Global shortcuts unresponsive after resuming from sleep
Recently I started to experience unresponsive global shortcuts after resuming from sleep.
In particular I use F12 to show/hide yakuake and Meta to show/hide krunner (this one is configured in kwinrc).
After resuming from sleep, if I press one of these buttons the effect is triggered after some time, e.g. 30 seconds. An application like yakuake is responsive, indeed I can open it by clicking on its icon. Sometimes the shortcut is processed after I opened the application with the mouse and so the shortcut hides yakuake.
What should I look for to trying debugging this? (I experience this in two different notebooks).
Hi @simgunz
have you checked KDE Software • KDE Community Forums ? For problems like there it’s usually better to check upstream as it’s most likely not a problem with the manjaro distribution.
Reported the bug to KDE:
https://bugs.kde.org/show_bug.cgi?id=440439
