Github copilot doesn't work after some time in vscode
When I start vscode, Copilot is working fine, but after some time, like 30-40 mins, it stops to work and I need to restart vscode for it to work again. I’m using visual-studio-code-bin. Is there any way to fix this?
This is not a Manjaro issue.
Possibly - github copilot is a paid service provided by Microsoft and perhaps you are simply logged off?
I’m logged in and when I start vscode, it works. After it turns off, even if I try to sign in again, it doesn’t even sign in, just gets stuck in the “signing you in” part at which point I have to close and reopen the program and then it works fine until it doesn’t again
You are - from my point of view - using the only version that supports Github Copilot OOB.
If you are logged out - and you need to restart the app to continue working - I am fairly certain the issue is app related and you need to file a bugreport upstream with Microsoft.
I too use AI to get quick ideas on how to solve a given challenge - and I have - on occasions had to relogin to the AI service - not Copilot though - but JetBrains AI.
