I installed GITHUB desktop and having some issues
First I found that the system was not working without gnome-keyring even if I have a KDE installation
Then had to run the following command
git config --global http.sslverify false
since there is one of my repos that has self generated SSL cert
Now it is a few days that I ty to simply fetch or push some changes but the app hangs there with an "hang on"message
No log (i havent found at least) with reasonable explanation
Well, if this is out of option then we can try to fix the github desktop i guess,
I think best course of actions would be to try if normal git cli works as it should, if it doesn’t it should output some useful information very likely,
if it does then I won’t be able to help you very likely
The problem was in the .git/config file
For some reason GITHUB didnt add the username/password in that file
It is only using the keyring (in aworng way as far as i can see)
I will try now to remove the gnome-keyring package to test it again
