Manjaro runs as guest in latest virtualbox. Settings → Appearance is glitchy (screenshot attached). Any clue why?
$ inxi -Fauxi ✔
Host: manjaro Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
v: 12.1.1 parameters: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64
root=UUID=3598832e-8748-4f88-8a4e-faaaf70d851b rw quiet splash apparmor=1
Desktop: GNOME v: 42.4 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Virtualbox System: innotek GmbH product: VirtualBox v: 1.2
serial: <superuser required> Chassis: Oracle Corporation type: 1
Mobo: Oracle model: VirtualBox v: 1.2 serial: <superuser required>
BIOS: innotek GmbH v: VirtualBox date: 12/01/2006
ID-1: BAT0 charge: 50.0 Wh (100.0%) condition: 50.0/50.0 Wh (100.0%)
volts: 10.0 min: 10.0 model: innotek 1 type: Unknown serial: N/A
status: full
Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MCP
arch: Tiger Lake gen: core 11 built: 2020 process: Intel 10nm family: 6
model-id: 0x8D (141) stepping: 1 microcode: N/A
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 320 KiB
desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 96 MiB
desc: 4x24 MiB
Speed (MHz): avg: 2304 min/max: N/A cores: 1: 2304 2: 2304 3: 2304
4: 2304 bogomips: 18439
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Type: itlb_multihit status: KVM: VMX unsupported
Type: mds mitigation: Clear CPU buffers; SMT Host state unknown
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: VMware SVGA II Adapter driver: vmwgfx v: 2.19.0.0 ports:
active: Virtual-1 empty: Virtual-2, Virtual-3, Virtual-4, Virtual-5,
Virtual-6, Virtual-7, Virtual-8 bus-ID: 00:02.0 chip-ID: 15ad:0405
class-ID: 0300
Display: x11 server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
compositor: gnome-shell driver: X: loaded: vmware unloaded: modesetting
alternate: fbdev,vesa gpu: vmwgfx display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: Virtual-1 mapped: Virtual1 res: 1920x1080 hz: 60 size: N/A
modes: max: 1240x795 min: 640x480
OpenGL: renderer: SVGA3D; build: RELEASE; LLVM; v: 2.1 Mesa 22.1.6
direct render: Yes
Device-1: Intel 82801AA AC97 Audio vendor: Dell driver: snd_intel8x0
v: kernel bus-ID: 00:05.0 chip-ID: 8086:2415 class-ID: 0401
Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Intel 82540EM Gigabit Ethernet driver: e1000 v: kernel port: d020
bus-ID: 00:03.0 chip-ID: 8086:100e class-ID: 0200
IF: enp0s3 state: up speed: 1000 Mbps duplex: full mac: 08:00:27:14:cf:ae
IP v4: 10.0.2.15/24 type: dynamic noprefixroute scope: global
broadcast: 10.0.2.255
IP v6: fe80::5294:2ea8:167e:f5ef/64 type: noprefixroute scope: link
Device-2: Intel 82371AB/EB/MB PIIX4 ACPI type: network bridge
driver: piix4_smbus v: N/A modules: i2c_piix4 port: N/A bus-ID: 00:07.0
chip-ID: 8086:7113 class-ID: 0680
WAN IP: 49.204.133.125
Local Storage: total: 22 GiB used: 9.04 GiB (41.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: VirtualBox model: VBOX HARDDISK
size: 22 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: N/A serial: VBc55e4240-39e573e0 rev: 1.0 scheme: MBR
ID-1: / raw-size: 21.99 GiB size: 21.48 GiB (97.67%) used: 9.04 GiB (42.1%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1
uuid: 3598832e-8748-4f88-8a4e-faaaf70d851b
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
Message: No sensor data found. Is lm-sensors configured?
Processes: 233 Uptime: 12m wakeups: 974 Memory: 7.76 GiB used: 1.53 GiB
(19.7%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: pacman: 1143 lib: 250
flatpak: 0 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.20
