I customized it quite much after installing and added a theme, but it dosn’t work with the standard theme eihter.
I reinstalled as you wrote with removal of config file, but nothing changed:
[ford@doloris ~]$ gimp --verbose
Parsing '/etc/gimp/2.0/gimprc' for configured language.
Parsing '/home/ford/.config/GIMP/2.10/gimprc' for configured language.
No language property found.
INIT: gimp_load_config
Parsing '/home/ford/.config/GIMP/2.10/unitrc'
gimp: fatal error: Segmentation fault
At least it outputs the version:
[ford@doloris ~]$ gimp --version
GNU Image Manipulation Program version 2.10.24
[ford@doloris ~]$ less $HOME/.xsession-errors
/usr/bin/iceauth: creating new authority file /run/user/1000/ICEauthority
gpg-agent: a gpg-agent is already running - not starting a new one
(xfce4-panel:1157): xfce4-panel-CRITICAL **: 21:38:40.645: Plugin xfce4-orageclock-plugin: The Desktop file /usr/share/xfce4/panel/plugins/xfce4-orageclock-plugin.desktop requested the Gtk2 API (v1.0), which is no longer supported.
(wrapper-2.0:1170): libnotify-WARNING **: 21:38:40.818: Failed to connect to proxy
(wrapper-2.0:1168): Gtk-WARNING **: 21:38:41.084: Negative content width -1 (allocation 1, extents 1x1) while allocating gadget (node button, owner GtkToggleButton)
** (xfce4-clipman:1193): WARNING **: 21:38:41.136: Unable to register GApplication: An object is already exported for the interface org.gtk.Application at /org/xfce/clipman
(xfce4-clipman:1193): GLib-GIO-CRITICAL **: 21:38:41.136: g_application_get_is_remote: assertion ‘application->priv->is_registered’ failed
(xfce4-clipman:1193): GLib-WARNING **: 21:38:41.136: g_set_application_name() called multiple times
(wrapper-2.0:1170): Gtk-WARNING **: 21:38:41.159: Negative content width -1 (allocation 1, extents 1x1) while allocating gadget (node button, owner PulseaudioButton)
** (xfce4-power-manager:1241): WARNING **: 21:38:41.239: Failed to get name owner: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Could not get owner of name ‘org.freedesktop.PowerManagement’: no such name
** (xfce4-power-manager:1241): WARNING **: 21:38:41.239: Failed to get name owner: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Could not get owner of name ‘org.xfce.PowerManager’: no such name
(xfce4-power-manager:1241): GLib-GObject-WARNING **: 21:38:41.537: …/glib/gobject/gsignal.c:2614: signal ‘Changed’ is invalid for instance ‘0x563ddb39c3a0’ of type ‘GDBusProxy’
(xfce4-power-manager:1241): xfce4-power-manager-WARNING **: 21:38:41.551: could not map keysym 1008ffa8 to keycode
** (xfce4-power-manager:1241): WARNING **: 21:38:41.556: No outputs have backlight property
(xfce4-power-manager:1241): xfce4-power-manager-WARNING **: 21:38:41.560: Failed to get keyboard max brightness level : GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface “org.freedesktop.UPower.KbdBacklight” on object at path /org/freedesktop/UPower/KbdBacklight
blueman-applet 21.38.41 WARNING PluginManager:148 __load_plugin: Not loading PPPSupport because its conflict has higher priority
blueman-applet 21.38.41 WARNING PluginManager:148 __load_plugin: Not loading DhcpClient because its conflict has higher priority
(wrapper-2.0:1169): libsystray-CRITICAL **: 21:38:42.023: sn_item_invalidate: assertion ‘item->properties_proxy != NULL’ failed
xfsettingsd: Another instance took over. Leaving…
blueman-applet 21.39.05 WARNING DiscvManager:109 update_menuitems: warning: Adapter is None
** Message: 21:39:12.123: updates_checker.vala:71: check updates
** Message: 21:39:13.220: updates_checker.vala:101: 0 updates found
(xfwm4:1128): xfwm4-WARNING **: 21:42:06.882: unmanaged net_wm_state (window 0x4400072, atom “_NET_WM_STATE_STAYS_ON_TOP”)
(xfwm4:1128): xfwm4-WARNING **: 21:42:15.375: unmanaged net_wm_state (window 0x4400078, atom “_NET_WM_STATE_STAYS_ON_TOP”)
(xfwm4:1128): xfwm4-WARNING **: 21:43:30.267: unmanaged net_wm_state (window 0x440007e, atom “_NET_WM_STATE_STAYS_ON_TOP”)
[ford@doloris ~]$ coredumpctl
TIME PID UID GID SIG COREFILE EXE
Thu 2021-05-20 21:19:17 CEST 14607 1000 1000 11 missing /usr/bin/xfce4-settings-manager
Thu 2021-05-20 22:07:26 CEST 1230 1000 1000 11 missing /usr/bin/xfdesktop
Thu 2021-05-20 23:19:18 CEST 1138 1000 1000 6 missing /usr/bin/xfce4-session
Sat 2021-05-22 17:09:56 CEST 1401 1000 1000 6 missing /opt/slic3r/perl-local
Sat 2021-05-22 17:10:06 CEST 1444 1000 1000 6 missing /opt/slic3r/perl-local
Sat 2021-05-22 17:10:12 CEST 1487 1000 1000 6 missing /opt/slic3r/perl-local
Sat 2021-05-22 17:10:24 CEST 1532 1000 1000 6 missing /opt/slic3r/perl-local
Sat 2021-05-22 17:11:23 CEST 6489 1000 1000 6 missing /opt/slic3r/perl-local
Sat 2021-05-22 17:29:04 CEST 10060 1000 1000 6 missing /home/ford/perl-local
[ford@doloris ~]$ journalctl -b -p err
-- Journal begins at Thu 2021-05-20 20:36:30 CEST, ends at Thu 2021-05-27 21:54:07 CEST. --
Mai 27 21:38:33 doloris kernel: kvm: disabled by bios
Mai 27 21:38:33 doloris systemd-udevd[305]: could not read from '/sys/module/amd64_edac/initstate': No such device
Mai 27 21:38:34 doloris kernel: kvm: disabled by bios
Mai 27 21:38:39 doloris lightdm[1045]: gkr-pam: unable to locate daemon control file
Mai 27 21:38:42 doloris wpa_supplicant[681]: bgscan simple: Failed to enable signal strength monitoring
Mai 27 21:39:05 doloris pulseaudio[1151]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy bloc>
