I just bought a Dell 5760 with Ubuntu 20.04 Gnome preinstalled. I ran some Geekbench on it and the scores were around 9500, after I installed Manjaro KDE they were around 6000 ish.
Please see attached image (note some are from a Surface Pro 5 and much lower)
What could be the cause of such a large difference and what can I do to fix?
I would like a faster machine but couldn’t go back to Ubuntu after Manjaro!
This image don’t show anything – there is several results and doesn’t show which result is from which OS. The difference may be caused by anything. Software versions, running programs etc. This is unsolvable problem – we know nothing about environment differences between tests.
Don’t bother some random tests – just use Manjaro if you like.
The scores in the region:
9xxx are Ubuntu
15xx Surface Pro 5 Manjaro
6xxx are Manjaro.
The ones at the bottom are oldest, before I changed from Ubuntu to Manjaro.
The ones at the top are most recent.
So, the 9xxx are Ubuntu, fresh install by Dell. 6xxx fresh install of Manjaro by me. The difference is between fresh installs of Ubuntu Gnome and Manjaro KDE.
I hope this is clearer and someone can help me understand why Ubuntu seems to have 50% greater scores.
From kernel version to CPU governor to power management, everything can change the score. I suggest at least check with something like cpupower GUI when running Geekbench, see if all cores boost to their spec and the governor used is capable for it (e.g. schedutil or performance). Oh, match the kernel version, too. Some kernels have more mitigations against hardware based attacks like the kinda old Spectre and Meltdown (that can actually be disabled) that result in significant performance penalty.
A better look: Dell Inc. Precision 5760 vs Dell Inc. Precision 5760 - Geekbench Browser
So basically single core is right on the ballpark of run variance, but multicore isn’t. That would suggest either power limit throttling (half likely) or disabled hyperthreading (more likely), especially since tests that are well scaled over threads (such as SQLite) result only in ~50% score.
