Gimp crashes at startup
Weird, can’t launch gimp anymore, any ideas?
$ gimp
gimp: symbol lookup error: /usr/lib/libgegl-0.4.so.0: undefined symbol: babl_fish_get_process, version V0_1_0
Installed:
$ pacman -Q |grep gimp
gimp 2.10.32-1
gimp-help-en 2.10.0-5
gimp-plugin-resynthesizer 2.0.3-2
python2-gimp 2.10.30-1
What about the packages gegl and babl ?
You should re-install them (or make sure they’re fully updated), and also make sure they’re not from the AUR.
It’s possible you pulled one of them (or both) from the AUR because of another dependent package (besides GIMP), and thus you don’t consciously relate gegl or babl with GIMP itself. :wink:
Great, that was it, solved now:
$ sudo pacman -Suy gegl babl
[sudo] password for user:
 core        166.3 KiB   449 KiB/s 00:00 [#############################################################] 100%
 extra is up to date
 community is up to date
 multilib is up to date
warning: gegl-0.4.38-1 is up to date -- reinstalling
resolving dependencies...
:: babl and babl-git are in conflict. Remove babl-git? [y/N] y
Packages (4) babl-git-0.1.89.r1705.2c9843f-1 [removal]  grub-2.06.r297.g0c6c1aff2-1  babl-0.1.92-1  gegl-0.4.38-1
Total Download Size:   18.37 MiB
Total Installed Size:  63.92 MiB
Net Upgrade Size:       0.87 MiB
:: Proceed with installation? [Y/n] Y
:: Retrieving packages...
 grub-2.06.r297.g0c6c1aff2-1-x86_64                                         14.8 MiB  3.65 MiB/s 00:04 [#############################################################] 100%
 gegl-0.4.38-1-x86_64                                                        3.1 MiB  4.30 MiB/s 00:01 [#############################################################] 100%
 babl-0.1.92-1-x86_64                                                      464.0 KiB  3.02 MiB/s 00:00 [#############################################################] 100%
 Total (3/3)        18.4 MiB  3.61 MiB/s 00:05 [#############################################################] 100%
(3/3) checking keys in keyring        [#############################################################] 100%
(3/3) checking package integrity        [#############################################################] 100%
(3/3) loading package files        [#############################################################] 100%
(3/3) checking for file conflicts        [#############################################################] 100%
(4/4) checking available disk space        [#############################################################] 100%
(1/1) removing babl-git        [#############################################################] 100%
(1/3) installing babl        [#############################################################] 100%
(2/3) reinstalling gegl        [#############################################################] 100%
(3/3) upgrading grub        [#############################################################] 100%
:: Grub does no longer support side-loading modules when secure boot is
   enabled. Thus booting will fail, unless you have an efi executable
   'grubx64.efi' with bundled modules.
(1/2) Arming ConditionNeedsUpdate...
(2/2) Updating the info directory file...
