Please move if there’s a better place for this.
Platform: Pinephone 64, Manjaro / Plasma Mobile. (Stable branch)
Since there was a stable update announced, I started “Discover”, and after checking for updates, it declared that the system was up to date.
A quick check of the python version in a terminal revealed that this was not the case.
Running sudo pacman -Syu in a terminal updated just over 400 packages.
So: does this mean that discover doesn’t actually manage the low-level packages or that it isn’t scanning the repositories properly (or that I need to select some option to make it do so even though it says “Checking updates” before declaring the system up to date)?
P.S. On my desktop systems, pacman -Syu is my normal modus operandi so I’m not too familiar with the GUI software management tools.
