Storing the logs for another case I wrote, I experienced a strange behaviour from gedit. When opening or saving a file and accidentially typing (expecting to be in the filename dialog but being the the file path dialog) it goes into the search dialog and crashes.
Gedit gives the following logs but I don’t suppose it crashes because of missing spellcheck libraries (whiche aren’t missing by the way, hunspell is installed).
(gedit:7639): libenchant-WARNING **: 08:45:37.107: Error loading plugin: libhspell.so.0: cannot open shared object file: No such file or directory
(gedit:7639): libenchant-WARNING **: 08:45:37.107: Error loading plugin: libaspell.so.15: cannot open shared object file: No such file or directory
(gedit:7639): libenchant-WARNING **: 08:45:37.107: Error loading plugin: libnuspell.so.5: cannot open shared object file: No such file or directory
(gedit:7639): libenchant-WARNING **: 08:45:37.107: Error loading plugin: libvoikko.so.1: cannot open shared object file: No such file or directory
(gedit:7639): libenchant-WARNING **: 08:45:37.108: Error loading plugin: libhspell.so.0: cannot open shared object file: No such file or directory
(gedit:7639): libenchant-WARNING **: 08:45:37.108: Error loading plugin: libaspell.so.15: cannot open shared object file: No such file or directory
(gedit:7639): libenchant-WARNING **: 08:45:37.108: Error loading plugin: libnuspell.so.5: cannot open shared object file: No such file or directory
(gedit:7639): libenchant-WARNING **: 08:45:37.108: Error loading plugin: libvoikko.so.1: cannot open shared object file: No such file or directory
zsh: killed gedit
