GCC incorrect compilation when targeting native goldmont-plus
When trying to run dsda-doom, or its fork nyan-doom or gzdoom/uzdooom-git compiled with AUR’s pkgbuild, with the flag -march=goldmont-plus, both results in segmentation fault. Some ports can get to the menu but whenever it reachs to a ingame scenario, it results in a crash.
log from a failed nyan-doom run:
ALSA lib pcm.c:2722:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.front
ALSA lib pcm.c:2722:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2722:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2722:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm.c:2722:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround21
ALSA lib pcm.c:2722:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround40
ALSA lib pcm.c:2722:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround41
ALSA lib pcm.c:2722:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround50
ALSA lib pcm.c:2722:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround51
ALSA lib pcm.c:2722:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround71
ALSA lib pcm.c:2722:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.iec958
ALSA lib confmisc.c:1377:(snd_func_refer) Unable to find definition 'cards.0.pcm.hdmi.0:CARD=0,AES0=4,AES1=130,AES2=0,AES3=2'
ALSA lib conf.c:5205:(_snd_config_evaluate) function snd_func_refer returned
ALSA lib conf.c:5728:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2722:(snd_pcm_open_noupdate) Unknown PCM hdmi
ALSA lib conf.c:5205:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib pcm.c:2722:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2722:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
ALSA lib pcm_oss.c:404:(_snd_pcm_oss_open) Cannot open device /dev/dsp
ALSA lib pcm_a52.c:1036:(_snd_pcm_a52_open) a52 is only for playback
ALSA lib conf.c:5695:(snd_config_expand) Unknown parameters {AES0 0x6 AES1 0x82 AES2 0x0 AES3 0x2 CARD 0}
ALSA lib pcm.c:2722:(snd_pcm_open_noupdate) Unknown PCM iec958:{AES0 0x6 AES1 0x82 AES2 0x0 AES3 0x2 CARD 0}
ALSA lib confmisc.c:160:(snd_config_get_card) Invalid field card
ALSA lib pcm_usb_stream.c:481:(_snd_pcm_usb_stream_open) Invalid card 'card'
ALSA lib pcm_dmix.c:1000:(snd_pcm_dmix_open) unable to open slave
The game has crashed!
Please report the following information: Segmentation fault (0x0000)
Atleast some of those ALSA errors appear trivial as running these applications compiled with -march=x86-64-v2 results in a normal run.
So far these are the only programs these errors are encountered.
This system’s cpu is a Celeron N4020c
Welcome to the Manjaro community @menguele
Update Announcements
System Information
inxi --filter --verbosity=8
inxi -zv8
Required reading
Resources
When you encounter such issue - go to the source https://gcc.gnu.org - the development team will have more insight into the matter than any member of this forum.
Comment on AUR page does not mention use of -march=goldmont-plus or -march=x86-64-v2
AUR (en) - nyan-doom
menguele commented on [2025-11-02 06:20 (UTC)
Compile but when running DOOM or any mod/map it returns:
$ pamac info nyan-doom
Version               : 1.4.0-1
Description           : A cuddly fork of DSDA, with an emphasis on innovative and QoL features.
URL                   : https://github.com/andrikpowell/nyan-doom
Licences              : GPL2
Repository            : AUR
$ pamac info dsda-doom
Version               : 0.29.4-1
Description           : Fork of PrBoom+ with extra tooling for demo recording and playback, with a focus on speedrunning
URL                   : https://github.com/kraflab/dsda-doom
Licences              : GPL
Repository            : AUR
Is it even worth it?
To investige this?
Would not have -march=native have sufficed?
… I have spent way too much time on Gentoo and the like.
None of this optimization will make a noticable difference to you.
None of it. :wink:
