Gimp crashes with fatal error segmentation fault. Gpu has been upgraded, plenty of memory, made a swap file, and still Gimp crashes under even moderate load demands.
(As an aside, when I try to register as a new user to report the crash to ArchLinux the form will not accept my answer to the Bot check question. Anyone else had a problem with this?)
~ inxi -v7azy ✔
Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=99af4291-78c7-4807-9ec4-2289a039fef7 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 wm: kwin_x11 vt: 1 dm: SDDM
Mobo: ASUSTeK model: PRIME Z690-A v: Rev 1.xx serial: <superuser required>
UEFI: American Megatrends v: 2403 date: 05/11/2023
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M510
status: discharging
System RAM: available: 62.54 GiB used: 10.96 GiB (17.5%)
Info: model: 12th Gen Intel Core i7-12700 bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151) stepping: 2
microcode: 0x2C
Topology: cpus: 1x cores: 12 mt: 8 tpc: 2 st: 4 threads: 20 smt: enabled
cache: L1: 1024 KiB desc: d-4x32 KiB, 8x48 KiB; i-8x32 KiB, 4x64 KiB
L2: 12 MiB desc: 8x1.2 MiB, 1x2 MiB L3: 25 MiB desc: 1x25 MiB
Speed (MHz): avg: 1908 high: 2100 min/max: 800/4800:4900:3600 scaling:
driver: intel_pstate governor: powersave cores: 1: 769 2: 2100 3: 2100
4: 2100 5: 2100 6: 2100 7: 2100 8: 2100 9: 900 10: 2100 11: 2100 12: 2100
13: 2100 14: 2100 15: 2100 16: 2100 17: 800 18: 2100 19: 2100 20: 2100
bogomips: 84500
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pconfig pdcm
rdtscp rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect
ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tme tpr_shadow
tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves
xtopology xtpr
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: XFX Pine driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
process: GF 14nm built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: DVI-D-1,HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0
chip-ID: 1002:67df class-ID: 0300 temp: 56.0 C
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1200 s-dpi: 96 s-size: 1016x317mm (40.00x12.48")
s-diag: 1064mm (41.9")
Monitor-1: DVI-D-1 mapped: DVI-D-0 pos: top-right model: Samsung SyncMaster
serial: <filter> built: 2007 res: 1920x1200 hz: 60 dpi: 94 gamma: 1.6
size: 518x324mm (20.39x12.76") diag: 611mm (24.1") ratio: 16:10 modes:
max: 1920x1200 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary,bottom-l
model: Acer G276HL serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 82
gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9
modes: max: 1920x1080 min: 720x400
API: OpenGL v: 4.6 Mesa 23.0.4 renderer: AMD Radeon RX 580 Series
(polaris10 LLVM 15.0.7 DRM 3.49 6.1.31-2-MANJARO) direct-render: Yes
Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:7ad0
class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: XFX Pine driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 06:00.0 chip-ID: 8086:15f3
class-ID: 0200
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 3.64 TiB used: 1006.68 GiB (27.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 2000GB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 04RL scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD20SDRW-11VUUS0 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1034 scheme: GPT
Optical-1: /dev/sr0 vendor: ASUS model: DRW-24B1ST a rev: 1.04
dev-links: cdrom
Optical-2: /dev/sr1 vendor: TSSTcorp model: CD/DVDW SH-S183L rev: SB03
dev-links: N/A
ID-1: / raw-size: 397.85 GiB size: 390.53 GiB (98.16%)
used: 67.81 GiB (17.4%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 99af4291-78c7-4807-9ec4-2289a039fef7
ID-2: /boot/efi raw-size: 330 MiB size: 329.3 MiB (99.79%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: E873-1CCD
ID-3: /run/media/chas/easystore raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 907.25 GiB (49.5%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17
label: easystore uuid: d1ec5187-ff6a-40d7-837d-03e2c59cf507
ID-4: /run/media/chas/home raw-size: 1.43 TiB size: 1.41 TiB (98.36%)
used: 31.62 GiB (2.2%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: home
uuid: b8a05f2b-2ce8-405a-ab04-b533e2c95eab
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
Hub-2: 1-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
chip-ID: 174c:2074 class-ID: 0900
Device-1: 1-2.3:4 info: HP LaserJet 2300d type: printer driver: usblp
interfaces: 1 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
chip-ID: 03f0:0b17 class-ID: 0701 serial: <filter>
Device-2: 1-4:3 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:19af class-ID: 0300
serial: <filter>
Device-3: 1-8:5 info: Wacom PTZ-630 [Intuos3 (6x8)] type: mouse
driver: usbhid,wacom interfaces: 1 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 300mA chip-ID: 056a:00b1 class-ID: 0301
Device-4: 1-9:6 info: Elan Micro type: keyboard driver: hid-generic,usbhid
interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0
power: 100mA chip-ID: 04f3:0104 class-ID: 0301
Hub-3: 1-12:7 info: Terminus Hub ports: 4 rev: 2.0
chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-12.1:8 info: Logitech Unifying Receiver
type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-12.3:9 info: Holtek Keyboard [Diatec Filco Majestouch 2]
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
chip-ID: 04d9:1818 class-ID: 0301
Hub-4: 2-0:1 info: super-speed hub ports: 9 rev: 3.1
Device-1: 2-4:2 info: Western Digital easystore 2648 type: mass storage
driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 1058:2648 class-ID: 0806
serial: <filter>
Hub-5: 2-9:3 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
chip-ID: 174c:3074 class-ID: 0900
System Temperatures: cpu: 27.0 C mobo: N/A gpu: amdgpu temp: 57.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 932
Processes: 379 Uptime: 1d 20h 56m wakeups: 20 Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
Packages: 1425 pm: pacman pkgs: 1415 libs: 389 tools: pamac pm: flatpak
pkgs: 10 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.27
I’d appreciate knowing about anything that looks suspicious in my system setup that might be contributing to repeated segmentation faults.
