I recently found out about mangohud and wanted to try and get it to display on cyberpunk 2077 while I play it on Steam with Proton, but the usual command that I’m finding online doesn’t seem to be working.
I’m inputting into the Properties Launch Options field
MANGOHUD=1 %command%
I have also tried mangohud=1 %command% and also mangohud %command%
None of these seem to work, the game won’t even launch with these commands inputted.
Any insight or help regarding this would be greatly appreciated! Thanks in advance Manjaro community!
Thanks for the response! I only installed mangohud as I was unaware of the mangohud-common and lib32-mangohud packages. I’ll install those when I get home, but I don’t have a command set up to run cyberpunk specifically, as I usually access it through Steam’s GUI, thusly I was trying to put the aforementioned commands into their Launcher Command section. It worked for preventing the game launcher window from popping up (I was having issues with that launcher window just being a black window…) but this command isn’t working for some reason.
I’ll install those other packages when I get home (at work ATM) and try it out. Again, thank you!
Awesome, just got home and got mangohud working. Took a bit to figure out how to set it up so it displayed temps as well, and apparently the order to tell it not to call the initial launcher window was important to. I did a little bit of customization, here’s what I have so far:
I know it’s a bit off the original topic, @XRaTiX but I was wondering if you could tell me how to get it to not display the default graph and cpu/gpu usage %, I literally just want it to display the temps and the fps (and maybe change the color of the displayed text, but I’ll play with that on my own).
I know mangohud has some good documentation on their github, but if you could just tell me how to get the graph and the usage percentages to disappear I would be ever the more grateful.
I think there is no way to only display temps,you need to have cpu/gpu usage as well.
You can use goverlay-bin from the AUR,is a graphical way to manage Mangohud as well other tools,I was playing around and I think this is the setup you want
