Hello and apologies if this is a basic question.
I followed the forum tutorial called how-to-install-apache-mariadb-mysql-php-lamp. Everything worked great then. When I tried to open phpmyadmin a few days later, I get the following error displayed in the browser:
dial tcp myIPaddress:80: getsockopt: connection refused
So far, I have already tried the following commands:
sudo systemctl enable httpd
sudo systemctl restart httpd
sudo systemctl status httpd
Here’s the output from the status:
● httpd.service - Apache Web Server
Loaded: loaded (/usr/lib/systemd/system/httpd.service; enabled; preset: disabled)
Active: active (running) since Sat 2022-10-15 19:05:19 PDT; 24min ago
Main PID: 7514 (httpd)
Tasks: 6 (limit: 19043)
Memory: 8.2M
CPU: 160ms
CGroup: /system.slice/httpd.service
├─7514 /usr/bin/httpd -k start -DFOREGROUND
├─7516 /usr/bin/httpd -k start -DFOREGROUND
├─7517 /usr/bin/httpd -k start -DFOREGROUND
├─7518 /usr/bin/httpd -k start -DFOREGROUND
├─7519 /usr/bin/httpd -k start -DFOREGROUND
└─7520 /usr/bin/httpd -k start -DFOREGROUND
Oct 15 19:05:19 nick-pc systemd[1]: Started Apache Web Server.
Oct 15 19:05:19 nick-pc httpd[7514]: AH00558: httpd: Could not reliably determine the server's fully qualified domain name using myIPaddress Set the 'ServerName' directive globally to suppress this message>>
Thank you for helping!
