GDM accent color blue instead of Manjaro green
GDM accent color has changed to blue after latest updates.
Is this a global inconsistency?
Kernel: 6.1.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
Desktop: GNOME v: 45.0 Distro: Manjaro Linux base: Arch Linux
Gnome probably changed something …
Can someone check if it is a global inconsistency?
(Do you also have the same issue or is it something local on my side?)
Many THX in advance!
We have removed 1 gnome-shell-maia which compiled GNOME Shell with the Maia accent color. That is the only way to change the accent color in GDM. It ended up causing more problems than it solved.
If one changes the accent color with Custom Accent Colors or Gradience, it will not be able to change the shell theme with gnome-shell-maia installed.
1 Technically still around as a dummy transition package
This topic was automatically closed 24 hours after the last reply. New replies are no longer allowed.
