I was poking around with Howdy trying to get that to work and I needed to sign out. When I came to the login screen my second screen displayed no signal. I went into display settings and it showed this device “DP-2” with only a few display modes that weren’t the same as my second display. I deleted KDE configs, there’s no Xorg configs.
My Laptop screen is listed as “eDP-1”. I connect my second display with HDMI; there’s no displayports on this laptop.
Kernel: 6.1.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
v: 12.2.1 parameters: BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64
root=UUID=033641d7-6d63-4b46-ac9b-73c230505958 rw quiet
splash udev.log_priority=3
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11
vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Convertible System: HP product: HP Spectre x360
Convertible 15-ch0xx v: N/A serial: <superuser required>
Chassis: type: 31 serial: <superuser required>
Mobo: HP model: 83BB v: 60.34 serial: <superuser required>
UEFI: AMI v: F.36 date: 03/19/2022
Device-1: hid-0018:04F3:25BF.0001-battery
model: ELAN2514:00 04F3:25BF serial: N/A charge: N/A
status: N/A
RAM: total: 31.11 GiB used: 4.03 GiB (13.0%)
RAM Report: permissions: Unable to run dmidecode. Root
privileges required.
Info: model: Intel Core i7-8705G bits: 64 type: MT MCP
arch: Kaby Lake gen: core 8 level: v3 note: check built: 2018
process: Intel 14nm family: 6 model-id: 0x9E (158)
stepping: 9 microcode: 0xF0
Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled
cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800
3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 bogomips: 49618
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts
clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp
hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx
monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse
pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep sgx
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves
xtopology xtpr
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache
flushes, SMT vulnerable
Type: mmio_stale_data mitigation: Clear CPU buffers; SMT
vulnerable
Type: spec_store_bypass mitigation: Speculative Store Bypass
disabled via prctl
Type: spectre_v1 mitigation: usercopy/swapgs barriers and
__user pointer sanitization
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 630 vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-9.5 process: Intel 14nm
built: 2016-20 ports: active: DP-2,eDP-1 empty: DP-1, DP-3,
HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:591b
class-ID: 0300
Device-2: AMD Polaris 22 XL [Radeon RX Vega M GL]
vendor: Hewlett-Packard driver: amdgpu v: kernel arch: GCN-4
code: Arctic Islands process: GF 14nm built: 2016-20 pcie:
gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 1002:694e
class-ID: 0380 temp: 37.0 C
Device-3: Quanta HP Wide Vision FHD Camera type: USB
driver: uvcvideo bus-ID: 1-5:5 chip-ID: 0408:5251
Display: x11 server: X.Org v: 21.1.7 compositor: kwin_x11
driver: X: loaded: amdgpu,modesetting alternate: fbdev,vesa
dri: iris,radeonsi gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96
s-size: 507x285mm (19.96x11.22") s-diag: 582mm (22.9")
Monitor-1: DP-2 pos: primary res: 640x480 hz: 60 size: N/A
modes: max: 640x480 min: 848x480
Monitor-2: eDP-1 model: BOE Display 0x0730 built: 2016
res: 1920x1080 hz: 60 dpi: 141 gamma: 1.2
size: 345x194mm (13.58x7.64") diag: 396mm (15.6") ratio: 16:9
modes: 3840x2160
API: OpenGL v: 4.6 Mesa 22.3.5 renderer: Mesa Intel HD
Graphics 630 (KBL GT2) direct-render: Yes
Device-1: Intel CM238 HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel bus-ID: 1-2:17 v: kernel bus-ID: 00:1f.3
chip-ID: 14ed:1012 chip-ID: 8086:a171 class-ID: 0300
class-ID: 0403
Device-2: Shure MV7 type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound API: ALSA v: k6.1.12-1-MANJARO running: yes
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-3: PipeWire v: 0.3.65 running: yes
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 6e:00.0
chip-ID: 8086:24fd class-ID: 0280
Device-1: Intel Bluetooth wireless interface type: USB
driver: btusb v: 0.8 bus-ID: 1-7:7 chip-ID: 8087:0a2b
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 0 state: up
address: see --recommends
Local Storage: total: 983.17 GiB used: 13.68 GiB (1.4%)
SMART Message: Unable to run smartctl. Root privileges
required.
ID-1: /dev/sda maj-min: 8:0 vendor: TeamGroup
model: TM8PS7001T size: 953.87 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 8A0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB model: General
size: 29.3 GiB block-size: physical: 512 B logical: 512 B
type: N/A serial: <filter> rev: 5.00 scheme: MBR
SMART Message: Unknown USB bridge. Flash drive/Unsupported
enclosure?
ID-1: / raw-size: 953.57 GiB size: 937.53 GiB (98.32%)
used: 13.68 GiB (1.5%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
label: N/A uuid: 033641d7-6d63-4b46-ac9b-73c230505958
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
label: N/A uuid: F678-8AA4
ID-1: /dev/sdb1 maj-min: 8:17 size: 3.82 GiB fs: iso9660
ID-2: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat
label: MISO_EFI uuid: 91F8-3549
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16
rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Hub-2: 1-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1
speed: 480 Mb/s power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-1.1:4 info: Logitech G502 X type: Mouse,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 046d:c099 class-ID: 0300
serial: <filter>
Device-2: 1-1.2:6 info: Logitech Gaming Keyboard G610
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 500mA chip-ID: 046d:c338
class-ID: 0300 serial: <filter>
Device-3: 1-1.4:8 info: Integrated Express Chipsbank CBM2199
Flash Drive type: Mass Storage driver: usb-storage
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA
chip-ID: 048d:1234 class-ID: 0806 serial: <filter>
Device-4: 1-2:17 info: Shure MV7 type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 5 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 14ed:1012 class-ID: 0300
Device-5: 1-5:5 info: Quanta HP Wide Vision FHD Camera
type: Video driver: uvcvideo interfaces: 4 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 0408:5251
Device-6: 1-7:7 info: Intel Bluetooth wireless interface
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 8087:0a2b class-ID: e001
Hub-3: 2-0:1 info: Super-speed hub ports: 8 rev: 3.0
speed: 5 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-4: 2-1:2 info: Genesys Logic USB3.0 Hub ports: 4 rev: 3.0
speed: 5 Gb/s chip-ID: 05e3:0617 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 2
Hub-6: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
System Temperatures: cpu: 48.0 C pch: 57.5 C mobo: N/A
gpu: amdgpu temp: 37.0 C
Fan Speeds (RPM): cpu: 0 mobo: 8960
Processes: 268 Uptime: 59m wakeups: 6 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1
clang: 15.0.7 Packages: pm: pacman pkgs: 1277 libs: 329
tools: pamac,trizen pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.25
xrandr --verbose:
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
eDP-1 connected 1920x1080+0+0 (0x60) normal (normal left inverted right x axis y axis) 345mm x 194mm
Identifier: 0x41
Timestamp: 3139568
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 1
CRTCs: 1 0 2
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
EDID:
00ffffffffffff0009e5300700000000
121a0104a5221378022e10a757549f26
11505400000001010101010101010101
0101010101014dd000a0f0703e803020
350059c21000001ae08a00a0f0703e80
3020350059c21000001a000000000000
00000000000000000000000000000002
000c2dff103ca632463aa60000000027
scaling mode: Full aspect
supported: Full, Center, Full aspect
Colorspace: Default
supported: Default, RGB_Wide_Gamut_Fixed_Point, RGB_Wide_Gamut_Floating_Point, opRGB, DCI-P3_RGB_D65, BT2020_RGB, BT601_YCC, BT709_YCC, XVYCC_601, XVYCC_709, SYCC_601, opYCC_601, BT2020_CYCC, BT2020_YCC
max bpc: 12
range: (6, 12)
Broadcast RGB: Automatic
supported: Automatic, Full, Limited 16:235
panel orientation: Normal
supported: Normal, Upside Down, Left Side Up, Right Side Up
link-status: Good
supported: Good, Bad
CTM: 0 1 0 0 0 0 0 0 0 1 0 0 0 0 0 0
0 1
CONNECTOR_ID: 95
supported: 95
non-desktop: 0
range: (0, 1)
3840x2160 (0x48) 533.250MHz +HSync -VSync +preferred
h: width 3840 start 3888 end 3920 total 4000 skew 0 clock 133.31KHz
v: height 2160 start 2163 end 2168 total 2222 clock 60.00Hz
3840x2160 (0x49) 712.750MHz -HSync +VSync
h: width 3840 start 4160 end 4576 total 5312 skew 0 clock 134.18KHz
v: height 2160 start 2163 end 2168 total 2237 clock 59.98Hz
3840x2160 (0x4a) 533.000MHz +HSync -VSync
h: width 3840 start 3888 end 3920 total 4000 skew 0 clock 133.25KHz
v: height 2160 start 2163 end 2168 total 2222 clock 59.97Hz
3840x2160 (0x4b) 355.520MHz +HSync -VSync
h: width 3840 start 3888 end 3920 total 4000 skew 0 clock 88.88KHz
v: height 2160 start 2163 end 2168 total 2222 clock 40.00Hz
3200x1800 (0x4c) 492.000MHz -HSync +VSync
h: width 3200 start 3456 end 3800 total 4400 skew 0 clock 111.82KHz
v: height 1800 start 1803 end 1808 total 1865 clock 59.96Hz
3200x1800 (0x4d) 373.000MHz +HSync -VSync
h: width 3200 start 3248 end 3280 total 3360 skew 0 clock 111.01KHz
v: height 1800 start 1803 end 1808 total 1852 clock 59.94Hz
2880x1620 (0x4e) 396.250MHz -HSync +VSync
h: width 2880 start 3096 end 3408 total 3936 skew 0 clock 100.67KHz
v: height 1620 start 1623 end 1628 total 1679 clock 59.96Hz
2880x1620 (0x4f) 303.750MHz +HSync -VSync
h: width 2880 start 2928 end 2960 total 3040 skew 0 clock 99.92KHz
v: height 1620 start 1623 end 1628 total 1666 clock 59.97Hz
2560x1600 (0x50) 348.500MHz -HSync +VSync
h: width 2560 start 2760 end 3032 total 3504 skew 0 clock 99.46KHz
v: height 1600 start 1603 end 1609 total 1658 clock 59.99Hz
2560x1600 (0x51) 268.500MHz +HSync -VSync
h: width 2560 start 2608 end 2640 total 2720 skew 0 clock 98.71KHz
v: height 1600 start 1603 end 1609 total 1646 clock 59.97Hz
2560x1440 (0x52) 638.250MHz -HSync +VSync DoubleScan
h: width 2560 start 2780 end 3064 total 3568 skew 0 clock 178.88KHz
v: height 1440 start 1441 end 1444 total 1491 clock 59.99Hz
2560x1440 (0x53) 469.125MHz +HSync -VSync DoubleScan
h: width 2560 start 2584 end 2600 total 2640 skew 0 clock 177.70KHz
v: height 1440 start 1441 end 1444 total 1481 clock 59.99Hz
2560x1440 (0x54) 312.250MHz -HSync +VSync
h: width 2560 start 2752 end 3024 total 3488 skew 0 clock 89.52KHz
v: height 1440 start 1443 end 1448 total 1493 clock 59.96Hz
2560x1440 (0x55) 241.500MHz +HSync -VSync
h: width 2560 start 2608 end 2640 total 2720 skew 0 clock 88.79KHz
v: height 1440 start 1443 end 1448 total 1481 clock 59.95Hz
2048x1536 (0x56) 266.950MHz -HSync +VSync
h: width 2048 start 2200 end 2424 total 2800 skew 0 clock 95.34KHz
v: height 1536 start 1537 end 1540 total 1589 clock 60.00Hz
1920x1440 (0x57) 234.000MHz -HSync +VSync
h: width 1920 start 2048 end 2256 total 2600 skew 0 clock 90.00KHz
v: height 1440 start 1441 end 1444 total 1500 clock 60.00Hz
1856x1392 (0x58) 218.300MHz -HSync +VSync
h: width 1856 start 1952 end 2176 total 2528 skew 0 clock 86.35KHz
v: height 1392 start 1393 end 1396 total 1439 clock 60.01Hz
1792x1344 (0x59) 204.800MHz -HSync +VSync
h: width 1792 start 1920 end 2120 total 2448 skew 0 clock 83.66KHz
v: height 1344 start 1345 end 1348 total 1394 clock 60.01Hz
2048x1152 (0x5a) 406.500MHz -HSync +VSync DoubleScan
h: width 2048 start 2220 end 2444 total 2840 skew 0 clock 143.13KHz
v: height 1152 start 1153 end 1156 total 1193 clock 59.99Hz
2048x1152 (0x5b) 302.500MHz +HSync -VSync DoubleScan
h: width 2048 start 2072 end 2088 total 2128 skew 0 clock 142.15KHz
v: height 1152 start 1153 end 1156 total 1185 clock 59.98Hz
2048x1152 (0x5c) 197.000MHz -HSync +VSync
h: width 2048 start 2184 end 2400 total 2752 skew 0 clock 71.58KHz
v: height 1152 start 1155 end 1160 total 1195 clock 59.90Hz
2048x1152 (0x5d) 156.750MHz +HSync -VSync
h: width 2048 start 2096 end 2128 total 2208 skew 0 clock 70.99KHz
v: height 1152 start 1155 end 1160 total 1185 clock 59.91Hz
1920x1200 (0x5e) 193.250MHz -HSync +VSync
h: width 1920 start 2056 end 2256 total 2592 skew 0 clock 74.56KHz
v: height 1200 start 1203 end 1209 total 1245 clock 59.88Hz
1920x1200 (0x5f) 154.000MHz +HSync -VSync
h: width 1920 start 1968 end 2000 total 2080 skew 0 clock 74.04KHz
v: height 1200 start 1203 end 1209 total 1235 clock 59.95Hz
1920x1080 (0x60) 356.375MHz -HSync +VSync DoubleScan *current
h: width 1920 start 2080 end 2288 total 2656 skew 0 clock 134.18KHz
v: height 1080 start 1081 end 1084 total 1118 clock 60.01Hz
1920x1080 (0x61) 266.500MHz +HSync -VSync DoubleScan
h: width 1920 start 1944 end 1960 total 2000 skew 0 clock 133.25KHz
v: height 1080 start 1081 end 1084 total 1111 clock 59.97Hz
1920x1080 (0x62) 173.000MHz -HSync +VSync
h: width 1920 start 2048 end 2248 total 2576 skew 0 clock 67.16KHz
v: height 1080 start 1083 end 1088 total 1120 clock 59.96Hz
1920x1080 (0x63) 138.500MHz +HSync -VSync
h: width 1920 start 1968 end 2000 total 2080 skew 0 clock 66.59KHz
v: height 1080 start 1083 end 1088 total 1111 clock 59.93Hz
1600x1200 (0x64) 162.000MHz +HSync +VSync
h: width 1600 start 1664 end 1856 total 2160 skew 0 clock 75.00KHz
v: height 1200 start 1201 end 1204 total 1250 clock 60.00Hz
1680x1050 (0x65) 146.250MHz -HSync +VSync
h: width 1680 start 1784 end 1960 total 2240 skew 0 clock 65.29KHz
v: height 1050 start 1053 end 1059 total 1089 clock 59.95Hz
1680x1050 (0x66) 119.000MHz +HSync -VSync
h: width 1680 start 1728 end 1760 total 1840 skew 0 clock 64.67KHz
v: height 1050 start 1053 end 1059 total 1080 clock 59.88Hz
1400x1050 (0x67) 122.000MHz +HSync +VSync
h: width 1400 start 1488 end 1640 total 1880 skew 0 clock 64.89KHz
v: height 1050 start 1052 end 1064 total 1082 clock 59.98Hz
1600x900 (0x68) 246.000MHz -HSync +VSync DoubleScan
h: width 1600 start 1728 end 1900 total 2200 skew 0 clock 111.82KHz
v: height 900 start 901 end 904 total 932 clock 59.99Hz
1600x900 (0x69) 186.500MHz +HSync -VSync DoubleScan
h: width 1600 start 1624 end 1640 total 1680 skew 0 clock 111.01KHz
v: height 900 start 901 end 904 total 926 clock 59.94Hz
1600x900 (0x6a) 118.250MHz -HSync +VSync
h: width 1600 start 1696 end 1856 total 2112 skew 0 clock 55.99KHz
v: height 900 start 903 end 908 total 934 clock 59.95Hz
1600x900 (0x6b) 97.500MHz +HSync -VSync
h: width 1600 start 1648 end 1680 total 1760 skew 0 clock 55.40KHz
v: height 900 start 903 end 908 total 926 clock 59.82Hz
1280x1024 (0x6c) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1400x900 (0x6d) 103.500MHz -HSync +VSync
h: width 1400 start 1480 end 1624 total 1848 skew 0 clock 56.01KHz
v: height 900 start 903 end 913 total 934 clock 59.96Hz
1400x900 (0x6e) 86.500MHz +HSync -VSync
h: width 1400 start 1448 end 1480 total 1560 skew 0 clock 55.45KHz
v: height 900 start 903 end 913 total 926 clock 59.88Hz
1280x960 (0x6f) 108.000MHz +HSync +VSync
h: width 1280 start 1376 end 1488 total 1800 skew 0 clock 60.00KHz
v: height 960 start 961 end 964 total 1000 clock 60.00Hz
1440x810 (0x70) 198.125MHz -HSync +VSync DoubleScan
h: width 1440 start 1548 end 1704 total 1968 skew 0 clock 100.67KHz
v: height 810 start 811 end 814 total 839 clock 60.00Hz
1440x810 (0x71) 151.875MHz +HSync -VSync DoubleScan
h: width 1440 start 1464 end 1480 total 1520 skew 0 clock 99.92KHz
v: height 810 start 811 end 814 total 833 clock 59.97Hz
1368x768 (0x72) 85.250MHz -HSync +VSync
h: width 1368 start 1440 end 1576 total 1784 skew 0 clock 47.79KHz
v: height 768 start 771 end 781 total 798 clock 59.88Hz
1368x768 (0x73) 72.250MHz +HSync -VSync
h: width 1368 start 1416 end 1448 total 1528 skew 0 clock 47.28KHz
v: height 768 start 771 end 781 total 790 clock 59.85Hz
1280x800 (0x74) 174.250MHz -HSync +VSync DoubleScan
h: width 1280 start 1380 end 1516 total 1752 skew 0 clock 99.46KHz
v: height 800 start 801 end 804 total 829 clock 59.99Hz
1280x800 (0x75) 134.250MHz +HSync -VSync DoubleScan
h: width 1280 start 1304 end 1320 total 1360 skew 0 clock 98.71KHz
v: height 800 start 801 end 804 total 823 clock 59.97Hz
1280x800 (0x76) 83.500MHz -HSync +VSync
h: width 1280 start 1352 end 1480 total 1680 skew 0 clock 49.70KHz
v: height 800 start 803 end 809 total 831 clock 59.81Hz
1280x800 (0x77) 71.000MHz +HSync -VSync
h: width 1280 start 1328 end 1360 total 1440 skew 0 clock 49.31KHz
v: height 800 start 803 end 809 total 823 clock 59.91Hz
1280x720 (0x78) 156.125MHz -HSync +VSync DoubleScan
h: width 1280 start 1376 end 1512 total 1744 skew 0 clock 89.52KHz
v: height 720 start 721 end 724 total 746 clock 60.00Hz
1280x720 (0x79) 120.750MHz +HSync -VSync DoubleScan
h: width 1280 start 1304 end 1320 total 1360 skew 0 clock 88.79KHz
v: height 720 start 721 end 724 total 740 clock 59.99Hz
1280x720 (0x7a) 74.500MHz -HSync +VSync
h: width 1280 start 1344 end 1472 total 1664 skew 0 clock 44.77KHz
v: height 720 start 723 end 728 total 748 clock 59.86Hz
1280x720 (0x7b) 63.750MHz +HSync -VSync
h: width 1280 start 1328 end 1360 total 1440 skew 0 clock 44.27KHz
v: height 720 start 723 end 728 total 741 clock 59.74Hz
1024x768 (0x7c) 133.475MHz -HSync +VSync DoubleScan
h: width 1024 start 1100 end 1212 total 1400 skew 0 clock 95.34KHz
v: height 768 start 768 end 770 total 794 clock 60.04Hz
1024x768 (0x7d) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
960x720 (0x7e) 117.000MHz -HSync +VSync DoubleScan
h: width 960 start 1024 end 1128 total 1300 skew 0 clock 90.00KHz
v: height 720 start 720 end 722 total 750 clock 60.00Hz
928x696 (0x7f) 109.150MHz -HSync +VSync DoubleScan
h: width 928 start 976 end 1088 total 1264 skew 0 clock 86.35KHz
v: height 696 start 696 end 698 total 719 clock 60.05Hz
896x672 (0x80) 102.400MHz -HSync +VSync DoubleScan
h: width 896 start 960 end 1060 total 1224 skew 0 clock 83.66KHz
v: height 672 start 672 end 674 total 697 clock 60.01Hz
1024x576 (0x81) 98.500MHz -HSync +VSync DoubleScan
h: width 1024 start 1092 end 1200 total 1376 skew 0 clock 71.58KHz
v: height 576 start 577 end 580 total 597 clock 59.95Hz
1024x576 (0x82) 78.375MHz +HSync -VSync DoubleScan
h: width 1024 start 1048 end 1064 total 1104 skew 0 clock 70.99KHz
v: height 576 start 577 end 580 total 592 clock 59.96Hz
1024x576 (0x83) 46.500MHz -HSync +VSync
h: width 1024 start 1064 end 1160 total 1296 skew 0 clock 35.88KHz
v: height 576 start 579 end 584 total 599 clock 59.90Hz
1024x576 (0x84) 42.000MHz +HSync -VSync
h: width 1024 start 1072 end 1104 total 1184 skew 0 clock 35.47KHz
v: height 576 start 579 end 584 total 593 clock 59.82Hz
960x600 (0x85) 96.625MHz -HSync +VSync DoubleScan
h: width 960 start 1028 end 1128 total 1296 skew 0 clock 74.56KHz
v: height 600 start 601 end 604 total 622 clock 59.93Hz
960x600 (0x86) 77.000MHz +HSync -VSync DoubleScan
h: width 960 start 984 end 1000 total 1040 skew 0 clock 74.04KHz
v: height 600 start 601 end 604 total 617 clock 60.00Hz
960x540 (0x87) 86.500MHz -HSync +VSync DoubleScan
h: width 960 start 1024 end 1124 total 1288 skew 0 clock 67.16KHz
v: height 540 start 541 end 544 total 560 clock 59.96Hz
960x540 (0x88) 69.250MHz +HSync -VSync DoubleScan
h: width 960 start 984 end 1000 total 1040 skew 0 clock 66.59KHz
v: height 540 start 541 end 544 total 555 clock 59.99Hz
960x540 (0x89) 40.750MHz -HSync +VSync
h: width 960 start 992 end 1088 total 1216 skew 0 clock 33.51KHz
v: height 540 start 543 end 548 total 562 clock 59.63Hz
960x540 (0x8a) 37.250MHz +HSync -VSync
h: width 960 start 1008 end 1040 total 1120 skew 0 clock 33.26KHz
v: height 540 start 543 end 548 total 556 clock 59.82Hz
800x600 (0x8b) 81.000MHz +HSync +VSync DoubleScan
h: width 800 start 832 end 928 total 1080 skew 0 clock 75.00KHz
v: height 600 start 600 end 602 total 625 clock 60.00Hz
800x600 (0x8c) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
800x600 (0x8d) 36.000MHz +HSync +VSync
h: width 800 start 824 end 896 total 1024 skew 0 clock 35.16KHz
v: height 600 start 601 end 603 total 625 clock 56.25Hz
840x525 (0x8e) 73.125MHz -HSync +VSync DoubleScan
h: width 840 start 892 end 980 total 1120 skew 0 clock 65.29KHz
v: height 525 start 526 end 529 total 544 clock 60.01Hz
840x525 (0x8f) 59.500MHz +HSync -VSync DoubleScan
h: width 840 start 864 end 880 total 920 skew 0 clock 64.67KHz
v: height 525 start 526 end 529 total 540 clock 59.88Hz
864x486 (0x90) 32.500MHz -HSync +VSync
h: width 864 start 888 end 968 total 1072 skew 0 clock 30.32KHz
v: height 486 start 489 end 494 total 506 clock 59.92Hz
864x486 (0x91) 30.500MHz +HSync -VSync
h: width 864 start 912 end 944 total 1024 skew 0 clock 29.79KHz
v: height 486 start 489 end 494 total 500 clock 59.57Hz
700x525 (0x92) 61.000MHz +HSync +VSync DoubleScan
h: width 700 start 744 end 820 total 940 skew 0 clock 64.89KHz
v: height 525 start 526 end 532 total 541 clock 59.98Hz
800x450 (0x93) 59.125MHz -HSync +VSync DoubleScan
h: width 800 start 848 end 928 total 1056 skew 0 clock 55.99KHz
v: height 450 start 451 end 454 total 467 clock 59.95Hz
800x450 (0x94) 48.750MHz +HSync -VSync DoubleScan
h: width 800 start 824 end 840 total 880 skew 0 clock 55.40KHz
v: height 450 start 451 end 454 total 463 clock 59.82Hz
640x512 (0x95) 54.000MHz +HSync +VSync DoubleScan
h: width 640 start 664 end 720 total 844 skew 0 clock 63.98KHz
v: height 512 start 512 end 514 total 533 clock 60.02Hz
700x450 (0x96) 51.750MHz -HSync +VSync DoubleScan
h: width 700 start 740 end 812 total 924 skew 0 clock 56.01KHz
v: height 450 start 451 end 456 total 467 clock 59.96Hz
700x450 (0x97) 43.250MHz +HSync -VSync DoubleScan
h: width 700 start 724 end 740 total 780 skew 0 clock 55.45KHz
v: height 450 start 451 end 456 total 463 clock 59.88Hz
640x480 (0x98) 54.000MHz +HSync +VSync DoubleScan
h: width 640 start 688 end 744 total 900 skew 0 clock 60.00KHz
v: height 480 start 480 end 482 total 500 clock 60.00Hz
640x480 (0x99) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
720x405 (0x9a) 22.500MHz -HSync +VSync
h: width 720 start 744 end 808 total 896 skew 0 clock 25.11KHz
v: height 405 start 408 end 413 total 422 clock 59.51Hz
720x405 (0x9b) 21.750MHz +HSync -VSync
h: width 720 start 768 end 800 total 880 skew 0 clock 24.72KHz
v: height 405 start 408 end 413 total 419 clock 58.99Hz
684x384 (0x9c) 42.625MHz -HSync +VSync DoubleScan
h: width 684 start 720 end 788 total 892 skew 0 clock 47.79KHz
v: height 384 start 385 end 390 total 399 clock 59.88Hz
684x384 (0x9d) 36.125MHz +HSync -VSync DoubleScan
h: width 684 start 708 end 724 total 764 skew 0 clock 47.28KHz
v: height 384 start 385 end 390 total 395 clock 59.85Hz
640x400 (0x9e) 41.750MHz -HSync +VSync DoubleScan
h: width 640 start 676 end 740 total 840 skew 0 clock 49.70KHz
v: height 400 start 401 end 404 total 415 clock 59.88Hz
640x400 (0x9f) 35.500MHz +HSync -VSync DoubleScan
h: width 640 start 664 end 680 total 720 skew 0 clock 49.31KHz
v: height 400 start 401 end 404 total 411 clock 59.98Hz
640x360 (0xa0) 37.250MHz -HSync +VSync DoubleScan
h: width 640 start 672 end 736 total 832 skew 0 clock 44.77KHz
v: height 360 start 361 end 364 total 374 clock 59.86Hz
640x360 (0xa1) 31.875MHz +HSync -VSync DoubleScan
h: width 640 start 664 end 680 total 720 skew 0 clock 44.27KHz
v: height 360 start 361 end 364 total 370 clock 59.83Hz
640x360 (0xa2) 18.000MHz -HSync +VSync
h: width 640 start 664 end 720 total 800 skew 0 clock 22.50KHz
v: height 360 start 363 end 368 total 376 clock 59.84Hz
640x360 (0xa3) 17.750MHz +HSync -VSync
h: width 640 start 688 end 720 total 800 skew 0 clock 22.19KHz
v: height 360 start 363 end 368 total 374 clock 59.32Hz
512x384 (0xa4) 32.500MHz -HSync -VSync DoubleScan
h: width 512 start 524 end 592 total 672 skew 0 clock 48.36KHz
v: height 384 start 385 end 388 total 403 clock 60.00Hz
512x288 (0xa5) 23.250MHz -HSync +VSync DoubleScan
h: width 512 start 532 end 580 total 648 skew 0 clock 35.88KHz
v: height 288 start 289 end 292 total 299 clock 60.00Hz
512x288 (0xa6) 21.000MHz +HSync -VSync DoubleScan
h: width 512 start 536 end 552 total 592 skew 0 clock 35.47KHz
v: height 288 start 289 end 292 total 296 clock 59.92Hz
480x270 (0xa7) 20.375MHz -HSync +VSync DoubleScan
h: width 480 start 496 end 544 total 608 skew 0 clock 33.51KHz
v: height 270 start 271 end 274 total 281 clock 59.63Hz
480x270 (0xa8) 18.625MHz +HSync -VSync DoubleScan
h: width 480 start 504 end 520 total 560 skew 0 clock 33.26KHz
v: height 270 start 271 end 274 total 278 clock 59.82Hz
400x300 (0xa9) 20.000MHz +HSync +VSync DoubleScan
h: width 400 start 420 end 484 total 528 skew 0 clock 37.88KHz
v: height 300 start 300 end 302 total 314 clock 60.32Hz
400x300 (0xaa) 18.000MHz +HSync +VSync DoubleScan
h: width 400 start 412 end 448 total 512 skew 0 clock 35.16KHz
v: height 300 start 300 end 301 total 312 clock 56.34Hz
432x243 (0xab) 16.250MHz -HSync +VSync DoubleScan
h: width 432 start 444 end 484 total 536 skew 0 clock 30.32KHz
v: height 243 start 244 end 247 total 253 clock 59.92Hz
432x243 (0xac) 15.250MHz +HSync -VSync DoubleScan
h: width 432 start 456 end 472 total 512 skew 0 clock 29.79KHz
v: height 243 start 244 end 247 total 250 clock 59.57Hz
320x240 (0xad) 12.587MHz -HSync -VSync DoubleScan
h: width 320 start 328 end 376 total 400 skew 0 clock 31.47KHz
v: height 240 start 245 end 246 total 262 clock 60.05Hz
360x202 (0xae) 11.250MHz -HSync +VSync DoubleScan
h: width 360 start 372 end 404 total 448 skew 0 clock 25.11KHz
v: height 202 start 204 end 206 total 211 clock 59.51Hz
360x202 (0xaf) 10.875MHz +HSync -VSync DoubleScan
h: width 360 start 384 end 400 total 440 skew 0 clock 24.72KHz
v: height 202 start 204 end 206 total 209 clock 59.13Hz
320x180 (0xb0) 9.000MHz -HSync +VSync DoubleScan
h: width 320 start 332 end 360 total 400 skew 0 clock 22.50KHz
v: height 180 start 181 end 184 total 188 clock 59.84Hz
320x180 (0xb1) 8.875MHz +HSync -VSync DoubleScan
h: width 320 start 344 end 360 total 400 skew 0 clock 22.19KHz
v: height 180 start 181 end 184 total 187 clock 59.32Hz
DP-1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x42
Timestamp: 3139568
Subpixel: unknown
Clones: HDMI-1
CRTCs: 1 0 2
filter:
HDCP Content Type: HDCP Type0
supported: HDCP Type0, HDCP Type1
Content Protection: Undesired
supported: Undesired, Desired, Enabled
Colorspace: Default
max bpc: 12
range: (6, 12)
audio: auto
supported: force-dvi, off, auto, on
subconnector: Unknown
supported: Unknown, VGA, DVI-D, HDMI, DP, Wireless, Native
link-status: Good
0 1
CONNECTOR_ID: 103
supported: 103
non-desktop: 0
range: (0, 1)
HDMI-1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x43
Timestamp: 3139568
Subpixel: unknown
Clones: DP-1
CRTCs: 1 0 2
filter:
max bpc: 12
range: (8, 12)
content type: No Data
supported: No Data, Graphics, Photo, Cinema, Game
Colorspace: Default
supported: Default, SMPTE_170M_YCC, BT709_YCC, XVYCC_601, XVYCC_709, SYCC_601, opYCC_601, opRGB, BT2020_CYCC, BT2020_RGB, BT2020_YCC, DCI-P3_RGB_D65, DCI-P3_RGB_Theater
aspect ratio: Automatic
supported: Automatic, 4:3, 16:9
audio: auto
link-status: Good
0 1
CONNECTOR_ID: 113
supported: 113
non-desktop: 0
range: (0, 1)
DP-2 connected primary 640x480+0+0 (0x99) normal (normal left inverted right x axis y axis) 0mm x 0mm
Identifier: 0x44
Timestamp: 3139568
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 1 0 2
filter:
Colorspace: Default
max bpc: 12
range: (6, 12)
audio: auto
subconnector: HDMI
link-status: Good
0 1
CONNECTOR_ID: 119
supported: 119
non-desktop: 0
range: (0, 1)
640x480 (0x99) 25.175MHz -HSync -VSync *current +preferred
848x480 (0xb2) 33.750MHz +HSync +VSync
h: width 848 start 864 end 976 total 1088 skew 0 clock 31.02KHz
v: height 480 start 486 end 494 total 517 clock 60.00Hz
DP-3 disconnected (normal left inverted right x axis y axis)
Identifier: 0x45
Timestamp: 3139568
Subpixel: unknown
Clones:
CRTCs: 1 0 2
filter:
Colorspace: Default
max bpc: 12
range: (6, 12)
audio: auto
link-status: Good
0 1
CONNECTOR_ID: 126
supported: 126
non-desktop: 0
range: (0, 1)
HDMI-2 disconnected (normal left inverted right x axis y axis)
Identifier: 0x46
Timestamp: 3139568
Subpixel: unknown
Clones:
CRTCs: 1 0 2
filter:
max bpc: 12
range: (8, 12)
Colorspace: Default
audio: auto
link-status: Good
0 1
CONNECTOR_ID: 132
supported: 132
non-desktop: 0
range: (0, 1)
