Hi all,
a friend gave me his iMac 24’’ from 2007.
I upgraded the machine from its original specs (https://everymac.com/systems/apple/imac/specs/imac-core-2-duo-2.4-24-inch-aluminum-specs.html
) to 4GB RAM and a 250GB SSD, thoroughly cleaned the insides and replaced the thermal paste on CPU and GPU.
In short, it will never be an extremely snappy system but should completely suffice for office work, multimedia etc.
As its video card is not supported in recent kernels, I everything in cli until now. Booting any distro into the GUI results in funny geometric patterns on the screen, so cli it is for the installation.
The iMac has a 32bit UEFI but a 64bit CPU, which might be part of my problem.
Contrary to the description in the [HowTo] Installation of Manjaro on 32Bit EFI , 64Bit CPU Systems (https://forum.manjaro.org/t/howto-installation-of-manjaro-on-32bit-efi-64bit-cpu-systems/93848
), I didn’t encounter any problems in booting the recent manjaro image manjaro-xfce-23.0.4-minimal-231015-linux65.iso that I dd’d on a stick.
So, I booted the live system and then followed [root tip] [How To] Do a manual Manjaro installation (https://forum.manjaro.org/t/root-tip-how-to-do-a-manual-manjaro-installation/12507
) to the dot up to point 8. Bootloader (https://forum.manjaro.org/t/root-tip-how-to-do-a-manual-manjaro-installation/12507#h-8-bootloader-31
Here, I failed to install the 64bit grub due to the iMac’s EFI being 32bit. Instead, I followed this guide (https://ubuntuforums.org/showthread.php?t=2287767
) and ran
grub-install --target=i386-efi --boot-directory=/boot --efi-directory=/boot/efi --bootloader-id=Manjaro
update-grub
which finished without errors.
Now, when I unplug the boot stick and restart the computer, it does not boot into grub. Instead, I see a folder symbol with a question mark (https://support.apple.com/en-us/102601
). A reset of the NVRAM (https://support.apple.com/en-gb/HT204063
) didn’t change that.
When I turn off the computer, insert the Manjaro bootstick and press ALT on my windows keyboard, I can select the boot stick via the “EFI boot” symbol that appears, then select “Detect EFI bootloaders” in the following menu and can then choose between four bootloaders:
- (hd1,gpt1)/efi/Manjaro/grubx64.efi
- (hd1,gpt1)/efi/Manjaro/grub.efi
- (hd1,gpt1)/efi/Manjaro/grubia32.efi (which I put there due to 4. Placed the bootia32.efi in the /EFI/BOOT folder on the Ubuntu Server installer USB stick. (
- (hd1,gpt1)/efi/efi/Manjaro/grubx64.efi
Options 1. and 4. lead me to a cli login of the local Manjaro installation, 2. & 3. are not able to boot.
So far so good, but I don’t want to have to use a USB drive to kickstart grub.
This is the partitioning:
lsblk -f
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
sda
├─sda1 vfat FAT32 CC90-E8F2 498,3M 0% /boot/efi
├─sda2 swap 1 6addd690-8c0c-4be0-8026-b3092ef03369 [SWAP]
├─sda3 ext4 1.0 e239e8fc-c0a6-4f18-9306-6e4c0be10e83 91,1G 2% /
└─sda4 ext4 1.0 4dea75b2-d20d-4ddd-a9ff-0fa2d404e6b5 110,7G 0% /home
sr0
How do I make loading first grub and then bootloader 1 permanent and without the aid of an extra USB drive?
Sorry for the long text but I thought this might be able to help folks who might run into similar problems.
Thank you very much in advance,
DarthBongo
