Hi.
I was searching something about this and found this closed topic “Is there way to apply vkBasalt to GeforceNow?” (i can’t put link here)
Pretty sad, I thought, but I found a solution with app named gamescope.
Just run something like this:
"ENABLE_VKBASALT=1 gamescope – ‘path to your geforcenow binary’ "
For me it looks:
"ENABLE_VKBASALT=1 gamescope -f -w 1920 -h 1080 – /opt/geforcenow-electron/geforcenow
You can add CAS and other (maybe not all) reshade shaders with goverlay.
You did see the solution to that post, right?
