There is a bug on Thunderbird mail to 91.1.0. The default for mp3 is set on VLC media player. When I try to play a voice mail (mp3 format), you get a pop up message.
“What should Thunderbird do with this file?”
You get the pop up box every time you try to play a voice mail, even after you check the box to “Do this automatically for files like this from now on. Should I report this as a Thunderbird or KDE bug?
Looks like I’m on version 91 now! Interesting, since this is a recent Manjaro installation, yet forcing the mirrors to refresh was needed for the Thunderbird update to show up.
@fhins I tried again with Thunderbird 91, and renaming / deleting handlers.json does in fact reset the the “Open With” settings to the defaults. You can try to reconfigure it from that point forwards, in case there was an errant setting in the handlers.json file.
The update was through the default system. I never install or update anything unless it’s the official repository. It’s not that big of a deal but it’s just pain!
@winnie,
Did this fix it for you?
“mv ~/.thunderbird/profile.default/handlers.json ~/.thunderbird/profile.default/handlers.json.bak”
It was never broken for me in the first place, but I noticed by renaming the file, it reset the “Open With” to the defaults.
So my hunch is if there’s an errant string/option in your current handlers.json file, forcing it to generate a new one from scratch might solve your issue.
Isn’t my profile name is what shows up in the Konsole? I tried both user name and profile name which is fred@Man-fh, and neither worked. I get the same error message.
Your Thunderbird (or Firefox) profile is different from your system user entirely. Simply browse ~/.thunderbird to see which profile is your default one.
I found the profile name, but for some reason can’t find the directory. I’m not going to worry about for now, as this is not a big deal. I’ll just wait for an update.
At the very least I learned a few things, and thanks for all your help!
Now that you know the unique profile folder name, you can replace it in the “mv” command, which will essentially rename the handlers.json file and force Thunderbird to create a new, fresh one (possibly without the bug you’re experiencing.)
So instead of this (using “profile.default” as an example)…
