/etc/default/grub
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor resume=UUID=19a7c527-96f1-4795-b9b7-04924492d2c8 udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
GRUB_CMDLINE_LINUX_DEFAULT="quiet acpi_backlight=vendor pci=noaer"
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
GRUB_DISABLE_OS_PROBER=false
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
/etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=2658-2BAF /boot/efi vfat umask=0077 0 2
UUID=19a7c527-96f1-4795-b9b7-04924492d2c8 swap swap defaults,noatime 0 0
UUID=1c116981-add3-4dd5-814b-0a77994a4b19 / ext4 defaults,noatime 0 1
UUID=b92a2932-930e-4e00-b390-95789841b34e /home ext4 defaults,noatime 0 2
UUID=c4f9d3cb-e857-4cc5-882d-2973f0697a67 /mnt/Storage ext4 defaults,noatime 0 3
Welcome Tanya to the forum,
Can you tell me the error which you are getting while booting and the output of free -h and what do you mean by you cannot use hibernate!
free -h
total used free shared buff/cache available
Mem: 5.8Gi 1.6Gi 2.8Gi 201Mi 1.4Gi 3.7Gi
Swap: 11Gi 0B 11Gi
I can’t hibernate means my laptop stops working if I try to hibernate. Even REISUB doesn’t work.
The error is: ERROR: resume: no device specified for hibernation
/etc/default/grub
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor resume=UUID=19a7c527-96f1-4795-b9b7-04924492d2c8 udev.log_priority=3 acpi_backlight=vendor pci=noaer"
GRUB_GFXMODE=auto
The error message is now gone but hibernation is still failing. Here’s some output that I think might be useful:
journalctl --system --boot=-1 --priority=3 | tail --lines=50
-- Journal begins at Thu 2021-07-29 17:04:01 IST, ends at Sat 2021-08-07 20:16:10 IST. --
Aug 07 20:12:33 tanaya-laptop kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP2.BCM5], AE_NOT_FOUND (20200925/dswload2-162)
Aug 07 20:12:33 tanaya-laptop kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20200925/psobject-220)
Aug 07 20:12:33 tanaya-laptop kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP1.DEV0], AE_NOT_FOUND (20200925/dswload2-162)
Aug 07 20:12:33 tanaya-laptop kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.WLBU._STA.WLVD], AE_NOT_FOUND (20200925/psargs-330)
Aug 07 20:12:33 tanaya-laptop kernel: ACPI Error: Aborting method \_SB.WLBU._STA due to previous error (AE_NOT_FOUND) (20200925/psparse-529)
Aug 07 20:12:33 tanaya-laptop kernel: snd_pci_acp3x 0000:04:00.5: Invalid ACP audio mode : 1
Aug 07 20:12:34 tanaya-laptop kernel: kvm: disabled by bios
Aug 07 20:12:34 tanaya-laptop NetworkManager[344]: <error> [1628347354.6372] connectivity: invalid URI '8.8.8.8' for connectivity check.
Aug 07 20:12:37 tanaya-laptop kernel: ACPI Error: No handler for Region [RCM0] (000000003d63898f) [SystemCMOS] (20200925/evregion-129)
Aug 07 20:12:37 tanaya-laptop kernel: ACPI Error: Region SystemCMOS (ID=5) has no handler (20200925/exfldio-261)
Aug 07 20:12:37 tanaya-laptop kernel: ACPI Error: Aborting method \_SB.WMID.ESDT due to previous error (AE_NOT_EXIST) (20200925/psparse-529)
Aug 07 20:12:37 tanaya-laptop kernel: ACPI Error: Aborting method \_SB.PCI0.LPC0.EC0._Q42 due to previous error (AE_NOT_EXIST) (20200925/psparse-529)
Aug 07 20:12:45 tanaya-laptop wpa_supplicant[569]: bgscan simple: Failed to enable signal strength monitoring
Aug 07 20:15:05 tanaya-laptop kernel: rtl8821ce 0000:02:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000b address=0xffe66800 flags=0x0000]
Aug 07 20:15:05 tanaya-laptop kernel: rtl8821ce 0000:02:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000b address=0xffe66830 flags=0x0000]
Aug 07 20:15:24 tanaya-laptop kernel: watchdog: watchdog0: watchdog did not stop!
I ran it just after rebooting from a failed hibernation.
I made the change, but hibernate still isn’t working. I’m getting the same error. Here’s my /etc/mkinitcpio.conf :
# vim:set ft=sh
# MODULES
# The following modules are loaded before any boot hooks are
# run. Advanced users may wish to specify all system modules
# in this array. For instance:
# MODULES=(piix ide_disk reiserfs)
MODULES=""
# BINARIES
# This setting includes any additional binaries a given user may
# wish into the CPIO image. This is run last, so it may be used to
# override the actual binaries included by a given hook
# BINARIES are dependency parsed, so you may safely ignore libraries
BINARIES=()
# FILES
# This setting is similar to BINARIES above, however, files are added
# as-is and are not parsed in any way. This is useful for config files.
FILES=""
# HOOKS
# This is the most important setting in this file. The HOOKS control the
# modules and scripts added to the image, and what happens at boot time.
# Order is important, and it is recommended that you do not change the
# order in which HOOKS are added. Run 'mkinitcpio -H <hook name>' for
# help on a given hook.
# 'base' is _required_ unless you know precisely what you are doing.
# 'udev' is _required_ in order to automatically load modules
# 'filesystems' is _required_ unless you specify your fs modules in MODULES
# Examples:
## This setup specifies all modules in the MODULES setting above.
## No raid, lvm2, or encrypted root is needed.
# HOOKS=(base)
## This setup will autodetect all modules for your system and should
## work as a sane default
# HOOKS=(base udev autodetect block filesystems)
## This setup will generate a 'full' image which supports most systems.
## No autodetection is done.
# HOOKS=(base udev block filesystems)
## This setup assembles a pata mdadm array with an encrypted root FS.
## Note: See 'mkinitcpio -H mdadm' for more information on raid devices.
# HOOKS=(base udev block mdadm encrypt filesystems)
## This setup loads an lvm2 volume group on a usb device.
# HOOKS=(base udev block lvm2 filesystems)
## NOTE: If you have /usr on a separate partition, you MUST include the
# usr, fsck and shutdown hooks.
HOOKS="base udev resume autodetect modconf block keyboard keymap filesystems fsck"
# COMPRESSION
# Use this to compress the initramfs image. By default, gzip compression
# is used. Use 'cat' to create an uncompressed image.
#COMPRESSION="gzip"
#COMPRESSION="bzip2"
#COMPRESSION="lzma"
#COMPRESSION="xz"
#COMPRESSION="lzop"
#COMPRESSION="lz4"
#COMPRESSION="zstd"
# COMPRESSION_OPTIONS
# Additional options for the compressor
#COMPRESSION_OPTIONS=()
