Up from today there is an annoying issue in chrome-browsers.
If I open some pages, thy are scroll down the screen at their own in a ghostly manner.
I’ve tried it in Brave and Vivaldi
See this video, what happend if I refresh a Page (e.g. this Forum-Page here).
BTW: Yesterday there was a bigger upgrade available. I’ve done this update.
First I thought, it might be a sticked key or broken mouse-hardware… so I’ve unplugged them.
But the issue remain.
As I use a laptop (keyboard and mouse are untouched in last days) I want to be sure that it’s not an hardware issue of the build-in keyboard and touchpad… so I’ve started “screenkey” where I also activate “mouse-monitoring”.
So no keypress or mouse-move are recognized.
BTW: It make no difference if I start the browser in general or incognito-mode
What might the error be?
As I don’t have this scroll-down behavior in other applications (I’ve tried kate, libre-writer, thunderbird, etc.) I think it might be an chrome-engine issue?!?
Ah… ok, that is not in any dependency to the issue.
I’ve found that this was caused of my Screen-Recorder Application which runs in wine.
If I stop it, and refresh the browser… and ghostly stuff scrolling starts again, no logs are created in the Journal.
Since you mentioned it works on correctly in some apps, and others not it looks like, to me at least, it is a GTK issue, since all/most apps you mentioned working is Qt. The reason I say most is because you mentioned Thunderbird and I don’t think it’s Qt.
So I’d recommend checking that. I do not know what the settings are or is named, but I think that’s where the answer lay, at least.
Ok, your suggestion might point in the right direction. Checked it with firefox now, same result (ghostly scrolling).
What other GTK-Based application can I check for this bug?
And how to fix it?
Your linked page give me no Idea what the reason might be and how I may fix it. The posting is about a user who tells that his touchpad is to senstive. But I don’t touch any key or touchpad at all.
