Does anyone knows how to make it work? cause i’ve seen that i’ve already installed it using the program app but it doesn’t appear on my GIMP :S
According to your screenshot, you do not have gimp-plugin-gmic installed. Given the name of that package, one would suspect that installing it would prove beneficial to your situation. ![]()
Jejeje…that’s easy! I thought it would be automatic with the main app
thanks for the help ![]()
That is an interesting point about knowing what else to install that would be useful. For gimp I have these packages installed.
gimp
gimp-help-en # html manual loca: online: https://docs.gimp.org/2.10/en/
gimp-plugin-gmic # gmic
xsane, xsane-gimp # scanning: https://docs.gimp.org/2.10/en/gimp-file-create.html
gutenprint # https://www.gimp.org/docs/gimp-print/print.html
Sometimes it helps to look at the package, pacman -Qi gimp to see what other packages are available.
