When i select any tool and try to do something with it on the canvas, nothing happens, ecxept the mouse gets very juddery.
Does this happen in X11 session too?
i dont kow how to try this.
i tried to startx and to simply run gimp on another tty but this failed.
You added wayland as tag to your topic title, so i assumed you run under wayland session and you know how to switch sessions.
Open up terminal and provide from it:
inxi -Fazy
Also, open gimp from terminal and provide the errors you get. Please format the output text for better reading.
$ inxi -Fazy
Kernel: 5.15.25-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=6cc17556-5d59-4602-878c-d03a8eb9f4d5 rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel, plank
wm: xfwm 4.16.1 vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux
base: Arch Linux
Type: Desktop System: Micro-Star product: MS-7A38 v: 2.0
serial: <superuser required>
Mobo: Micro-Star model: B350M PRO-VDH (MS-7A38) v: 2.0
serial: <superuser required> UEFI: American Megatrends v: A.60
date: 09/19/2017
Info: model: AMD Ryzen 5 1400 bits: 64 type: MT MCP arch: Zen
family: 0x17 (23) model-id: 1 stepping: 1 microcode: 0x8001129
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1583 high: 2763 min/max: 1550/3200 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2763 2: 1650
3: 1377 4: 1375 5: 1377 6: 1377 7: 1377 8: 1373 bogomips: 51216
Type: spectre_v2
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: AMD Lexa XT [Radeon PRO WX 2100] driver: amdgpu v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 8 ports: active: DP-3 empty: DP-1,DP-2
bus-ID: 22:00.0 chip-ID: 1002:6995 class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.3 compositor: xfwm v: 4.16.1 driver:
X: loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
gpu: amdgpu display-ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: DisplayPort-2 mapped: DP-3 model: HP 24es serial: <filter>
built: 2017 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
size: 527x296mm (20.7x11.7") diag: 604mm (23.8") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8
bus-ID: 22:00.1 chip-ID: 1002:aae0 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
bus-ID: 24:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: C-Media Audio Adapter (Unitek Y-247A) type: USB
driver: cmedia_hs100b,snd-usb-audio,usbhid bus-ID: 1-9:3 chip-ID: 0d8c:0014
class-ID: 0300
Sound Server-1: ALSA v: k5.15.25-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.47 running: no
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 1e:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp30s0 state: down mac: <filter>
Device-2: Broadcom BCM4360 802.11ac Wireless Network Adapter driver: wl
v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 20:00.0 chip-ID: 14e4:43a0 class-ID: 0280
IF: wlp32s0 state: up mac: <filter>
Local Storage: total: 1.25 TiB used: 95.23 GiB (7.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Silicon Power
model: SPCC M.2 PCIe SSD size: 238.47 GiB block-size: physical: 512 B
rev: ECFM22.6 temp: 27.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT120BX500SSD1
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: R013 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000VX005-2EZ102
type: HDD rpm: 5900 serial: <filter> rev: CV11 scheme: GPT
ID-1: / raw-size: 111.33 GiB size: 109.08 GiB (97.98%)
used: 95.23 GiB (87.3%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 469 MiB size: 468.1 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: file size: 10.74 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 34.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 2019
Processes: 273 Uptime: 13m wakeups: 0 Memory: 7.78 GiB
used: 2.19 GiB (28.1%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 1611 pacman: 1600 lib: 427 flatpak: 11
Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.13
$ gimp
Gtk-Message: 12:39:51.638: Failed to load module "topmenu-gtk-module"
~/.gtkrc-2.0:1: error: unexpected character ':', expected keyword - e.g. `style'
I just realized it is an x session
Ok, so you are using topmenu-gtk from AUR, that might need a rebuild once you install the latest updates, but i wonder what custom thing you added to your
Not quite sure how much that will affect things in gimp, but might want to look into it:
I dont use topmenu-gtk because i got it never working.
in fact it isnt installed anymore.
the configuration line was for the module. gimp tried to use the module beacuse of the line, i deleted it.
however, it didn’t solve the problem
Well, you can remove then the file, restart your session and share the newer error you get when opening gimp from terminal.
Not sure also how to interpret this:
Do you have some custom driver installed for your GPU?
Also, never had issues with gimp, but might want to delete, or move the ~/.config/GIMP/ and start gimp fresh …
There is no new error message.
I dont remind to install any gpu drivers.
i solved it by moving the configuration file, i will try to find the wrong setting later this day and post it here.
Thanks for your help so far!
This seemd to be all pretty obivous stuff but i hadn’t really a way of approaching such an issue.
Edit:
The folder is quite big an i found no suspicious differences at a broad overview. It wasn’t the config file.
