On startup intermittently I get the following error.
Title bar says: applications:kcm_kwinscreenedges
dialogue box says: The file or folder cm_kwinscreenedges/ does not exist.
I posted a photo. It is self explanatory but I do not know how to proceed and since this seems to be part of KDE I am hesitant to so so. It is a very minor inconvenience because the desktop is still usable.
An error like that is usually the result of an incompatible (or recently no longer compatible) theme component or desktop effect. Considering that it’s referring to the screen edges, it is most likely one of the desktop effects.
Merry Christmas!
I just did this and it did work, albeit reset everything else. I will compare the two files and see if I can find the culprit. Thank you for the help!
