I’m trying to install the GIMP plugin called GMIC on my Manjaro installation of the GIMP unstable developer’s edition (2.99.12). The following link gives command line instructions to do so:
Which basically amounts to executing the following:
sudo pacman -S gimp-plugin-gmic
After completing this step, I restarted GIMP but do not see GMIC listed under ‘Filters’ where it should be found. When I check my folders for GIMP under plugins, the folder is still empty.
Does anybody have experiencing installing this plugin? Appreciate the help.
Is not compatible with the gimp-plugin-gmic
from repos, even if you add the path to the plugin folders in gimp developer settings, nor with the gimp-plugin-gmic-git
from AUR that is quite outdated really (and will not compile anyway) …
What you need is this version GitHub - c-koi/gmic-qt: G'MIC-Qt is a versatile front-end to the image processing framework G'MIC. to compile it from source, as according to this post Some News About Your Donations
So, instead of gimp-devel
you could try the gimp-develop-git
that is non conflicting version with another install, use gimp
and gimp-plugin-gmic
from repository, and play with gmic-qt
from source.
