I was able to use Gnome with Wayland and my eGPU, however, now the internal display of the laptop (what I’m using as my secondary monitor), is extremely laggy/choppy/sluggish.
Rarely, a bootup would result in a much smoother second display experience. I got the journalctl boot log of that boot instance and compared it to a boot instance where it was laggy and found that problematic boot instance had a lot of the following messages:
i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:3a:00.0) do not share an upstream bridge or whitelisted host bridge
Whereas the boot instance with no problems on the secondary monitor (internal) did not have any of those messages.
I’m also aware of this merge request that’s to fix lots of Mutter’s framerate issues, but I’m not sure if my problem falls within the scope of that solution.
glxgears reports ~60fps for my external (primary) monitor, and ~30fps for my internal (secondary) monitor.
my inxi:
Kernel: 5.14.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=5a221c44-509c-4529-8d41-43ed70a124b9 rw quiet splash apparmor=1
security=apparmor resume=UUID=78565509-fb86-4433-aa87-75fcb00a1811
udev.log_priority=3 intel_iommu=igfx_off
Desktop: GNOME 41.1 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 41.0
Type: Convertible System: LENOVO product: 81C4 v: Lenovo YOGA C930-13IKB
serial: <superuser required> Chassis: type: 31 v: Lenovo YOGA C930-13IKB
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
serial: <superuser required> UEFI: LENOVO v: 8GCN37WW date: 11/23/2020
ID-1: BAT1 charge: 43.6 Wh (98.2%) condition: 44.4/60.0 Wh (74.0%)
volts: 8.5 min: 7.7 model: Simplo BASE-BAT type: Li-poly serial: <filter>
status: Unknown
Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: EA cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 32012
Speed: 856 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 800 2: 800
3: 1062 4: 830 5: 800 6: 800 7: 800 8: 800
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: XFX Pine driver: amdgpu v: kernel bus-ID: 3a:00.0 chip-ID: 1002:67df
class-ID: 0300
Device-3: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-1:2
chip-ID: 5986:2115 class-ID: 0e02
Device-4: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-6.1.2:7 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Display: wayland server: X.org 1.21.1.1 compositor: gnome-shell driver:
loaded: amdgpu note: n/a (using device driver) - try sudo/root display-ID: 0
OpenGL: renderer: AMD Radeon RX 580 Series (POLARIS10 DRM 3.42.0
5.14.18-1-MANJARO LLVM 13.0.0)
v: 4.6 Mesa 21.2.5 direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo driver: snd_soc_skl
v: kernel alternate: snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:9d71
class-ID: 0401
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: XFX Pine driver: snd_hda_intel v: kernel bus-ID: 3a:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.14.18-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel bus-ID: 6b:00.0
chip-ID: 8086:2526 class-ID: 0280
IF: wlp107s0 state: up mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-8:5 chip-ID: 8087:0025 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Local Storage: total: 462.05 GiB used: 15.89 GiB (3.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB256HAHQ-000L2
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 0L1QEXD7 temp: 29.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Kingston model: SA400S37240
size: 223.57 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: SBFK scheme: GPT
ID-1: / raw-size: 217.26 GiB size: 212.85 GiB (97.97%)
used: 11.07 GiB (5.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: partition size: 20.92 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 29.8 C pch: 41.0 C mobo: 27.8 C gpu: amdgpu
temp: 47.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 944
Processes: 321 Uptime: 36m wakeups: 8 Memory: 15.38 GiB
used: 2.88 GiB (18.8%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1182 lib: 327 flatpak: 0 Shell: Zsh v: 5.8
running-in: gnome-terminal inxi: 3.3.09
