I am in X set the gamma to .40, iy resets mainly after reboot, why?
X and Wayland reload defaults on reboot unless your settings are stored in a permanent config.
An alternative would be to set your active monitors gamma after your reboot:
xrandr --output "$(xrandr --listmonitors | awk '/\*/{print $NF}')" --gamma 0.40:0.40:0.40
Save that and rename it set-gamma-0.4
chmod +x set-gamma-0.4
Now move that somewhere in your $PATH
mv set-gamma-0.4 ~/.local/bin
System Settings
Startup and Shutdown
Autostart
Add Script
select by navigating to ~/.local/bin and find set-gamma-0.4
Thabks, wjen will we beable to set gamma & contrast in Wayland?
kgamma2 is a Wayland-replacement for kgamma:
It is still in its development stage, but it can be installed from the AUR if you want to test it:
pamac info kgamma2-git
⯠pamac info kgamma2-git
Version : r17.beaa5f2885-1
Description : Adjust your monitor gamma settings in a Wayland session
URL : https://invent.kde.org/davidedmundson/kgamma2
Licenses : LGPL-2.1-or-later
Repository : AUR
Groups : --
Depends On : ki18n lcms2 libkscreen qt6-base qt6-declarative
Optional Dependencies : --
Make Dependencies : git cmake extra-cmake-modules kirigami
Check Dependencies : --
Provides : --
Replaces : kgamma2
Conflicts With : kgamma2
Maintainer : C0rn3j
First Submitted : Thu 13 Aug 2026 21:29:37
Last Modified : Thu 13 Aug 2026 21:29:37
Votes : 0
Out of Date : --
The Git page:
@scotty65 Sorry, accidentaly flagged your post Canât unflag, no harm meant, is Kgamma 2 out of beta/
As I mentioned, it is still in development phase, but it does work (according to the developer). You would be best served by reading the article posted by the developer that I linked to in my post - that explains everything.
Something to also note (from the same article):
So, it will likely have to be explicitly installed by users. It wonât just arrive one day in a Plasma update.
As a bit of reassurance, I never saw a flag & there isnât a record of one, so no harm done either. ![]()
Maybe it was a pirate flag. ![]()
RRRRR, you salty dogâŠ
The hotdog might be a Bicky burger sideways, you never know.
When is this being release, my vision needs help. Since all hate XLibre, no gamma adjust anymore.
Did you have problems building kgamma2-git on your system?
I just installed it on my Unstable branch system with no issues encountered:
pamac build kgamma2-git
⯠pamac build kgamma2-git
Preparing...
Checking kgamma2-git dependencies...
Resolving dependencies...
Checking inter-conflicts...
To build (1):
kgamma2-git r17.beaa5f2885-1 AUR
Edit build files : [e]
Apply transaction ? [e/y/N] y
Cloning kgamma2-git build files...
Generating kgamma2-git information...
Authenticating as: Scott (scotty)
Password:
Building kgamma2-git...
==> Making package: kgamma2-git r17.beaa5f2885-1 (Tue 15 Sep 2026 07:13:12)
==> Retrieving sources...
-> Cloning kgamma2 git repo...
Cloning into bare repository '/var/tmp/pamac-build-scotty/kgamma2-git/kgamma2'...
warning: redirecting to https://invent.kde.org/davidedmundson/kgamma2.git/
remote: Enumerating objects: 118, done.
remote: Total 118 (delta 0), reused 0 (delta 0), pack-reused 118 (from 1)
Receiving objects: 100% (118/118), done.
Resolving deltas: 100% (70/70), done.
kgamma2 ... Skipped
==> Extracting sources...
-> Creating working copy of kgamma2 git repo...
Cloning into 'kgamma2'...
done.
==> Starting pkgver()...
==> Starting build()...
-- The CXX compiler identification is GNU 16.2.1
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- No Qt5 qmake executable found. Can't check QT_INSTALL_PREFIX
-- Found Python3: /usr/bin/python3.14 (found version "3.14.7") found components: Interpreter
Installing in /usr. Run /var/tmp/pamac-build-scotty/kgamma2-git/src/build/prefix.sh to set the environment for kgamma_wayland.
-- Setting build type to 'Debug' as none was specified.
-- Looking for __GLIBC__
-- Looking for __GLIBC__ - found
-- Performing Test _OFFT_IS_64BIT
-- Performing Test _OFFT_IS_64BIT - Success
-- Performing Test HAVE_DATE_TIME
-- Performing Test HAVE_DATE_TIME - Success
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Success
-- Found Threads: TRUE
-- Performing Test HAVE_STDATOMIC
-- Performing Test HAVE_STDATOMIC - Success
-- Found WrapAtomic: TRUE
-- Found OpenGL: /usr/lib/libOpenGL.so
-- Found WrapOpenGL: TRUE
-- Could NOT find WrapVulkanHeaders (missing: Vulkan_INCLUDE_DIR)
-- Found Gettext: /usr/bin/msgmerge (found version "1.0")
-- Found OpenMP_CXX: -fopenmp (found version "5.2")
-- Found OpenMP: TRUE (found version "5.2")
-- Found PkgConfig: /usr/bin/pkg-config (found version "3.0.7")
-- Checking for module 'lcms2'
-- Found lcms2, version 2.19
CMake Warning (author) at /usr/lib/cmake/Qt6Core/Qt6CoreMacros.cmake:3573 (message):
Qt policy QTP0004 is not set: You need qmldir files for each extra
directory that contains .qml files for your module. Check
https://doc.qt.io/qt-6/qt-cmake-policy-qtp0004.html for policy details.
Use the qt_policy command to set the policy and suppress this warning.
Call Stack (most recent call first):
/usr/lib/cmake/Qt6Qml/Qt6QmlMacros.cmake:4040 (__qt_internal_setup_policy)
/usr/lib/cmake/Qt6Qml/Qt6QmlMacros.cmake:1035 (qt6_target_qml_sources)
/usr/lib/cmake/Qt6Qml/Qt6QmlMacros.cmake:1513 (qt6_add_qml_module)
CMakeLists.txt:40 (qt_add_qml_module)
This warning is for project developers. Use -Wno-author to suppress it.
-- Configuring done (2.5s)
-- Generating done (0.0s)
-- Build files have been written to: /var/tmp/pamac-build-scotty/kgamma2-git/src/build
[ 9%] Copying kgamma_wayland qml sources into build dir
[ 9%] Populating .qmlls.ini file at /var/tmp/pamac-build-scotty/kgamma2-git/src/build/.qt/.qmlls.build.ini
[ 9%] Built target kgamma_wayland_copy_qml
[ 13%] Copying kgamma_wayland qml resources into build dir
[ 13%] Built target generate_qmlls_build_ini_file
[ 13%] Built target kgamma_wayland_copy_res
[ 13%] Built target kgamma_wayland_autogen_timestamp_deps
[ 18%] Automatic MOC and UIC for target kgamma_wayland
[ 18%] Built target kgamma_wayland_autogen
[ 27%] Running rcc for resource kgamma_wayland_raw_qml_0
[ 27%] Running AUTOMOC file extraction for target kgamma_wayland
[ 31%] Running rcc for resource qmake_KGammaWayland
[ 36%] Generating .rcc/qmlcache/kgamma_wayland_qmlcache_loader.cpp
[ 40%] Running moc --collect-json for target kgamma_wayland
[ 45%] Generating meta_types/qt6kgamma_wayland_metatypes.json
[ 50%] Automatic QML type registration for target kgamma_wayland
[ 54%] Generating .rcc/qmlcache/kgamma_wayland_qml_Main_qml.cpp, .rcc/qmlcache/kgamma_wayland_qml_Main_qml.cpp.aotstats
[ 63%] Building CXX object CMakeFiles/kgamma_wayland.dir/kgamma_wayland_autogen/mocs_compilation.cpp.o
[ 63%] Building CXX object CMakeFiles/kgamma_wayland.dir/main.cpp.o
[ 68%] Building CXX object CMakeFiles/kgamma_wayland.dir/correctionsettings.cpp.o
[ 72%] Building CXX object CMakeFiles/kgamma_wayland.dir/screenprofilemanager.cpp.o
[ 77%] Building CXX object CMakeFiles/kgamma_wayland.dir/kgamma_wayland_qmltyperegistrations.cpp.o
[ 81%] Building CXX object CMakeFiles/kgamma_wayland.dir/.qt/rcc/qrc_qmake_KGammaWayland.cpp.o
[ 86%] Building CXX object CMakeFiles/kgamma_wayland.dir/.rcc/qmlcache/kgamma_wayland_qmlcache_loader.cpp.o
[ 90%] Building CXX object CMakeFiles/kgamma_wayland.dir/.rcc/qmlcache/kgamma_wayland_qml_Main_qml.cpp.o
[ 95%] Building CXX object CMakeFiles/kgamma_wayland.dir/.qt/rcc/qrc_kgamma_wayland_raw_qml_0.cpp.o
[100%] Linking CXX executable kgamma_wayland
[100%] Built target kgamma_wayland
==> Entering fakeroot environment...
==> Starting package()...
-- Install configuration: "Debug"
-- Installing: /var/tmp/pamac-build-scotty/kgamma2-git/pkg/kgamma2-git/usr/bin/kgamma_wayland
-- Set non-toolchain portion of runtime path of "/var/tmp/pamac-build-scotty/kgamma2-git/pkg/kgamma2-git/usr/bin/kgamma_wayland" to "$ORIGIN:$ORIGIN/../lib"
==> Tidying install...
-> Removing libtool files...
-> Removing static library files...
-> Purging unwanted files...
-> Stripping unneeded symbols from binaries and libraries...
-> Compressing man and info pages...
==> Checking for packaging issues...
==> WARNING: Package contains reference to $srcdir
==> Creating package "kgamma2-git"...
-> Generating .PKGINFO file...
-> Generating .BUILDINFO file...
-> Generating .MTREE file...
-> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: kgamma2-git r17.beaa5f2885-1 (Tue 15 Sep 2026 07:13:28)
==> Cleaning up...
Checking keyring... [1/1]
Checking integrity... [1/1]
Loading packages files... [1/1]
Checking file conflicts... [1/1]
Checking available disk space... [1/1]
Installing kgamma2-git (r17.beaa5f2885-1)... [1/1]
It successfully opened after installation. The command to run it is kgamma_wayland (note that it uses an underscore _, not a hyphen -):
Nope, didnât install tet, I will do it know. So will it upgrade next sys update? Is it almost out of beta? Where do I get the package, can I donload it then build it with 1 comand?
How long is a piece of string? ![]()
What I mean to say is â please ask the developer.
Not automatically until Arch moves it from the AUR into the repos, and it then arrives in Manjaroâs repos (unless the Manjaro team decide to add it to the repos themselves - very unlikely while it is still in development).
In the meantime, you should follow the regular advice provided here regarding AUR packages - rebuild it by running the pamac build kgamma2-git command again after doing a system update (especially if the update includes KDE/Plasma or Qt packages).
As the package is in the AUR, running pamac build kgamma2-git will download the PKGBUILD which contains the information required to build the package on your system, and then build the package for you.
What is the progress? My eyes are going⊠![]()
