При игре в Garry`s Mod первые 10 минут всё нормально, потом чёрный экран и система перестаёт отвечать
Kernel: 5.15.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=c4444d52-5d6c-4291-baef-69a9b2663d72 rw quiet apparmor=1
security=apparmor resume=UUID=234570bc-a9a2-4436-9468-14e557ecc336
udev.log_priority=3
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: N/A v: N/A
serial: <superuser required> Chassis: type: 3 serial: <superuser required>
Mobo: Gigabyte model: 970A-DS3P serial: <superuser required>
UEFI: American Megatrends v: F1 date: 04/08/2013
RAM: total: 7.73 GiB used: 2.23 GiB (28.9%)
RAM Report:
Info: model: AMD FX-6300 bits: 64 type: MT MCP arch: Piledriver
family: 0x15 (21) model-id: 2 stepping: 0 microcode: 0x6000852
Topology: cpus: 1x cores: 6 smt: enabled cache: L1: 288 KiB
desc: d-6x16 KiB; i-3x64 KiB L2: 6 MiB desc: 3x2 MiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1505 high: 1986 min/max: 1400/3500 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1422 2: 1986
3: 1406 4: 1406 5: 1406 6: 1406 bogomips: 42212
Flags: 3dnowprefetch abm aes aperfmperf apic arat avx bmi1 clflush cmov
cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists
extapic extd_apicid f16c flushbyasid fma fma4 fpu fxsr fxsr_opt ht
hw_pstate ibpb ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor
msr mtrr nodeid_msr nonstop_tsc nopl npt nrip_save nx osvw pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni
popcnt pse pse36 rdtscp rep_good sep skinit ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 svm svm_lock syscall tbm tce topoext tsc tsc_scale vmcb_clean
vme vmmcall wdt xop xsave
disabled, RSB filling
Device-1: AMD Cayman PRO [Radeon HD 6950] vendor: PC Partner Limited
driver: radeon v: kernel bus-ID: 01:00.0 chip-ID: 1002:6719 class-ID: 0300
Display: x11 server: X.org 1.21.1.3 compositor: kwin_x11 driver:
loaded: ati,radeon unloaded: modesetting alternate: fbdev,vesa
Device-1: AMD SBx00 Azalia vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 00:14.2 chip-ID: 1002:4383 class-ID: 0403
Device-2: AMD Cayman/Antilles HDMI Audio [Radeon HD 6930/6950/6970/6990]
vendor: PC Partner Limited driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 1002:aa80 class-ID: 0403
Sound Server-1: ALSA v: k5.15.19-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.45 running: no
vendor: Gigabyte driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 763.85 GiB used: 179.39 GiB (23.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD3200AAKS-00L9A0 size: 298.09 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 3E01
scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST500LM012 HN-M500MBB
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: <unknown> type: HDD rpm: 5400 serial: <filter> rev: 0002
scheme: GPT
Optical-1: /dev/sr0 vendor: ASUS model: SDRW-08D2S-U rev: A801
dev-links: cdrom
ID-1: / raw-size: 456.66 GiB size: 448.43 GiB (98.20%)
used: 179.39 GiB (40.0%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: c4444d52-5d6c-4291-baef-69a9b2663d72
used: 288 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
uuid: A324-3A23
dev: /dev/sdb3 maj-min: 8:19 label: swap
uuid: 234570bc-a9a2-4436-9468-14e557ecc336
ID-1: /dev/sda1 maj-min: 8:1 size: 450 MiB fs: ntfs
label: \xd0\x92\xd0\xbe\xd1\x81\xd1\x81\xd1\x82\xd0\xb0\xd0\xbd\xd0\xbe\xd0\xb2\xd0\xb8\xd1\x82\xd1\x8c
uuid: A06E2F366E2F051E
ID-2: /dev/sda2 maj-min: 8:2 size: 100 MiB fs: vfat label: N/A
uuid: 7E31-23E8
ID-3: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/sda4 maj-min: 8:4 size: 296.97 GiB fs: ntfs label: N/A
uuid: 823033FB3033F4AF
ID-5: /dev/sda5 maj-min: 8:5 size: 576 MiB fs: ntfs label: N/A
uuid: BAB48455B48415D3
Hub-1: 1-0:1 info: Full speed or root hub ports: 5 rev: 2.0 speed: 480 Mb/s
Device-1: 1-1:2 info: MediaTek Slim Portable DVD Writer type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 0e8d:1887 class-ID: 0802 serial: <filter>
Hub-2: 2-0:1 info: Full speed or root hub ports: 5 rev: 2.0
Hub-3: 3-0:1 info: Full speed or root hub ports: 4 rev: 2.0
Hub-4: 4-0:1 info: Full speed or root hub ports: 5 rev: 1.1 speed: 12 Mb/s
chip-ID: 1d6b:0001 class-ID: 0900
Hub-5: 5-0:1 info: Full speed or root hub ports: 5 rev: 1.1 speed: 12 Mb/s
Hub-6: 6-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-7: 7-0:1 info: Full speed or root hub ports: 4 rev: 1.1 speed: 12 Mb/s
Device-1: 7-3:2 info: Elan Micro Gaming KB type: Keyboard
power: 100mA chip-ID: 04f3:152e class-ID: 0301
Device-2: 7-4:3 info: [Maxxter] Optical gaming mouse type: Mouse,Keyboard
power: 100mA chip-ID: 18f8:0f99 class-ID: 0301
Hub-8: 8-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-9: 8-1:2 info: VIA Labs Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 2109:3431 class-ID: 0900
Hub-10: 9-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 37.8 C mobo: N/A gpu: radeon temp: 57.0 C
Processes: 226 Uptime: 12m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1280 pacman: 1273 lib: 353
flatpak: 0 snap: 7 Shell: Zsh v: 5.8 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.12
