I installed manjaro with gnome to use the new workflow and to my surprise the interface is in the old standard, has how to fix this or the manjaro chose not to update?
I thank you for the attention
emke
18 April 2021 21:57
2
Gnome-shell 40 has reached the unstable branch .
Learn about switching branches here .
Also read:
Hi Gnome Fellows,
Manjaro currently ships a mixture of Gnome 3.38 Shell and Gnome 40 Apps, as long as it works together for a while now in Stable and Testing branches. Gnome 40 Shell and other newer packages you may find in our Unstable branch. The following packages we hold back (plus needed extensions):
gnome-control-center
gnome-control-center-x11-scaling
gnome-settings-daemon
gnome-shell
gnome-shell-extensions
gnome-tweaks
gsettings-desktop-schemas
mutter
This is the minimal set of 3.38 pā¦
