Global menu does not appear when I open Dolphin or Konsole.
There are several things you can try…
Press Ctrl+M.
Click the button above the red arrow in the screenshot below.
- It may be necessary to switch to another Qt-based application first and then back to Dolphin or Konsole. There is a bug in the global menu widget, and normally it should not affect Qt-based applications ─ it only appears to affect GTK-based applications ─ but it never hurts to try.
When I press Ctrl+M, I can see a menu bar, but it is not on the top panel. The theme I installed doesn’t work on Dolphin neither.
Are you using the standard global menu widget that comes with Plasma or are you using one of the alternative widgets like plasma5-applets-window-appmenu-widget from the AUR?
I have tried the alternatives, and I had the same problem with Konsole ─ I don’t remember whether I also had it in Dolphin, but I do remember that it was also missing the menu in one of the editors. So I went back to using the stock global menu widget, which works.
I am not using any alternative widgets.
Earlier you said… ![]()
Maybe that’s the cause of the problem?
I think the problem is the theme, because the menu worked before I use a theme.
That’s what I was trying to tell you already.
I solved the problem.
