The update stops and I get the error message of a file conflict:
gcc13: /usr/lib/gcc/x86_64-pc-linux-gnu/lib/libgcc_s.so existiert im Dateisystem (gehört zu gcc12)
gcc13: /usr/lib/gcc/x86_64-pc-linux-gnu/lib/libgcc_s.so.1 existiert im Dateisystem (gehört zu gcc12)
gcc12 cannot be uninstalled:
das Entfernen von gcc12 verletzt Abhängigkeit ‘gcc12’ benötigt von cuda
I will provide further information if necessary. Any recommendations?
Thanks
Either way, any gcc package is only required to build packages, not a runtime dependency. The base-devel package depends on gcc, so you don’t need gcc13, either.
I had used the search before and tried this:
To remove them
sudo pacman -R $(pacman -Qqm)
Then run a full system sync
sudo pacman -Syu
The result was:
Error: The operation could not be performed (Conflicting files) (translated)
Fehler sind aufgetreten, keine Pakete wurden aktualisiert.
how about sudo pacman -R gcc
or, better sudo pacman -Rns gcc
and if it depends on base-devel or something else like cuda - so be it, remove that as well
you can reinstall it afterwards
On a cloned drive I tried various ways to remove gccxx without success.
Removing cuda with
sudo pacman -Rns cuda
Removed cuda, gcc12 and gcc12-libs.
After that, the update ran without any problems. I didn’t have to reinstall Cuda. E.g. Blender continued to use Cuda. Everything was fine - problem solved - thank you for your support.
There are other problems with Cuda now. I know whether it has anything to do with this. However, I would no longer see removing Cuda as a solution to the gcc problem.
Is there another way to resolve the conflict with gcc12 and gcc13? So far removing gcc hasn’t worked.
