[dude@dude-80sm Desktop]$ burpsuite
Error: A JNI error has occurred, please check your installation and try again
Exception in thread “main” java.lang.UnsupportedClassVersionError: burp/StartBurp has been compiled by a more recent version of the Java Runtime (class file version 53.0), this version of the Java Runtime only recognizes class file versions up to 52.0
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:763)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:467)
at java.net.URLClassLoader.access$100(URLClassLoader.java:73)
at java.net.URLClassLoader$1.run(URLClassLoader.java:368)
at java.net.URLClassLoader$1.run(URLClassLoader.java:362)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:361)
at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:331)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at sun.launcher.LauncherHelper.checkAndLoadMain(LauncherHelper.java:495)
update your java
how to update?? bro
thanks mate
according to this file supports 52.0 right and I use 53.0 so I need to downgrade???
You need to check which version you are running
archlinux-java status
Then install a more recent version e.g. the latest which is jdk16
[dude@dude-80sm ~]$ archlinux-java status
Available Java environments:
java-16-openjdk
java-8-openjdk (default)
sudo archlinux-java set java-16-openjdk
i did this but problem is same
Then switch the active envionment to jdk16
If that is too new - can also happen - then install jdk 11 and set this as the default.
If none of it helps - contact the developer.
yeah i did that but still problem is same
oka bro
