I’m trying to get the source code for a package. I see that I’m to use
sudo pacman -S asp
However –
error: target not found: asp
sudo pacman -S asp
However –
asp is not in the Manjaro repositories.
How do we get the source code?
Source code of what? The source of asp is available on Github[1]. The PKGBUILD files for Manjaro packages are available on their Gitlab[2]. And if you cannot find a package there, then it probably comes directly from the Arch repositories, so its PKGBUILD may be found on their Github[3].
[1]: https:// github. com/archlinux/asp
[2]: https:// gitlab. manjaro. org/packages
[3]: https:// github. com/archlinux/svntogit-packages
By going to wherever the developer hosts the source code?
asp is only available in AUR, it’s not in Manjaro repo
