Hello,
I know little about how Manjaro and Steam manage to make games run smoothly; however, on one of my laptops (ASUS Zenbook, with no GPU), games that should work, don’t. Specifically:
- some native games (for example Superliminal) won’t launch at all;
- some games, that should (according to other users on ProtonDB) work with minimal tweaks (like STRAFTAT, which is reported to work with only Proton 9 or Experimental, and no launch options — extremely lightweight game with simple graphics) only work with a lot of launch options and patches, and still run pretty bad (for STRAFTAT, I need to put:
DXVK_ASYNC=1 PROTON_USE_WINED3D=1 gamemoderun mangohud %command%).
System info:
Kernel: 6.11.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.11-x86_64
root=UUID=ccf1bd5a-96d0-48ce-b352-228bc163669c rw quiet splash apparmor=1
security=apparmor resume=UUID=f18e1fcf-8c17-46de-84fc-4c543a06dffe
udev.log_priority=3
Desktop: GNOME v: 47.2 tk: GTK v: 3.24.43 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Manjaro
base: Arch Linux
Type: Laptop System: ASUSTeK product: Zenbook UX3402ZA_UX3402ZA v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: UX3402ZA v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: UX3402ZA.310
date: 12/14/2022
ID-1: BAT0 charge: 54.6 Wh (74.0%) condition: 73.8/75.4 Wh (97.9%)
volts: 8.0 min: 8.0 model: ASUSTeK UX3402ZA type: Li-ion serial: <filter>
status: charging cycles: 56
System RAM: total: 16 GiB available: 15.25 GiB used: 11.34 GiB (74.4%)
Array-1: capacity: 16 GiB slots: 8 modules: 8 EC: None
max-module-size: 2 GiB note: est.
Device-1: Controller0-ChannelA type: LPDDR5 detail: synchronous
size: 2 GiB speed: spec: 6400 MT/s actual: 4800 MT/s volts: curr: 0.5
min: 0.5 max: 0.5 width (bits): data: 16 total: 16 manufacturer: SK Hynix
part-no: H9JCNNNCP3MLYR-N6E serial: N/A
Device-2: Controller0-ChannelB type: LPDDR5 detail: synchronous
Device-3: Controller0-ChannelC type: LPDDR5 detail: synchronous
Device-4: Controller0-ChannelD type: LPDDR5 detail: synchronous
Device-5: Controller1-ChannelA type: LPDDR5 detail: synchronous
Device-6: Controller1-ChannelB type: LPDDR5 detail: synchronous
Device-7: Controller1-ChannelC type: LPDDR5 detail: synchronous
Device-8: Controller1-ChannelD type: LPDDR5 detail: synchronous
Info: model: 12th Gen Intel Core i7-1260P bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
microcode: 0x435
Topology: cpus: 1x dies: 1 clusters: 6 cores: 12 threads: 16 mt: 4 tpc: 2
st: 8 smt: enabled cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32
KiB, 8x64 KiB L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 400 min/max: 400/4700:3400 scaling: driver: intel_pstate
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400 15: 400 16: 400
bogomips: 79888
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pdcm pdpe1gb
pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp
rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
xtopology xtpr
conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] vendor: ASUSTeK
driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
built: 2021-22+ ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4,
HDMI-A-1 bus-ID: 0000:00:02.0 chip-ID: 8086:46a6 class-ID: 0300
Device-2: Sonix USB2.0 FHD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:3 chip-ID: 3277:0010
class-ID: 0e02
Display: x11 server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3296x2060 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 model: Samsung 0x4171 built: 2020 res: mode: 2880x1800
hz: 90 scale: 87% (1.14444444444444) to: 3296x2060 dpi: 242 gamma: 1.2
chroma: red: x: 0.682 y: 0.322 green: x: 0.235 y: 0.725 blue: x: 0.137
y: 0.047 white: x: 0.314 y: 0.329 size: 302x189mm (11.89x7.44")
diag: 356mm (14") ratio: 16:10 modes: 2880x1800
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.8-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
device-ID: 8086:46a6 memory: 7.45 GiB unified: yes
Info: Tools: api: eglinfo,glxinfo x11: xprop,xrandr
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: ASUSTeK
driver: sof-audio-pci-intel-tgl alternate: snd_hda_intel, snd_soc_avs,
snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:51c8
class-ID: 0401
API: ALSA v: k6.11.11-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0033
class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 236.64 GiB (49.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 3400 MTFDKBA512TFH
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: P7MA002 temp: 40.9 C
scheme: GPT
ID-1: / raw-size: 459.87 GiB size: 451.58 GiB (98.20%)
used: 231.39 GiB (51.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: ccf1bd5a-96d0-48ce-b352-228bc163669c
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 763E-75C2
ID-1: swap-1 type: partition size: 16.78 GiB used: 5.25 GiB (31.3%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: f18e1fcf-8c17-46de-84fc-4c543a06dffe
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-2:5 info: Xenta JLab JBuds Mouse type: keyboard,mouse,HID
driver: hid-generic,usbhid interfaces: 4 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 1d57:fa60 class-ID: 0301
Device-2: 3-6:2 info: Elan Micro ELAN:Fingerprint type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 04f3:0c6e class-ID: 0000
Device-3: 3-8:3 info: Sonix USB2.0 FHD UVC WebCam type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 3277:0010 class-ID: 0e02
Device-4: 3-10:4 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0033 class-ID: e001
System Temperatures: cpu: 51.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: 2084 pm: pacman pkgs: 2078 libs: 489 tools: gnome-software,pamac
pm: flatpak pkgs: 6
1: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
2: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
3: https://mirrors2.manjaro.org/stable/$repo/$arch
4: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
5: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
6: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
7: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
8: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 488
1: cpu: 11.0% command: vivaldi-bin pid: 184980 mem: 282.7 MiB (1.8%)
2: cpu: 9.1% command: vivaldi-bin pid: 178367 mem: 298.6 MiB (1.9%)
3: cpu: 3.7% command: gnome-terminal-server pid: 185890
mem: 60.0 MiB (0.3%)
4: cpu: 3.6% command: steam pid: 181485 mem: 153.6 MiB (0.9%)
5: cpu: 3.5% command: steamwebhelper pid: 181797 mem: 431.9 MiB (2.7%)
Memory top: 5 of 488
1: mem: 725.9 MiB (4.6%) command: firefox pid: 3613 cpu: 1.3%
2: mem: 448.7 MiB (2.8%) command: ./steamwebhelper pid: 181708 cpu: 2.8%
3: mem: 437.7 MiB (2.8%) command: gnome-shell pid: 2493 cpu: 3.2%
4: mem: 431.9 MiB (2.7%) command: steamwebhelper pid: 181797 cpu: 3.5%
5: mem: 393.2 MiB (2.5%) command: firefox pid: 10604 cpu: 0.4%
Processes: 488 Power: uptime: 11h 16m states: freeze,mem,disk
suspend: s2idle avail: deep wakeups: 4 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 6.09 GiB services: gsd-power,upowerd
Init: systemd v: 256 default: graphical tool: systemctl
Compilers: gcc: 14.2.1 alt: 13 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.37
Drivers:
> mhwd -lh -d
06: PCI 1c.0: 0604 PCI bridge (Normal decode)
SysFS ID: /devices/pci0000:00/0000:00:1c.0
SysFS BusID: 0000:00:1c.0
Hardware Class: bridge
Model: "Intel PCI bridge"
Vendor: pci 0x8086 "Intel Corporation"
Device: pci 0x51bf
SubVendor: pci 0x1043 "ASUSTeK Computer Inc."
SubDevice: pci 0x1e02
Revision: 0x01
Driver: "pcieport"
IRQ: 124 (no events)
Module Alias: "pci:v00008086d000051BFsv00001043sd00001E02bc06sc04i00"
07: PCI 08.0: 0880 System peripheral
SysFS ID: /devices/pci0000:00/0000:00:08.0
SysFS BusID: 0000:00:08.0
Hardware Class: unknown
Device Name: "Onboard - Other"
Model: "Intel System peripheral"
Device: pci 0x464f
Revision: 0x02
Memory Range: 0x603f2dd000-0x603f2ddfff (rw,non-prefetchable,disabled)
IRQ: 255 (no events)
Module Alias: "pci:v00008086d0000464Fsv00001043sd00001E02bc08sc80i00"
08: PCI 0d.0: 0c03 USB Controller (XHCI)
SysFS ID: /devices/pci0000:00/0000:00:0d.0
SysFS BusID: 0000:00:0d.0
Hardware Class: usb controller
Model: "Intel USB Controller"
Device: pci 0x461e
Revision: 0x02
Driver: "xhci_hcd"
Driver Modules: "xhci_pci"
Memory Range: 0x603f2b0000-0x603f2bffff (rw,non-prefetchable)
IRQ: 144 (no events)
Module Alias: "pci:v00008086d0000461Esv00000000sd00000000bc0Csc03i30"
Driver Info #0:
Driver Status: xhci_pci is active
Driver Activation Cmd: "modprobe xhci_pci"
09: PCI 15.1: 0c80 Serial bus controller
SysFS ID: /devices/pci0000:00/0000:00:15.1
SysFS BusID: 0000:00:15.1
Model: "Intel Serial bus controller"
Device: pci 0x51e9
Revision: 0x01
Driver: "intel-lpss"
Driver Modules: "intel_lpss_pci"
Memory Range: 0x4017001000-0x4017001fff (rw,non-prefetchable)
IRQ: 40 (no events)
Module Alias: "pci:v00008086d000051E9sv00001043sd00001E02bc0Csc80i00"
Driver Info #0:
Driver Status: intel_lpss_pci is active
Driver Activation Cmd: "modprobe intel_lpss_pci"
10: PCI 5500.0: 0805 SD Host controller
SysFS ID: /devices/pci0000:00/0000:00:1c.0/0000:55:00.0
SysFS BusID: 0000:55:00.0
Model: "O2 Micro SD/MMC Card Reader Controller"
Vendor: pci 0x1217 "O2 Micro, Inc."
Device: pci 0x8621 "SD/MMC Card Reader Controller"
SubDevice: pci 0x202f
Revision: 0x01
Driver: "sdhci-pci"
Driver Modules: "sdhci_pci"
Memory Range: 0x6c301000-0x6c301fff (rw,non-prefetchable)
Memory Range: 0x6c300000-0x6c3007ff (rw,non-prefetchable)
IRQ: 160 (no events)
Module Alias: "pci:v00001217d00008621sv00001043sd0000202Fbc08sc05i01"
Driver Info #0:
Driver Status: sdhci_pci is active
Driver Activation Cmd: "modprobe sdhci_pci"
Attached to: #6 (PCI bridge)
11: PCI 1f.0: 0601 ISA bridge
SysFS ID: /devices/pci0000:00/0000:00:1f.0
SysFS BusID: 0000:00:1f.0
Model: "Intel ISA bridge"
Device: pci 0x5182
Revision: 0x01
Module Alias: "pci:v00008086d00005182sv00001043sd00001E02bc06sc01i00"
12: PCI e006.0: 0604 PCI bridge (Normal decode)
SysFS ID: /devices/pci0000:00/0000:00:0e.0/pci10000:e0/10000:e0:06.0
SysFS BusID: 10000:e0:06.0
Device: pci 0x464d
Revision: 0x02
Driver: "pcieport"
IRQ: 161 (no events)
Module Alias: "pci:v00008086d0000464Dsv00000000sd00000000bc06sc04i00"
13: PCI 07.2: 0604 PCI bridge (Normal decode)
SysFS ID: /devices/pci0000:00/0000:00:07.2
SysFS BusID: 0000:00:07.2
Device: pci 0x462f
Revision: 0x02
Driver: "pcieport"
IRQ: 123 (no events)
Module Alias: "pci:v00008086d0000462Fsv00000000sd00000000bc06sc04i00"
14: PCI 04.0: 1180 Signal processing controller
SysFS ID: /devices/pci0000:00/0000:00:04.0
SysFS BusID: 0000:00:04.0
Model: "Intel Signal processing controller"
Device: pci 0x461d
Revision: 0x02
Driver: "proc_thermal_pci"
Driver Modules: "processor_thermal_device_pci"
Memory Range: 0x603f280000-0x603f29ffff (rw,non-prefetchable)
IRQ: 16 (32 events)
Module Alias: "pci:v00008086d0000461Dsv00001043sd00001E02bc11sc80i00"
Driver Info #0:
Driver Status: processor_thermal_device_pci is active
Driver Activation Cmd: "modprobe processor_thermal_device_pci"
15: PCI 14.3: 0200 Ethernet controller
SysFS ID: /devices/pci0000:00/0000:00:14.3
SysFS BusID: 0000:00:14.3
Hardware Class: network
Device Name: "Onboard - Ethernet"
Model: "Intel Ethernet controller"
Device: pci 0x51f0
SubVendor: pci 0x8086 "Intel Corporation"
SubDevice: pci 0x0094
Revision: 0x01
Driver: "iwlwifi"
Driver Modules: "iwlwifi"
Device File: wlo1
Memory Range: 0x603f2cc000-0x603f2cffff (rw,non-prefetchable)
IRQ: 16 (32 events)
HW Address: 04:e8:b9:e2:41:4a
Permanent HW Address: 04:e8:b9:e2:41:4a
Link detected: yes
Module Alias: "pci:v00008086d000051F0sv00008086sd00000094bc02sc80i00"
Driver Info #0:
Driver Status: iwlwifi is active
Driver Activation Cmd: "modprobe iwlwifi"
16: PCI 16.0: 0780 Communication controller
SysFS ID: /devices/pci0000:00/0000:00:16.0
SysFS BusID: 0000:00:16.0
Model: "Intel Communication controller"
Device: pci 0x51e0
Revision: 0x01
Driver: "mei_me"
Driver Modules: "mei_me"
Memory Range: 0x603f2d7000-0x603f2d7fff (rw,non-prefetchable)
IRQ: 186 (33 events)
Module Alias: "pci:v00008086d000051E0sv00001043sd00001E02bc07sc80i00"
Driver Info #0:
Driver Status: mei_me is active
Driver Activation Cmd: "modprobe mei_me"
17: PCI 1e.2: 0c80 Serial bus controller
SysFS ID: /devices/pci0000:00/0000:00:1e.2
SysFS BusID: 0000:00:1e.2
Device: pci 0x51aa
Revision: 0x01
Memory Range: 0x4017003000-0x4017003fff (rw,non-prefetchable)
IRQ: 36 (28570 events)
Module Alias: "pci:v00008086d000051AAsv00001043sd00001E02bc0Csc80i00"
Driver Info #0:
18: PCI 07.0: 0604 PCI bridge (Normal decode)
SysFS ID: /devices/pci0000:00/0000:00:07.0
SysFS BusID: 0000:00:07.0
Device: pci 0x466e
Revision: 0x02
Driver: "pcieport"
IRQ: 122 (no events)
Module Alias: "pci:v00008086d0000466Esv00001043sd00001E02bc06sc04i00"
19: PCI 1f.5: 0c80 Serial bus controller
SysFS ID: /devices/pci0000:00/0000:00:1f.5
SysFS BusID: 0000:00:1f.5
Device: pci 0x51a4
Revision: 0x01
Driver: "intel-spi"
Driver Modules: "spi_intel_pci"
Memory Range: 0x4f800000-0x4f800fff (rw,non-prefetchable)
Module Alias: "pci:v00008086d000051A4sv00001043sd00001E02bc0Csc80i00"
Driver Info #0:
Driver Status: spi_intel_pci is active
Driver Activation Cmd: "modprobe spi_intel_pci"
20: PCI 0d.3: 0c03 USB Controller (USB4 Host Interface)
SysFS ID: /devices/pci0000:00/0000:00:0d.3
SysFS BusID: 0000:00:0d.3
Device: pci 0x466d
SubVendor: pci 0x2222
SubDevice: pci 0x1111
Revision: 0x02
Driver: "thunderbolt"
Driver Modules: "thunderbolt"
Memory Range: 0x603f200000-0x603f23ffff (rw,non-prefetchable)
Memory Range: 0x603f2db000-0x603f2dbfff (rw,non-prefetchable)
IRQ: 16 (32 events)
Module Alias: "pci:v00008086d0000466Dsv00002222sd00001111bc0Csc03i40"
Driver Info #0:
Driver Status: thunderbolt is active
Driver Activation Cmd: "modprobe thunderbolt"
21: PCI 1e.0: 0780 Communication controller
SysFS ID: /devices/pci0000:00/0000:00:1e.0
SysFS BusID: 0000:00:1e.0
Device: pci 0x51a8
Revision: 0x01
Memory Range: 0x4017002000-0x4017002fff (rw,non-prefetchable)
IRQ: 16 (32 events)
Module Alias: "pci:v00008086d000051A8sv00001043sd00001E02bc07sc80i00"
Driver Info #0:
22: PCI 1f.3: 0401 Multimedia audio controller
SysFS ID: /devices/pci0000:00/0000:00:1f.3
SysFS BusID: 0000:00:1f.3
Hardware Class: sound
Device Name: "Onboard - Sound"
Model: "Intel Multimedia audio controller"
Device: pci 0x51c8
Revision: 0x01
Driver: "sof-audio-pci-intel-tgl"
Driver Modules: "snd_sof_pci_intel_tgl"
Memory Range: 0x603f2c8000-0x603f2cbfff (rw,non-prefetchable)
Memory Range: 0x603f000000-0x603f0fffff (rw,non-prefetchable)
IRQ: 242 (10778 events)
Module Alias: "pci:v00008086d000051C8sv00001043sd00001E02bc04sc01i00"
Driver Info #0:
Driver Status: snd_hda_intel is active
Driver Activation Cmd: "modprobe snd_hda_intel"
Driver Info #1:
Driver Status: snd_soc_avs is active
Driver Activation Cmd: "modprobe snd_soc_avs"
Driver Info #2:
Driver Status: snd_sof_pci_intel_tgl is active
Driver Activation Cmd: "modprobe snd_sof_pci_intel_tgl"
23: PCI 00.0: 0600 Host bridge
SysFS ID: /devices/pci0000:00/0000:00:00.0
SysFS BusID: 0000:00:00.0
Model: "Intel Host bridge"
Device: pci 0x4621
Revision: 0x02
Driver: "igen6_edac"
Driver Modules: "igen6_edac"
Module Alias: "pci:v00008086d00004621sv00001043sd00001E02bc06sc00i00"
Driver Info #0:
Driver Status: igen6_edac is active
Driver Activation Cmd: "modprobe igen6_edac"
24: PCI 15.0: 0c80 Serial bus controller
SysFS ID: /devices/pci0000:00/0000:00:15.0
SysFS BusID: 0000:00:15.0
Device: pci 0x51e8
Revision: 0x01
Memory Range: 0x4017000000-0x4017000fff (rw,non-prefetchable)
IRQ: 27 (7704243 events)
Module Alias: "pci:v00008086d000051E8sv00001043sd00001E02bc0Csc80i00"
Driver Info #0:
25: PCI 06.0: 0880 System peripheral
SysFS ID: /devices/pci0000:00/0000:00:06.0
SysFS BusID: 0000:00:06.0
Device: pci 0x09ab
Module Alias: "pci:v00008086d000009ABsv00000000sd00000000bc08sc80i00"
26: PCI 0e.0: 0104 RAID bus controller
SysFS BusID: 0000:00:0e.0
Hardware Class: storage
Model: "Intel Volume Management Device NVMe RAID Controller"
Device: pci 0x467f "Volume Management Device NVMe RAID Controller"
SubDevice: pci 0x0000
Driver: "vmd"
Driver Modules: "vmd"
Memory Range: 0x603c000000-0x603dffffff (rw,non-prefetchable)
Memory Range: 0x50000000-0x51ffffff (rw,non-prefetchable)
Memory Range: 0x603f100000-0x603f1fffff (rw,non-prefetchable)
Module Alias: "pci:v00008086d0000467Fsv00008086sd00000000bc01sc04i00"
Driver Info #0:
Driver Status: vmd is active
Driver Activation Cmd: "modprobe vmd"
27: PCI 14.2: 0500 RAM memory
SysFS ID: /devices/pci0000:00/0000:00:14.2
SysFS BusID: 0000:00:14.2
Model: "Intel RAM memory"
Device: pci 0x51ef
Revision: 0x01
Memory Range: 0x603f2d0000-0x603f2d3fff (rw,non-prefetchable,disabled)
Memory Range: 0x603f2da000-0x603f2dafff (rw,non-prefetchable,disabled)
Module Alias: "pci:v00008086d000051EFsv00000000sd00000000bc05sc00i00"
28: PCI 02.0: 0300 VGA compatible controller (VGA)
SysFS ID: /devices/pci0000:00/0000:00:02.0
SysFS BusID: 0000:00:02.0
Hardware Class: graphics card
Device Name: "Onboard - Video"
Model: "Intel VGA compatible controller"
Device: pci 0x46a6
Revision: 0x0c
Driver: "i915"
Driver Modules: "i915"
Memory Range: 0x603e000000-0x603effffff (rw,non-prefetchable)
Memory Range: 0x4000000000-0x400fffffff (ro,non-prefetchable)
I/O Ports: 0x3000-0x303f (rw)
Memory Range: 0x000c0000-0x000dffff (rw,non-prefetchable,disabled)
IRQ: 179 (3482954 events)
Module Alias: "pci:v00008086d000046A6sv00001043sd00001E02bc03sc00i00"
Driver Info #0:
Driver Status: i915 is active
Driver Activation Cmd: "modprobe i915"
Driver Info #1:
Driver Status: xe is active
Driver Activation Cmd: "modprobe xe"
29: PCI e100.0: 0108 Non-Volatile memory controller (NVM Express)
SysFS ID: /devices/pci0000:00/0000:00:0e.0/pci10000:e0/10000:e0:06.0/10000:e1:00.0
SysFS BusID: 10000:e1:00.0
Model: "Micron Non-Volatile memory controller"
Vendor: pci 0x1344 "Micron Technology Inc"
Device: pci 0x5407
SubVendor: pci 0x1344 "Micron Technology Inc"
SubDevice: pci 0x0100
Driver: "nvme"
Driver Modules: "nvme"
Memory Range: 0x50000000-0x50003fff (rw,non-prefetchable)
Module Alias: "pci:v00001344d00005407sv00001344sd00000100bc01sc08i02"
Driver Info #0:
Driver Status: nvme is active
Driver Activation Cmd: "modprobe nvme"
Attached to: #12 (PCI bridge)
30: PCI 14.0: 0c03 USB Controller (XHCI)
SysFS ID: /devices/pci0000:00/0000:00:14.0
SysFS BusID: 0000:00:14.0
Device: pci 0x51ed
Revision: 0x01
Driver: "xhci_hcd"
Memory Range: 0x603f2a0000-0x603f2affff (rw,non-prefetchable)
IRQ: 152 (450908 events)
Module Alias: "pci:v00008086d000051EDsv00001043sd00001E02bc0Csc03i30"
Driver Info #0:
31: PCI 1f.4: 0c05 SMBus
SysFS ID: /devices/pci0000:00/0000:00:1f.4
SysFS BusID: 0000:00:1f.4
Model: "Intel SMBus"
Device: pci 0x51a3
Revision: 0x01
Driver: "i801_smbus"
Driver Modules: "i2c_i801"
Memory Range: 0x603f2d4000-0x603f2d40ff (rw,non-prefetchable)
I/O Ports: 0xefa0-0xefbf (rw)
IRQ: 16 (32 events)
Module Alias: "pci:v00008086d000051A3sv00001043sd00001E02bc0Csc05i00"
Driver Info #0:
Driver Status: i2c_i801 is active
Driver Activation Cmd: "modprobe i2c_i801"
32: PCI 0d.2: 0c03 USB Controller (USB4 Host Interface)
SysFS ID: /devices/pci0000:00/0000:00:0d.2
SysFS BusID: 0000:00:0d.2
Device: pci 0x463e
Revision: 0x02
Memory Range: 0x603f240000-0x603f27ffff (rw,non-prefetchable)
Memory Range: 0x603f2dc000-0x603f2dcfff (rw,non-prefetchable)
IRQ: 16 (32 events)
Module Alias: "pci:v00008086d0000463Esv00002222sd00001111bc0Csc03i40"
Driver Info #0:
33: PCI 0a.0: 1180 Signal processing controller
SysFS ID: /devices/pci0000:00/0000:00:0a.0
SysFS BusID: 0000:00:0a.0
Device: pci 0x467d
Revision: 0x01
Driver: "intel_vsec"
Driver Modules: "intel_vsec"
Memory Range: 0x603f2c0000-0x603f2c7fff (rw,non-prefetchable)
Module Alias: "pci:v00008086d0000467Dsv00000000sd00000000bc11sc80i00"
Driver Info #0:
Driver Status: intel_vsec is active
Driver Activation Cmd: "modprobe intel_vsec"
02: USB 00.3: 10800 Keyboard
SysFS ID: /devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2:1.3
SysFS BusID: 3-2:1.3
Hardware Class: keyboard
Model: "Xenta JLab JBuds Mouse"
Hotplug: USB
Vendor: usb 0x1d57 "Xenta"
Device: usb 0xfa60 "JLab JBuds Mouse"
Revision: "40.01"
Driver: "usbhid"
Driver Modules: "usbhid"
Device File: /dev/input/event21
Device Files: /dev/input/event21, /dev/input/by-id/usb-LXDDZ_JLab_JBuds_Mouse-if03-event-kbd, /dev/input/by-path/pci-0000:00:14.0-usbv2-0:2:1.3-event-kbd, /dev/input/by-path/pci-0000:00:14.0-usb-0:2:1.3-event-kbd
Device Number: char 13:85
Speed: 12 Mbps
Module Alias: "usb:v1D57pFA60d4001dc00dsc00dp00ic03isc01ip01in03"
Driver Info #0:
XkbRules: xfree86
XkbModel: pc104
Attached to: #4 (Hub)
03: USB 00.1: 10503 USB Mouse
SysFS ID: /devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2:1.1
SysFS BusID: 3-2:1.1
Hardware Class: mouse
Hotplug: USB
Revision: "40.01"
Compatible to: int 0x0210 0x0045
Driver: "usbhid"
Device File: /dev/input/mice (/dev/input/mouse2)
Device Files: /dev/input/mice, /dev/input/mouse2, /dev/input/event18, /dev/input/by-id/usb-LXDDZ_JLab_JBuds_Mouse-if01-event-mouse, /dev/input/by-path/pci-0000:00:14.0-usbv2-0:2:1.1-event-mouse, /dev/input/by-path/pci-0000:00:14.0-usb-0:2:1.1-event-mouse, /dev/input/by-path/pci-0000:00:14.0-usbv2-0:2:1.1-mouse, /dev/input/by-id/usb-LXDDZ_JLab_JBuds_Mouse-if01-mouse, /dev/input/by-path/pci-0000:00:14.0-usb-0:2:1.1-mouse
Device Number: char 13:63 (char 13:34)
Speed: 12 Mbps
Module Alias: "usb:v1D57pFA60d4001dc00dsc00dp00ic03isc01ip02in01"
Driver Info #0:
Buttons: 5
Wheels: 4
XFree86 Protocol: explorerps/2
GPM Protocol: exps2
04: USB 00.0: 10a00 Hub
SysFS ID: /devices/pci0000:00/0000:00:14.0/usb3/3-0:1.0
SysFS BusID: 3-0:1.0
Hardware Class: hub
Model: "Linux Foundation 2.0 root hub"
Hotplug: USB
Vendor: usb 0x1d6b "Linux Foundation"
Device: usb 0x0002 "2.0 root hub"
Revision: "6.11"
Serial ID: "0000:00:14.0"
Driver: "hub"
Speed: 480 Mbps
Module Alias: "usb:v1D6Bp0002d0611dc09dsc00dp01ic09isc00ip00in00"
05: USB 00.0: 11500 Bluetooth Device
SysFS ID: /devices/pci0000:00/0000:00:14.0/usb3/3-10/3-10:1.0
SysFS BusID: 3-10:1.0
Hardware Class: bluetooth
Model: "Intel Bluetooth Device"
Hotplug: USB
Vendor: usb 0x8087 "Intel Corp."
Device: usb 0x0033
Driver: "btusb"
Driver Modules: "btusb"
Speed: 12 Mbps
Module Alias: "usb:v8087p0033d0000dcE0dsc01dp01icE0isc01ip01in00"
Driver Info #0:
Driver Status: btusb is active
Driver Activation Cmd: "modprobe btusb"
06: USB 00.0: 0000 Unclassified device
SysFS ID: /devices/pci0000:00/0000:00:14.0/usb3/3-8/3-8:1.0
SysFS BusID: 3-8:1.0
Model: "Sonix USB2.0 FHD UVC WebCam"
Hotplug: USB
Vendor: usb 0x3277 "Sonix Technology Co., Ltd."
Device: usb 0x0010 "USB2.0 FHD UVC WebCam"
Revision: "0.03"
Driver: "uvcvideo"
Driver Modules: "uvcvideo"
Speed: 480 Mbps
Module Alias: "usb:v3277p0010d0003dcEFdsc02dp01ic0Eisc01ip00in00"
Driver Info #0:
Driver Status: uvcvideo is active
Driver Activation Cmd: "modprobe uvcvideo"
07: USB 00.0: 10a00 Hub
SysFS ID: /devices/pci0000:00/0000:00:14.0/usb4/4-0:1.0
SysFS BusID: 4-0:1.0
Hardware Class: hub
Model: "Linux Foundation 3.0 root hub"
Hotplug: USB
Device: usb 0x0003 "3.0 root hub"
Revision: "6.11"
Driver: "hub"
Module Alias: "usb:v1D6Bp0003d0611dc09dsc00dp03ic09isc00ip00in00"
08: USB 00.2: 0000 Unclassified device
SysFS ID: /devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2:1.2
SysFS BusID: 3-2:1.2
Hotplug: USB
Revision: "40.01"
Driver: "usbhid"
Device File: /dev/input/event20
Device Files: /dev/input/event20, /dev/input/by-path/pci-0000:00:14.0-usb-0:2:1.2-event, /dev/input/by-path/pci-0000:00:14.0-usbv2-0:2:1.2-event, /dev/input/by-id/usb-LXDDZ_JLab_JBuds_Mouse-event-if02
Device Number: char 13:84
Speed: 12 Mbps
Module Alias: "usb:v1D57pFA60d4001dc00dsc00dp00ic03isc00ip00in02"
Driver Info #0:
Driver Status: usbhid is active
Driver Activation Cmd: "modprobe usbhid"
09: USB 00.0: 10a00 Hub
SysFS ID: /devices/pci0000:00/0000:00:0d.0/usb1/1-0:1.0
SysFS BusID: 1-0:1.0
Hardware Class: hub
Hotplug: USB
Revision: "6.11"
Serial ID: "0000:00:0d.0"
Driver: "hub"
Speed: 480 Mbps
13: USB 00.0: 0000 Unclassified device
SysFS ID: /devices/pci0000:00/0000:00:14.0/usb3/3-6/3-6:1.0
SysFS BusID: 3-6:1.0
Model: "Elan Microelectronics ELAN:Fingerprint"
Hotplug: USB
Vendor: usb 0x04f3 "Elan Microelectronics Corp."
Device: usb 0x0c6e "ELAN:Fingerprint"
Revision: "8.00"
Speed: 12 Mbps
Module Alias: "usb:v04F3p0C6Ed0800dc00dsc00dp00icFFisc00ip00in00"
14: USB 00.0: 10a00 Hub
SysFS ID: /devices/pci0000:00/0000:00:0d.0/usb2/2-0:1.0
SysFS BusID: 2-0:1.0
Hardware Class: hub
Hotplug: USB
Revision: "6.11"
Driver: "hub"
Tell me if more info is needed. Thanks!
