Has anyone found the secret to get Kmail to work with Gmail when you have two factor authentication turned on?
Thanks
Jason
Thanks
Jason
Take a look at the thread for Bug 404990 - Sign in with Google temporarily disabled for this app , which came from kde forum.
Comment #2 says, “if you use 2-factor authentication you will need to generate an app-specific password on accounts.google.com”, and there is more…
