I’ve done as @linux-aarhus suggested in https://forum.manjaro.org/t/glibc-causing-pacman-fail/103065
- Remove the archlinuxcn repo from pacman.conf
- Change to unstable branch
pacman-mirrors -aS unstable -c Global
- Run a full sync
pacman -Syyu
The system still reported:
findmnt: /usr/lib/libc.so.6: version `GLIBC_2.34' not found (required by /usr/lib/libudev.so.1)
and
timeshift: /usr/lib/libc.so.6: version `GLIBC_2.34' not found (required by /usr/lib/libsystemd.so.0)
I didn’t find hooks
dir in /etc/pacman.d/, and I even can’t see if timeshift is running, since ps
is also blocked by glibc failure:
[manjaro /]# ps
ps: /usr/lib/libc.so.6: version `GLIBC_2.34' not found (required by /usr/lib/libsystemd.so.0)
Is there any way I can rescue the system?
BTW: And about what @Nachlese asked: yes, my old system is on /dev/sda1.
The output of lsblk -f
before manjaro-chroot
[manjaro@manjaro ~]$ lsblk -f
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0 squashfs 4.0 0 100% /run/miso/sfs/livefs
loop1 squashfs 4.0 0 100% /run/miso/sfs/mhwdfs
loop2 squashfs 4.0 0 100% /run/miso/sfs/desktopfs
loop3 squashfs 4.0 0 100% /run/miso/sfs/rootfs
sda
└─sda1 ext4 1.0 be4a5fec-3ebc-4436-b702-3b5fd6dad488 21.5G 86% /mnt
/mnt/repchroot
sdb
├─sdb1
└─sdb2 ntfs D 88D2DBD7D2DBC798 142.6G 85% /mnt/data
sdc
├─sdc1 ntfs UUI BA0068AA00686EF7
└─sdc4 iso9660 Joliet Extension MANJARO_XFCE_2122 2022-01-23-13-29-58-00 0 100% /run/miso/bootmnt
The old system is on sda1, sdb is only for data storage, sdc is the live usb.
after manjaro-chroot
[manjaro /]# lsblk -f
lsblk: /usr/lib/libc.so.6: version `GLIBC_2.34' not found (required by /usr/lib/libudev.so.1)
