I cannot see these in the Timeshift application itself, and would like to have them deleted.
Each time I run a system upgrade, Timeshift tries to do an ‘auto snapshot’ and clean up old snapshots - and since it cannot find these ‘ghost’ snapshots, it goes through a long process of trying to delete and failing.
I also see them. It’s like, when you remove snapshots, some files stay. It is possible that this is an intentional behaviour - it could be, that the newer snapshots, use the files from removed ones. However, I can be wrong.
Anyway, those old snapshots take a lot of space so I just delete them manually, but leave some “newer ones”, at least few versions before the last existing snapshot. Also, after deleting, I’m doing a new snapshot, in case the deleted folders messed up existing snapshots.
I wish there would be a better documentation for this.
Hi there, I have tried to delete them manually but cannot do so. I get an error “cannot remove xyz file, read-only file system”. Not sure how to proceed.
What file format do you use on your backup source and which type of backup do you use?
I use ext4 and have rsync based backups, so I have full access to my files. Aside having full backup, I often need to reach for certain files within backup, that is why this kind of setup is optimal for me.
ID 290 gen 389 parent 5 top level 5 path .Trash-0/files/2021-09-18_11-52-59/@
ID 291 gen 500 parent 5 top level 5 path .Trash-0/files/2021-09-18_13-18-27/@
ID 293 gen 807 parent 5 top level 5 path .Trash-0/files/2021-09-18_16-52-16/@
ID 296 gen 3076 parent 5 top level 5 path .Trash-0/files/2021-09-21_09-02-23/@
ID 298 gen 3050 parent 5 top level 5 path .Trash-0/files/2021-09-21_09-34-48/@
