Dear all,
i just entered a IMAP and SMTP account in the System-Settings. After that I opened Geary and the program got data from manjaro and it works - firstly.
I can sea some mails I have got in the past - but not all!! I also can receive new mails and send mails. But after some time i get an Error:
Account identifier: goa_account_1605810791_0
Account provider: GEARY_SERVICE_PROVIDER_OTHER
Error type: GearyEngineError 8
Message: Folder GearyImapEngineOtherFolder(>Entwürfe, open_count=1, remote_opened=false) not available
Back trace:
* geary_problem_report_construct
* geary_account_problem_report_construct
* application_main_window_prompt_empty_folder
* application_main_window_new
* g_socket_client_connect_to_uri_async
* g_task_had_error
* sqlite3FtsUnicodeFold
* g_task_had_error
* g_task_had_error
* g_task_had_error
* g_task_had_error
* turkish_UTF_8_create_env
* g_task_had_error
* g_task_had_error
* g_task_had_error
* g_task_had_error
* geary_nonblocking_lock_reset
* geary_scheduler_scheduled_instance_get_type
* g_main_context_dispatch
* g_io_channel_new_file
* g_main_context_iteration
* g_application_run
* _vala_main
* __libc_start_main
* _start
Some ideas?
