Getting lockups of plasmashell
Plasma 5 was solid. I have had lockups of plasmashell ever since the move to plasma6. I even reset my kde and reconfigured. At first I though it was the plasmoids i was running. (system monitor sensor). However I have been running a couple of weeks without plasmoids and it still happens. I have tried killing composting and restarting composting. about half of the time i can successfully kill and restart plasmashell using yakuake. But this is getting annoying. Everything else seems stable (kernel 6.12 notwithstanding). Any ideas what is going on? logs are just not helpful. Or at least point me to a direction. I have searched the forums and cannot find anything that applies to plasma6.
Reset all configurations - as weird things can happen if settings survive between 5 and 6.
See the script at Applications / Manjaro Plasma Reset · GitLab
Look at your theming configuration not only if you use custom theme.
Go over the packages installed and remove everything relating to plasma and qt5 e.g. packages starting with k ending with 5 or ending with qt5
I had a hard time getting a long overdue laptop up-to-date from plasma5 to plasma6.
I think you mean compositing, rather than composting (:face_with_hand_over_mouth:), but this either way suggests that you’re still using X11, because compositing cannot be disabled in Wayland.
I would therefore recommend that you try Wayland instead, because that’s what the focus of Plasma 6’s development is on. You can select the Wayland session at the login screen — usually at the bottom left.
Another thing to keep in mind is that global themes for Plasma 5 may be incompatible with Plasma 6 and may lead to all sorts of stability issues.
oh… i forgot to say that… i did exactly that and went back to default. no change. but nothing in my logs to point me in the right direction.
i tried wayland and there are things i need that still are not available in wayland. When i was testing, i still had lockups with plasmashell. Also, i removed all plasma5 themes and even reset plasma config. It seems random. I can go days without an issue and 3 times in a day. I really dont want to move from plasma but if this keeps up, then i may have to. I even considered doing a clean install. But all the customization i have done in Manjaro would have to be found and redone. This kind of reminds me of kde4 and early plasma5 days.
Such as?
transparency, global shortcuts (prob the biggest issue). citrix behaves oddly in wayland. i am not going to say screensavers… but screensavers. I had some problems with some games. Although i havent tried with the latest proton. konsole started crashing on me at random times. Mysterious slowdowns at random times that i dont see in X11. There are others, but you get the idea. I use my pc for work and play and wayland just isnt there yet for me.
thanks! ill give this a shot.
When last have you tried it?
I also still use X, but that’s only 'til the Nvidia experience is at least bearable. Of all those things you’ve mentioned, I have never seen a problem with in Wayland, and there’s always XWayland of you need X that badly.
About 3 weeks ago. I just need my pc to work.
With Wayland, compositing is always enabled, but transparency depends on the chosen theme, even when running on X11. Not all themes support transparency on everything, or even at all.
They are all still available, but the section of System Settings where you configure them is not the same as it used to be due to the replacement of khotkeys by the kglobalaccel framework.
The default kscreenlocker supports slideshows and screensaver plugins. Plasma 6.x even allows the use of a screensaver without locking the screen.
If you have to use proton then those are actually Windows games, and for all intents and purposes, that’s alien software, so it’s not fair to expect that those would work seamlessly.
Blockquote
in x11, i can make any window transparent by just mouse wheel on titile bar. that setting doesnt work in wayland.
Blockquote
I know nothing aobut kglobalaccel.
Blockquote
Yea i tried that, and locked it up so hard that i had to kill my session. I couldn’t open the settings anymore until i went back into X11 and changed it.
Blockquote
With all due respect, I dont give a crap. It is what a bunch of people use Linux for now. It isnt just a developer os anymore. SteamOS is based on Arch. That is elitist BS. You may not be a gamer, but a ton of people that run Manjaro and Arch are. I feel like I am beating a dead horse here, but Linux is no longer just IT and hobbist OS. It is a serious os that you can really game on. it was bad enough to shove systemd down our throats, but now everyone is praising wayland and it is STILL not a replacement for X11.
Yes it does - I use that feature all the time:
System Settings → Window Management → Window Behavior → Titlebar Actions → Mouse Wheel → Change Opacity
I’ve had zero issues using a slideshow as my lock screen background. Again, it can easily be set up in via the GUI: System Settings → Security & Privacy → Screen Locking → Configure Appearance. You may also have to adjust your sleep settings in Power Management.
If Wayland was not a good replacement for X11, then I’m sure that by now, almost a year after Plasma switched to Wayland as default, the pro-X11 voices would be drowning out the pro-Wayland voices. But that hasn’t happened. The vast majority of users seem to very happy with the switch.
ok… you talked me into trying wayland again. And global shortcuts are working now. Citrix is not wigging out. There was a big patch day last week (?) and i guess these bugs were addressed. I did get a lock up with the screen locker but i was able to get it fixed. I did have a bug with the panels… one was stuck in the middle of the screen. I will try to stay on wayland and see if i can. I did grab that script and will use that if this doesnt work. I did play fallout 76 last night and it seemed to be working fine.
I’m surprised nobody has yet asked for system information. This will help us rule out a number of contributing possibilities;
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Be prepared to provide more information and outputs from other commands whenever asked.
~ $ sudo inxi -zv8
  Kernel: 6.13.1-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    clocksource: tsc avail: hpet,acpi_pm parameters: zfs=nvmepool/manjaro/root
    rw ipv6.disable=1 mitigations=off acpi_osi=Linux amdgpu.gpu_recovery=1
    nowatchdog amdgpu.lockup_timeout=0 amdgpu.ppfeaturemask=0xffffffff quiet
    udev.log_priority=3 nowqatchdog zswap.enabled=0 quiet
    spl.spl_hostid=0x007f0101
  Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A wm: kwin_wayland tools:
    avail: xautolock,xscreensaver dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Desktop System: ASUS product: N/A v: N/A serial: N/A
  Mobo: ASUSTeK model: ROG CROSSHAIR VIII HERO (WI-FI) v: Rev X.0x
    serial: <filter> part-nu: SKU uuid: 4b043afe-5dd4-5664-b0cd-d45d6456b0d0
    UEFI: American Megatrends v: 4702 date: 10/20/2023
  System RAM: total: 64 GiB available: 62.7 GiB used: 38.15 GiB (60.8%)
  Device-1: DIMM_A1 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 16 GiB speed: 3200 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
    width (bits): data: 64 total: 64 manufacturer: Crucial Technology
    part-no: BL16G36C16U4RL.M8FB1 serial: <filter>
  Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
  Device-3: DIMM_B1 type: DDR4 detail: synchronous unbuffered (unregistered)
  Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
  Slot: 0 type: PCIe status: in use length: long volts: 3.3 bus-ID: 00:03.1
    children: 1: 08:00.0 class-ID: 0604 type: bridge children: 1: 09:00.0
    class-ID: 0604 type: bridge children: 1: 0a:00.0 class-ID: 0300
    type: display 2: 0a:00.1 class-ID: 0403 type: audio
  Slot: 1 type: PCIe status: in use length: long volts: 3.3 bus-ID: 00:03.2
    children: 1: 0b:00.0 class-ID: 0200 type: network
  Slot: 2 type: PCIe status: available length: short volts: 3.3
    bus-ID: 00:1f.7
  Slot: 3 type: PCIe status: available length: short volts: 3.3
    bus-ID: 00:1f.7
  Info: model: AMD Ryzen 9 5950X socket: AM4 bits: 64 type: MT MCP
    arch: Zen 3+ gen: 3 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
    family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA20102B
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 16 threads: 32 tpc: 2
    smt: enabled cache: L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB
    desc: 16x512 KiB L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 3779 min/max: 550/5084 boost: enabled
    base/boost: 3400/5050 scaling: driver: amd-pstate-epp governor: powersave
    volts: 1.1 V ext-clock: 100 MHz cores: 1: 3779 2: 3779 3: 3779 4: 3779
    5: 3779 6: 3779 7: 3779 8: 3779 9: 3779 10: 3779 11: 3779 12: 3779
    13: 3779 14: 3779 15: 3779 16: 3779 17: 3779 18: 3779 19: 3779 20: 3779
    21: 3779 22: 3779 23: 3779 24: 3779 25: 3779 26: 3779 27: 3779 28: 3779
    29: 3779 30: 3779 31: 3779 32: 3779 bogomips: 217727
    xsaves xtopology
  Type: spec_rstack_overflow status: Vulnerable
  Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
    usercopy barriers only; no swapgs barriers
  Type: spectre_v2 status: Vulnerable; IBPB: disabled; STIBP: disabled;
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 [Radeon RX 5600 OEM/5600
    XT / 5700/5700 XT] vendor: Tul / PowerColor driver: amdgpu v: kernel
    arch: RDNA-1 code: Navi-1x process: TSMC n7 (7nm) built: 2019-20 pcie:
    gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1
    empty: DP-2,DP-3,HDMI-A-1 bus-ID: 0a:00.0 chip-ID: 1002:731f
    class-ID: 0300
  Device-2: Logitech HD Webcam C525 driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.4:4
    chip-ID: 046d:0826 class-ID: 0e02 serial: <filter>
  Display: unspecified server: X.Org v: 24.1.5 with: Xwayland v: 24.1.5
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: :1 screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
    s-diag: 777mm (30.58")
  Monitor-1: DP-1 model: LG (GoldStar) ULTRAGEAR serial: <filter>
    built: 2021 res: mode: 2560x1440 hz: 165 scale: 100% (1) dpi: 93 gamma: 1.2
    chroma: red: x: 0.686 y: 0.310 green: x: 0.263 y: 0.671 blue: x: 0.149
    y: 0.055 white: x: 0.314 y: 0.329 size: 697x392mm (27.44x15.43")
    diag: 800mm (31.5") ratio: 16:9 modes: 2560x1440, 1920x1200, 1920x1080,
    1600x1200, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720, 1024x768,
    800x600, 720x480, 640x480
  EDID-Warnings: 1: parse_edid: unknown tag 112
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 5700 XT 50th
    Anniversary (radeonsi navi10 LLVM 19.1.7 DRM 3.59 6.13.1-2-MANJARO)
    device-ID: 1002:731f memory: 7.81 GiB unified: no
  API: Vulkan v: 1.4.303 layers: 1 device: 0 type: discrete-gpu name: AMD
    Radeon RX 5700 XT 50th Anniversary (RADV NAVI10) driver: N/A
    device-ID: 1002:731f surfaces: xcb,xlib
    de: kscreen-console,kscreen-doctor gpu: corectrl,radeontop wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio
    bus-ID: 0a:00.1 chip-ID: 1002:ab38 class-ID: 0403
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Logitech HD Webcam C525 driver: snd-usb-audio,uvcvideo type: USB
  API: ALSA v: k6.13.1-2-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.2.7 status: n/a (root, process)
    with: pipewire-media-session status: active tools: pw-cli
  Server-4: PulseAudio v: 17.0-43-g3e2bb status: active (root, process)
    with: 1: pulseaudio-alsa type: plugin 2: pulseaudio-jack type: module
    tools: pacat,pactl
  Device-1: Mellanox MT27500 Family [ConnectX-3] driver: mlx4_core v: 4.0-0
    pcie: gen: 3 speed: 8 GT/s lanes: 4 port: N/A bus-ID: 0b:00.0
    chip-ID: 15b3:1003 class-ID: 0200
  IF: enp11s0 state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
  IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
  Info: services: NetworkManager, sshd, systemd-timesyncd
  Device-1: gamepool type: zfs status: ONLINE level: linear raw:
    size: 10.8 TiB free: 3.98 TiB allocated: 6.8 TiB zfs-fs: size: 10.66 TiB
    free: 3.86 TiB
  Components: Online:
  1: sdb1 maj-min: 8:17 size: 3.61 TiB
  2: sdc1 maj-min: 8:33 size: 3.61 TiB
  3: sdd1 maj-min: 8:49 size: 3.61 TiB
  Device-2: miscpool type: zfs status: ONLINE level: linear raw:
    size: 16.4 TiB free: 10.3 TiB allocated: 6.01 TiB zfs-fs: size: 16.23 TiB
    free: 10.22 TiB
  Components: Online:
  1: sde maj-min: 8:64 size: 16.37 TiB
  Device-3: nvmepool type: zfs status: ONLINE level: linear raw:
    size: 3.66 TiB free: 1.15 TiB allocated: 2.51 TiB zfs-fs: size: 3.54 TiB
    free: 1.03 TiB
  Components: Online:
  1: nvme0n1p2 maj-min: 259:3 size: 1.83 TiB
  2: nvme1n1p2 maj-min: 259:6 size: 1.83 TiB
  Device-4: vmpool type: zfs status: ONLINE level: linear raw:
    size: 1.78 TiB free: 1.34 TiB allocated: 449 GiB zfs-fs: size: 1.73 TiB
    free: 1.29 TiB
  Components: Online:
  1: sda1 maj-min: 8:1 size: 1.79 TiB
  Local Storage: total: raw: 32.83 TiB usable: 32.36 TiB
    used: 15.71 TiB (48.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
    size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 42AZS6AC temp: 39.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 3y 94d 23h cycles: 2,209
    read-units: 153,476,028 [78.5 TB] written-units: 66,044,411 [33.8 TB]
  ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: A-Data model: SX8200PNP
    lanes: 4 tech: SSD serial: <filter> fw-rev: 42AZS6AC temp: 38.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 3y 91d 22h cycles: 2,245
    read-units: 355,661,423 [182 TB] written-units: 396,385,259 [202 TB]
  ID-3: /dev/sda maj-min: 8:0 vendor: Crucial model: CT2000MX500SSD1
    family: Micron Client SSDs size: 1.82 TiB block-size: physical: 4096 B
    logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 023 temp: 40 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 4y 17d 0h cycles: 2568
    written: 31.64 TiB
  ID-4: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT4000MX500SSD1
    family: Micron Client SSDs size: 3.64 TiB block-size: physical: 4096 B
    fw-rev: 046 temp: 30 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 338d 17h cycles: 630
    written: 24.65 TiB
  ID-5: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT4000MX500SSD1
    fw-rev: 046 temp: 31 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 342d 16h cycles: 635
    written: 26.02 TiB
  ID-6: /dev/sdd maj-min: 8:48 vendor: Crucial model: CT4000MX500SSD1
    fw-rev: 046 temp: 37 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 341d 9h cycles: 635
    written: 25.21 TiB
  ID-7: /dev/sde maj-min: 8:64 vendor: Western Digital
    model: WD181KRYZ-01AGBB0 family: Gold size: 16.37 TiB block-size:
    physical: 4096 B logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: HDD
    rpm: 7200 serial: <filter> fw-rev: 1H01 temp: 48 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 2y 31d 9h cycles: 1465
  ID-1: / raw-size: N/A size: 1.21 TiB used: 177.91 GiB (14.4%) fs: zfs
    logical: nvmepool/manjaro/root
    used: 217.8 MiB (72.8%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:2 label: EFI uuid: 0A81-8C64
  ID-3: /home raw-size: N/A size: 1.84 TiB used: 828.74 GiB (43.9%) fs: zfs
    logical: nvmepool/manjaro/home
  ID-4: /mnt/abyss/archives raw-size: N/A size: 14.01 TiB
    used: 1.47 TiB (10.5%) fs: nfs remote: 10.0.10.10:/export/archives
  ID-5: /mnt/abyss/audio raw-size: N/A size: 12.88 TiB
    used: 340.97 GiB (2.6%) fs: nfs remote: 10.0.10.10:/export/audio
  ID-6: /mnt/abyss/documents raw-size: N/A size: 12.65 TiB
    used: 105.91 GiB (0.8%) fs: nfs remote: 10.0.10.10:/export/documents
  ID-7: /mnt/abyss/erotica raw-size: N/A size: 25.23 TiB
    used: 12.69 TiB (50.3%) fs: nfs remote: 10.0.10.10:/export/erotica
  ID-8: /mnt/abyss/games raw-size: N/A size: 13.72 TiB used: 1.18 TiB (8.6%)
    fs: nfs remote: 10.0.10.10:/export/games
  ID-9: /mnt/abyss/homedirs raw-size: N/A size: 12.54 TiB used: 3 MiB (0.0%)
    fs: nfs remote: 10.0.10.10:/export/homedirs
  ID-10: /mnt/abyss/homestuff raw-size: N/A size: 15.15 TiB
    used: 2.61 TiB (17.2%) fs: nfs remote: 10.0.10.10:/export/homestuff
  ID-11: /mnt/abyss/isos raw-size: N/A size: 13.1 TiB
    used: 572.18 GiB (4.3%) fs: nfs remote: 10.0.10.10:/export/isos
  ID-12: /mnt/abyss/software raw-size: N/A size: 18.15 TiB
    used: 5.61 TiB (30.9%) fs: nfs remote: 10.0.10.10:/export/software
  ID-13: /mnt/abyss/videos raw-size: N/A size: 30.74 TiB
    used: 18.2 TiB (59.2%) fs: nfs remote: 10.0.10.10:/export/Videos
  ID-14: /mnt/backups raw-size: N/A size: 21.02 TiB used: 16.25 TiB (77.3%)
    fs: nfs remote: 10.0.10.20:/export/borgbackups
  ID-15: /mnt/cloud raw-size: N/A size: 10.23 TiB used: 5.77 GiB (0.1%)
    fs: zfs logical: miscpool/cloud
  ID-16: /mnt/eyecandy raw-size: N/A size: 13 TiB used: 2.77 TiB (21.3%)
    fs: zfs logical: miscpool/eyecandy
  ID-17: /mnt/games raw-size: N/A size: 5.78 TiB used: 1.92 TiB (33.3%)
    fs: zfs logical: gamepool/games
  ID-18: /mnt/games/steam/nvme raw-size: N/A size: 2.51 TiB
    used: 1.48 TiB (58.9%) fs: zfs logical: nvmepool/manjaro/steam
  ID-19: /mnt/games/steam/ssd raw-size: N/A size: 8.73 TiB
    used: 4.88 TiB (55.8%) fs: zfs logical: gamepool/steam
  ID-20: /mnt/master raw-size: N/A size: 13.12 TiB used: 2.9 TiB (22.1%)
    fs: zfs logical: miscpool/master
  ID-21: /mnt/master/audio raw-size: N/A size: 10.56 TiB
    used: 346.02 GiB (3.2%) fs: zfs logical: miscpool/audio
  ID-22: /mnt/misc raw-size: N/A size: 10.22 TiB used: 128 KiB (0.0%)
    fs: zfs logical: miscpool/misc
  ID-23: /mnt/vm raw-size: N/A size: 1.73 TiB used: 448.99 GiB (25.4%)
    fs: zfs logical: vmpool/vm
  Kernel: swappiness: 180 (default 60) cache-pressure: 100 (default) zswap: no
  ID-1: swap-1 type: zram size: 31.35 GiB used: 2.22 GiB (7.1%)
    priority: 100 comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842
    max-streams: 32 dev: /dev/zram0
  ID-1: /dev/nvme0n1p3 maj-min: 259:4 size: 29.3 GiB fs: N/A label: N/A
    uuid: N/A
  ID-2: /dev/nvme1n1p1 maj-min: 259:5 size: 2.93 GiB fs: N/A label: N/A
    uuid: N/A
  ID-3: /dev/nvme1n1p3 maj-min: 259:7 size: 29.3 GiB fs: N/A label: N/A
    uuid: N/A
  ID-4: /dev/sda2 maj-min: 8:2 size: 34.18 GiB fs: N/A label: N/A uuid: N/A
  ID-5: /dev/sdb2 maj-min: 8:18 size: 34.18 GiB fs: N/A label: N/A uuid: N/A
  ID-6: /dev/sdc2 maj-min: 8:34 size: 34.18 GiB fs: N/A label: N/A uuid: N/A
  ID-7: /dev/sdd2 maj-min: 8:50 size: 34.18 GiB fs: N/A label: N/A uuid: N/A
  Hub-2: 1-5:2 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-5.2:3 info: Areson Corp 2.4G Wireless Receiver
    type: mouse,keyboard driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 25a7:fa7c class-ID: 0301
  Device-2: 1-5.3:4 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:18f3 class-ID: 0300
    serial: <filter>
  Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
  Hub-5: 3-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
    chip-ID: 174c:2074 class-ID: 0900
  Device-1: 3-2.1:3 info: Keychron Q3 type: keyboard,HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 3434:0120 class-ID: 0300
  Device-2: 3-2.4:4 info: Logitech HD Webcam C525 type: audio,video
  Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-7: 4-2:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
    chip-ID: 174c:3074 class-ID: 0900
  Hub-8: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-9: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 75.0 C mobo: 39.0 C gpu: amdgpu temp: 37.0 C
    mem: 40.0 C
  Fan Speeds (rpm): cpu: 0 fan-1: 0 fan-2: 0 fan-3: 903 fan-4: 0 fan-5: 0
    fan-6: 816 fan-7: 826 gpu: amdgpu fan: 65535
  Packages: 3454 pm: dpkg pkgs: 0 pm: pacman pkgs: 3361 libs: 662
    tools: pamac,yay pm: appimage pkgs: 0 pm: flatpak pkgs: 93
    1: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    5: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 1348
  1: cpu: 17.4% command: pcloud pid: 410647 mem: 190.7 MiB (0.2%)
  2: cpu: 17.2% command: brave pid: 363326 mem: 551.8 MiB (0.8%)
  3: cpu: 14.0% command: brave pid: 205367 mem: 330.4 MiB (0.5%)
  4: cpu: 11.7% command: brave pid: 396663 mem: 258.6 MiB (0.4%)
  5: cpu: 11.5% command: C:\Program pid: 411088 mem: 89.3 MiB (0.1%)
  Memory top: 5 of 1348
  1: mem: 792.6 MiB (1.2%) command: brave pid: 374183 cpu: 7.7%
  2: mem: 755.8 MiB (1.1%) command: teams-for-linux pid: 361325 cpu: 2.9%
  3: mem: 687.2 MiB (1.0%) command: outlook-for-linux pid: 361147 cpu: 1.4%
  4: mem: 589.5 MiB (0.9%) command: plasmashell pid: 203843 cpu: 2.2%
  5: mem: 551.8 MiB (0.8%) command: brave pid: 363326 cpu: 17.2%
  Processes: 1348 Power: uptime: 18h 15m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 25.07 GiB services: org_kde_powerdevil,upowerd
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Sudo (sudo) v: 1.9.16p2
    default: Bash v: 5.2.37 running-in: yakuake inxi: 3.3.37
i had to go back to X11… i was having hardlocks with wayland.
kwin_wayland_drm: Pageflip timed out! This is a kernel bug
You might consider switching to kernel 6.12 (LTS).
I’m personally using 6.12 with Wayland (and AMD graphics) – this combination has proven more than stable for me.
i was having mce errors with 6.12. 6.11 was stable but no longer avail. although … i didnt try 6.12 with wayland
Let us know how this combination works for you.
