GE-Proton crash after system update
KDE Plasma Version: 6.6.6
KDE Frameworks Version: 6.27.0
Qt Version: 6.11.1
Kernel Version: 6.12.95-1-MANJARO (64-bit)
Graphics Platform: Wayland
Processors: 8 × Intel® Core™ i7-9700K CPU @ 3.60GHz
Memory: 17 GB of RAM (16,7 GB usable)
Graphics Processor: AMD Radeon RX 9070 XT
Manufacturer: Gigabyte Technology Co., Ltd.
Product Name: Z390 AORUS PRO
After updating I got this error on system start:
           PID: 5862 (services.exe)
           TID: 5913 (wine_rpcrt4_io)
           UID: 1000 (fred)
           GID: 1001 (fred)
        Signal: 11 (SEGV)
     Timestamp: Sun 2026-07-12 08:39:10 CEST (15min ago)
  Command Line: $'C:\\windows\\system32\\services.exe'
    Executable: /home/fred/.local/share/Steam/compatibilitytools.d/GE-Proton10-17/files/bin/wine64-preloader
 Control Group: /user.slice/user-1000.slice/user@1000.service/app.slice/app-steam@e009ddcadf7a40f38a8f40bd05d6b071.service
          Unit: user@1000.service
     User Unit: app-steam@e009ddcadf7a40f38a8f40bd05d6b071.service
         Slice: user-1000.slice
     Owner UID: 1000 (fred)
       Boot ID: 6715075789b84594b805e18096b2188e
    Machine ID: adf244945f194df4bcb83086e0e2a4c2
      Hostname: fred-manj
       Storage: /var/lib/systemd/coredump/core.services\x2eexe.1000.6715075789b84594b805e18096b2188e.5862.1783838350000000.zst (present)
  Size on Disk: 2.1M
       Message: Process 5862 (services.exe) of user 1000 dumped core.
                Stack trace of thread 5913:
                #0  0x00007f8dd6081430 save_context (/home/fred/.local/share/Steam/compatibilitytools.d/GE-Proton10-17/files/lib/wine/x86_64-unix/ntdll.so + 0x4a430)
                #1  0x00007f8dd60846a4 segv_handler (/home/fred/.local/share/Steam/compatibilitytools.d/GE-Proton10-17/files/lib/wine/x86_64-unix/ntdll.so + 0x4d6a4)
                #2  0x00007f8dd5e3e270 n/a (/run/host/usr/lib/libc.so.6 + 0x3e270)
                #3  0x00007f8dd5e3e270 n/a (/run/host/usr/lib/libc.so.6 + 0x3e270)
                #4  0x00007f8dd5eaa9a2 n/a (/run/host/usr/lib/libc.so.6 + 0xaa9a2)
                #5  0x00007f8dd5e97578 n/a (/run/host/usr/lib/libc.so.6 + 0x97578)
                #6  0x00007f8dd5f1bedc n/a (/run/host/usr/lib/libc.so.6 + 0x11bedc)
Trying to upload the error resulted in more errors:
⚠ warning: Can't open file /run/host/usr/lib/locale/locale-archive during file-backed mapping note processing
⚠ warning: Can't open file /run/host/usr/lib/libgcc_s.so.1 during file-backed mapping note processing
⚠ warning: Can't open file /run/host/usr/lib/libc.so.6 during file-backed mapping note processing
⚠ warning: Can't open file /dev/shm/wine-4137f-fsync during file-backed mapping note processing
⚠ warning: Can't open file /run/host/usr/lib/librt.so.1 during file-backed mapping note processing
⚠ warning: Can't open file /run/host/usr/lib/libdl.so.2 during file-backed mapping note processing
⚠ warning: Can't open file /run/host/usr/lib/libpthread.so.0 during file-backed mapping note processing
⚠ warning: Can't open file /run/host/usr/lib/ld-linux-x86-64.so.2 during file-backed mapping note processing
⚠ warning: core file may not match specified executable file.
[New LWP 5913]
[New LWP 5867]
[New LWP 5862]
[New LWP 5914]
[New LWP 5972]
[New LWP 5974]
[New LWP 5975]
⚠ warning: Could not load shared library symbols for 5 libraries, e.g. /usr/lib/pressure-vessel/overrides/lib/x86_64-linux-gnu/libpthread.so.0.
Use the "info sharedlibrary" command to see the complete listing.
Do you need "set solib-search-path" or "set sysroot"?
Downloading 1.26 M separate debug info for /lib64/ld-linux-x86-64.so.2
Core was generated by `C:\windows\system32\services.exe                                              '.
Program terminated with signal SIGSEGV, Segmentation fault.
#0  0x00007f8dd6081430 in save_context ()
   from /home/fred/.local/share/Steam/compatibilitytools.d/GE-Proton10-17/files/bin/../lib/wine/x86_64-unix/ntdll.so
[Current thread is 1 (LWP 5913)]
(gdb)
(gdb) info sharedlibrary
From                To                  Linker NS Syms Read   Shared Object Library
../../gdb/solib-svr4.c:3640: internal-error: find_debug_base_for_solib: Assertion `solib->objfile != nullptr' failed.
A problem internal to GDB has been detected,
further debugging may prove unreliable.
----- Backtrace -----
0x55e349e26c01 ???
0x55e34a452a44 ???
0x55e34a93cc51 ???
0x55e34a33243b ???
0x55e34a335e90 ???
0x55e34a34298e ???
0x55e34a3430d6 ???
0x55e349e6e277 ???
0x55e34a40d4e6 ???
0x55e349fa8061 ???
0x55e349fa8148 ???
0x55e349fa0b35 ???
0x7fe858e604b6 rl_callback_read_char
0x55e349fa3613 ???
0x55e349fa7de1 ???
0x55e34a4506cf ???
0x55e34a945f05 ???
0x55e34a94636c ???
0x55e34a115659 ???
0x55e349cda334 ???
0x7fe857a27740 ???
0x7fe857a27878 __libc_start_main
0x55e349cf7d34 ???
0xffffffffffffffff ???
This is a bug, please report it.  For instructions, see:
<https://www.gnu.org/software/gdb/bugs/>.
Create a core file of GDB? (y or n)
Please provide your system information in accordance with forum guidelines. :point_down:
inxi -zv8 (short-form)
Your privacy is respected
What is a Quark?
The issue is clearly WINE-related, and Steam is involved. The topic has been moved to a more appropriate Support category.
 inxi -zv8
  Kernel: 6.12.95-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
    root=UUID=ddd0a425-4318-460a-8a6e-486102175cb6 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.6.6 tk: Qt v: N/A info: frameworks v: 6.27.0
  Type: Desktop System: Gigabyte product: Z390 AORUS PRO v: N/A
    serial: <superuser required>
  Mobo: Gigabyte model: Z390 AORUS PRO-CF v: x.x
    serial: <superuser required> uuid: <superuser required>
    Firmware: UEFI-[Legacy] vendor: American Megatrends v: F12d
    date: 12/18/2019
  System RAM: total: 16 GiB available: 15.55 GiB used: 2.98 GiB (19.2%)
  Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
  Device-1: ChannelA-DIMM0 type: no module installed
  Device-2: ChannelA-DIMM1 type: DDR4 detail: synchronous size: 8 GiB
    speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
    data: 64 total: 64 manufacturer: G.Skill part-no: F4-3200C16-8GVKB
    serial: N/A
  Device-3: ChannelB-DIMM0 type: no module installed
  Device-4: ChannelB-DIMM1 type: DDR4 detail: synchronous size: 8 GiB
    serial: N/A
  Info: model: Intel Core i7-9700K bits: 64 type: MCP arch: Coffee Lake
    gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xC (12) microcode: 0xF8
  Topology: cpus: 1x dies: 1 clusters: 8 cores: 8 smt: <unsupported> cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 4898 min/max: 800/4900 scaling: driver: intel_pstate
    governor: powersave cores: 1: 4898 2: 4898 3: 4898 4: 4898 5: 4898 6: 4898
    7: 4898 8: 4898 bogomips: 57616
    dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
    pln pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap
    smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
  Type: spectre_v2 mitigation: IBRS; IBPB: conditional; STIBP: disabled;
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 [Radeon RX 9070/9070
    XT/9070 GRE] vendor: XFX driver: amdgpu v: kernel arch: RDNA-4
    code: Navi-4x process: TSMC n4 (4nm) built: 2025+ pcie: gen: 5
    speed: 32 GT/s lanes: 16 ports: active: DP-3 empty: DP-1, DP-2, HDMI-A-1,
    Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:7550 class-ID: 0300
  Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: 0
  Monitor-1: DP-3 model: Dell AW3423DWF serial: <filter> built: 2023 res:
    mode: 3440x1440 hz: 165 scale: 114% (1.15) to: 2991x1252 dpi: 109 gamma: 1.2
    chroma: red: x: 0.710 y: 0.282 green: x: 0.243 y: 0.718 blue: x: 0.145
    y: 0.051 white: x: 0.314 y: 0.329 size: 800x337mm (31.5x13.27")
    diag: 868mm (34.2") modes: 3440x1440, 2560x1440, 1920x1200, 1920x1080,
    1600x1200, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800, 1152x864,
    1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
  EDID-Warnings: 1: parse_edid: unknown tag 112
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi wayland:
    drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 vendor: amd mesa v: 26.1.4-arch1.1 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon RX 9070 XT (radeonsi gfx1201 ACO
    DRM 3.61 6.12.95-1-MANJARO) device-ID: 1002:7550 memory: 15.62 GiB
    unified: no display-ID: :1.0
  API: Vulkan v: 1.4.350 layers: 10 device: 0 type: discrete-gpu name: AMD
    Radeon RX 9070 XT (RADV GFX1201) driver: mesa radv v: 26.1.4-arch1.1
    device-ID: 1002:7550 surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: lact wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel 300/C240 Series Family HD Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl
    bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Navi 48 HDMI/DP Audio
    driver: snd_hda_intel v: kernel pcie: gen: 5 speed: 32 GT/s lanes: 16
    bus-ID: 03:00.1 chip-ID: 1002:ab40 class-ID: 0403
  Device-3: Corsair HS65 SURROUND driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:2
    chip-ID: 1b1c:0a87 class-ID: 0300
  API: ALSA v: k6.12.95-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.7 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
  Local Storage: total: 4.78 TiB used: 1.34 TiB (28.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Western Digital
    model: WD BLACK SN850X 2000GB size: 1.82 TiB block-size: physical: 512 B
    fw-rev: 620311WD temp: 44.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital
    fw-rev: 620331WD temp: 45.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
    tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 500GB
    tech: SSD serial: <filter> fw-rev: 1B6Q scheme: MBR
  ID-5: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 250GB
    size: 232.88 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
  ID-1: / raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
    used: 33.81 GiB (14.5%) fs: btrfs dev: /dev/sdc1 maj-min: 8:33 label: N/A
    uuid: ddd0a425-4318-460a-8a6e-486102175cb6
  ID-2: /home raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
  ID-3: /run/media/fred/M.2-2TB-W raw-size: 1.82 TiB
    size: 1.82 TiB (100.00%) used: 360.59 GiB (19.4%) fs: ntfs
    dev: /dev/nvme0n1p1 maj-min: 259:3 label: M.2-2TB-W uuid: 5BFD0EB944863891
  ID-4: /run/media/fred/M.2A-2TB raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
    used: 978.01 GiB (53.4%) fs: ext4 dev: /dev/nvme1n1p1 maj-min: 259:2
    label: M.2A-2TB uuid: c616db53-89db-417b-a3c1-a4634f601fe3
  ID-5: /var/cache raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
  ID-6: /var/log raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
  ID-1: /dev/sda1 maj-min: 8:1 size: 464.3 GiB fs: ntfs label: Win-SSD
    uuid: 6E9CD26C9CD22DF9
  ID-2: /dev/sda2 maj-min: 8:2 size: 100 MiB fs: vfat label: N/A
    uuid: 36E3-4747
  ID-3: /dev/sda3 maj-min: 8:3 size: 546 MiB fs: ntfs label: N/A
    uuid: 36F68638F685F7FF
  ID-4: /dev/sdb1 maj-min: 8:17 size: 465.76 GiB fs: btrfs label: N/A
    uuid: 6a467700-54b8-4ea5-8683-27c42c3ff458
  Device-1: 1-10:2 info: Corsair HS65 SURROUND type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
  Hub-2: 1-11:3 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-11.4:5 info: Corsair H115i Platinum type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 64mA chip-ID: 1b1c:0c13 class-ID: 0000 serial: <filter>
  Device-2: 1-12:4 info: Integrated Express IT8297 RGB LED Controller
    type: keyboard driver: hid-generic,usbhid interfaces: 1 rev: 2.0
    chip-ID: 048d:8297 class-ID: 0301
  Hub-3: 1-13:6 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-13.1:7 info: Logitech G MX518 Gaming Mouse (MU0053)
    type: mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
    chip-ID: 046d:c08e class-ID: 0300 serial: <filter>
  Device-2: 1-13.3:8 info: Turtle Beach Vulcan II TKL Pro type: HID,keyboard
    driver: hid-generic,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 10f5:5001 class-ID: 0300
  Hub-4: 2-0:1 info: super-speed hub ports: 10 rev: 3.1
  System Temperatures: cpu: 40.0 C pch: 56.0 C mobo: N/A gpu: amdgpu
    temp: 45.0 C mem: 46.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
  Packages: pm: pacman pkgs: 1560 libs: 476 tools: octopi,pamac,yay
    pm: flatpak pkgs: 0
    1: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    2: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    3: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    6: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://manjaro.grena.ge/stable/$repo/$arch
    8: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 286
  1: cpu: 7.2% command: freetube pid: 1578 mem: 166.1 MiB (1.0%)
  2: cpu: 5.7% command: zsh pid: 6647 mem: 10.6 MiB (0.0%)
  3: cpu: 4.6% command: konsole pid: 6622 mem: 259.4 MiB (1.6%)
  4: cpu: 4.1% command: firefox pid: 1838 mem: 694.3 MiB (4.3%)
  5: cpu: 3.4% command: kwin_wayland pid: 745 mem: 223.6 MiB (1.4%)
  Memory top: 5 of 286
  1: mem: 694.3 MiB (4.3%) command: firefox pid: 1838 cpu: 4.1%
  2: mem: 388.7 MiB (2.4%) command: easyeffects pid: 1245 cpu: 1.1%
  3: mem: 356.5 MiB (2.2%) command: plasmashell pid: 921 cpu: 0.1%
  4: mem: 343.3 MiB (2.1%) command: firefox pid: 6227 cpu: 1.2%
  5: mem: 296.8 MiB (1.8%) command: firefox pid: 2183 cpu: 0.2%
  Processes: 286 Power: uptime: 1h 36m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.19 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 261 default: graphical
    tool: systemctl
  Compilers: gcc: 16.1.1 Shell: Zsh v: 5.9.1 running-in: konsole
    inxi: 3.3.41
❯ inxi --filter --verbosity=8
    date: 12/18/2019
  System RAM: total: 16 GiB available: 15.55 GiB used: 3 GiB (19.3%)
    serial: N/A
    serial: N/A
  Speed (MHz): avg: 800 min/max: 800/4900 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 bogomips: 57616
    uuid: 36E3-4747
  System Temperatures: cpu: 46.0 C pch: 55.0 C mobo: N/A gpu: amdgpu
    pm: flatpak pkgs: 0
Processes:
  CPU top: 5 of 288
  1: cpu: 7.1% command: freetube pid: 1578 mem: 166.0 MiB (1.0%)
  2: cpu: 6.2% command: konsole pid: 7316 mem: 259.7 MiB (1.6%)
  3: cpu: 4.2% command: firefox pid: 1838 mem: 697.2 MiB (4.3%)
  4: cpu: 3.4% command: kwin_wayland pid: 745 mem: 228.7 MiB (1.4%)
  5: cpu: 2.2% command: freetube pid: 1608 mem: 256.7 MiB (1.6%)
  Memory top: 5 of 288
  1: mem: 697.2 MiB (4.3%) command: firefox pid: 1838 cpu: 4.2%
  3: mem: 371.2 MiB (2.3%) command: firefox pid: 6227 cpu: 2.1%
  4: mem: 357.1 MiB (2.2%) command: plasmashell pid: 921 cpu: 0.1%
  5: mem: 298.2 MiB (1.8%) command: firefox pid: 2183 cpu: 0.2%
  Processes: 288 Power: uptime: 1h 38m states: freeze,mem,disk suspend: deep
    tool: systemctl
    inxi: 3.3.41
Please elaborate. I just know I didnt fiddle with WINE.
Moderator edit: Merged consecutive posts
Could you please elaborate? What does system start mean and why should it include anything like this:
There is not much to elaborate on; services.exe certainly isn’t a Linux executable:
And it seems that WINE, which is used by Proton/Steam, is (as said) involved:
Additionally, a cursory Internet Search reveals this apparent crashing is not specific to Manjaro; this is the most recent reference I’ve found that is Arch-related – meaning, it was reported on an Arch Linux (or derivative) installation:
I note that the resolution for some was to completely remove Steam – and it’s configuration files – reboot, and install Steam again.
Whether this might resolve the issue in your case, remains to be seen.
as mentioned in the linked thread there was a change in the mesa/vulkan package.
So you can reinstall/update mesa package (which helped me a bit ago) or try the solution from the thread:
VK_ICD_FILENAMES=/usr/share/vulkan/icd.d/radeon_icd.i68.json:/usr/share/vulkan/icd.d/radeon_icd.x86_64.json is the environment variable.
It is pointing to only one valid path which is why vulkan-loader fails to find the driver. You can try renaming the file and see if that solves the issue.
sudo mv /usr/share/vulkan/icd.d/radeon_icd.json /usr/share/vulkan/icd.d/radeon_icd.x86_64.json Then you can try vulkaninfo again.
Thanks everyone!
Weirdly this crash came and went so I do not know what it was.
I reinstalled mesa just in case but since the first time the crash message has not appeared again. Can it be a Steam patch fixed it?
I have not started a game (not even when the crash occured) because I rarely play in summertime.
Is there a way to check if the problem persists?
I dont know howto. When I type vulcaninfo in the console it does not know it (stays red).
Thanks, I did not know that. Thanks also for the info that it is Arch related.
