ms971
10 December 2021 02:26
1
Kudos to Manjaro developers. This is the only distro that detected the wifi, and DVD. The MHWD sets Manjaro apart.
But I think the reason my Broadcom bluetooth is not detected is Qualcomm don’t support the chip except in Windows, as per this Git project GitHub - winterheart/broadcom-bt-firmware: Repository for various Broadcom Bluetooth firmware
for my BCM43142. I thought just using open source drivers would detect it and have tried to follow this AUR (en) - broadcom-bt-firmware-git but honestly, it’s beyond me. All I have done is download the snapshop, but have no idea where to go with it next.
What outputs do I need to post to get help on this?
OS: Manjaro Linux x86_64
Host: Aspire ES1-571 V1.00
Kernel: 5.15.2-2-MANJARO
Uptime: 10 hours, 31 mins
Packages: 1306 (pacman), 5 (flatpak)
Shell: bash 5.1.8
Resolution: 1366x768
DE: Plasma 5.23.3
WM: KWin
Theme: Breath2 2021 Light [Plasma], Breeze [GTK2/3]
Icons: breath2 [Plasma], breath2 [GTK2/3]
Terminal: yakuake
CPU: Intel i3-5005U (4) @ 1.900GHz
GPU: Intel HD Graphics 5500
Memory: 2140MiB / 3839MiB
With pamac you can create and install a package with:
pamac build broadcom-bt-firmware-git
or if you have cloned it, change the working dir to that folder and run it:
cd ~/path/to/broadcom-bt-firmware-git
makepkg -si
ms971
11 December 2021 01:51
3
I cloned it from Github, but do not really understand what to do next. How do I get the system to redetect the bluetooth? Can you point me to a Archwiki page on it? Sorry but this is new to me.
@ms971
Well in general it should work like that:
open a terminal
Install the firmware:
remove/unload the current driver:
sudo modprobe -rfv btusb
add/load it again:
sudo modprobe -v btusb
Check if it is running without errors:
sudo dmesg | grep -i blue
Configure bluetooth configs:
hciconfig --all
I did not test that and have no bluetooth devices for testing.
ms971
13 December 2021 01:22
5
Thanks, your instructions worked. But the hciconfig is not found, so I am including the grep results to try and learn why?
[ 23.173150] Bluetooth: Core ver 2.22
[ 23.173179] NET: Registered PF_BLUETOOTH protocol family
[ 23.173181] Bluetooth: HCI device and connection manager initialized
[ 23.173185] Bluetooth: HCI socket layer initialized
[ 23.173187] Bluetooth: L2CAP socket layer initialized
[ 23.173191] Bluetooth: SCO socket layer initialized
[ 23.507860] Bluetooth: hci0: BCM: chip id 70
[ 23.508857] Bluetooth: hci0: BCM: features 0x06
[ 23.524886] Bluetooth: hci0: manjaro
[ 23.524893] Bluetooth: hci0: BCM43142A0 (001.001.011) build 0000
[ 23.668901] Bluetooth: hci0: BCM43142A0 ‘brcm/BCM43142A0-04ca-2012.hcd’ Patch
[ 24.441012] Bluetooth: hci0: Broadcom Bluetooth 4.0 USB
[ 24.441026] Bluetooth: hci0: BCM43142A0 (001.001.011) build 0339
[ 31.773318] audit: type=1130 audit(1639334217.878:35): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=bluetooth comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
[ 32.092770] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 32.092778] Bluetooth: BNEP filters: protocol multicast
[ 32.092789] Bluetooth: BNEP socket layer initialized
[ 102.477550] Bluetooth: RFCOMM TTY layer initialized
[ 102.477564] Bluetooth: RFCOMM socket layer initialized
[ 102.477572] Bluetooth: RFCOMM ver 1.11
[22297.601625] Bluetooth: hci0: urb 000000000e37a582 failed to resubmit (2)
[22330.235025] Bluetooth: hci0: BCM: chip id 70
[22330.236023] Bluetooth: hci0: BCM: features 0x06
[22330.252026] Bluetooth: hci0: acer
[22330.252035] Bluetooth: hci0: BCM43142A0 (001.001.011) build 0339
[22330.253120] Bluetooth: hci0: BCM43142A0 ‘brcm/BCM43142A0-04ca-2012.hcd’ Patch
[22331.013027] Bluetooth: hci0: Broadcom Bluetooth 4.0 USB
[22331.013036] Bluetooth: hci0: BCM43142A0 (001.001.011) build 0339
[michael@acer Downloads]$ hciconfig --all
bash: hciconfig: command not found
Then I guess this tool is not installed or/and not needed. No idea
system
Closed
17 December 2021 03:18
7
