Gamescope stopped working
I am having the exact same problem since that same update. I even tried a simple gamescope -- vkcube and got
gamescope: types/wlr_linux_dmabuf_v1.c:532: feedback_compile: Assertion `table_len > 0' failed.
No idea where to begin to troubleshoot this. It was working before without issue. I also tried gamescope-plus and some other random versions in the repos, but none worked.
A new support post with the required info (see OP) would be the correct approach, both your situations might be completely different.
When starting an investigation, the best way I’ve found is past the error in a search engine, see what might be relevant, check versions of packages, check what solutions people post.
When unsure what the best approach is, not al distributions are the same… post about it and ask advice.
types/wlr_linux_dmabuf_v1.c:526: feedback_compile: Assertion `table_len > 0' failed. · Issue #1218 · ValveSoftware/gamescope · GitHub seems to suggest that it has been seen and a new version is being prepared/released. If this solves your specific issue is not a given.
Instead of hijacking an old thread, start your own. You can get better help there.
Please provide inxi -zv8 so we can try to help you.
Sorry, I thought adding to that post would be the correct approach, specially considering my problem started at the same time.
(I actually wanted to reply to it right after it was posted, but realised too late my previous forum account doesn’t exist anymore, and got distracted while waiting for a password reset email that obviously never came. But anyway.)
I had seen that github issue before but didn’t think it could be related, given it only started happening to me about a year after it was posted there, so I thought maybe there was something else that changed in the update before last.
I’m not very familiar with downgrading packages though (as the last post on the github thread suggests for a workaround).
> inxi -zv8
  Kernel: 6.12.12-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=e5ae375f-b004-40eb-9a0d-a705dd99a2d0 rw quiet
    udev.log_priority=3 mitigations=off pci=noaer
  Desktop: bspwm v: 0.9.10 with: polybar tools: avail: i3lock vt: 2 dm:
    1: LightDM v: 1.32.0 note: stopped 2: SDDM Distro: Manjaro base: Arch Linux
  Mobo: ASUSTeK model: PRIME B460M-A v: Rev 1.xx
    UEFI: American Megatrends v: 1605 date: 04/07/2021
  System RAM: total: 16 GiB available: 15.53 GiB used: 3.05 GiB (19.7%)
  Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
  Device-1: ChannelA-DIMM1 type: no module installed
  Device-2: ChannelA-DIMM2 type: DDR4 detail: synchronous size: 8 GiB
    speed: 2133 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
    data: 64 total: 64 manufacturer: Corsair part-no: CMK8GX4M1A2666C16
    serial: N/A
  Device-3: ChannelB-DIMM1 type: no module installed
  Device-4: ChannelB-DIMM2 type: DDR4 detail: synchronous size: 8 GiB
    serial: N/A
  Info: model: Intel Core i5-10400 bits: 64 type: MT MCP arch: Comet Lake
    gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
    model-id: 0xA5 (165) stepping: 3 microcode: 0xFC
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
    smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
    desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 2401 min/max: 800/4300 scaling: driver: intel_pstate
    governor: powersave cores: 1: 2401 2: 2401 3: 2401 4: 2401 5: 2401 6: 2401
    7: 2401 8: 2401 9: 2401 10: 2401 11: 2401 12: 2401 bogomips: 69629
    dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht hwp
    hwp_act_window hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt
    invpcid lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
    nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
    pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep
    ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust
    tsc_deadline_timer vme x2apic xgetbv1 xsave xsavec xsaveopt xsaves
    xtopology xtpr
  Type: gather_data_sampling status: Vulnerable
  Type: itlb_multihit status: KVM: VMX unsupported
  Type: mmio_stale_data status: Vulnerable
  Type: retbleed status: Vulnerable
  Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
    usercopy barriers only; no swapgs barriers
  Type: spectre_v2 status: Vulnerable; IBPB: disabled; STIBP: disabled;
    PBRSB-eIBRS: Vulnerable; BHI: Vulnerable
  Type: srbds status: Vulnerable
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX
    470/480/570/570X/580/580X/590] vendor: ASRock driver: amdgpu v: kernel
    arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20 pcie:
    gen: 3 speed: 8 GT/s lanes: 16 ports: active: DP-1,DP-2,HDMI-A-1
    empty: DP-3,DVI-D-1 bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300
    temp: 54.0 C
  Device-2: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.4:13
    chip-ID: 046d:082d class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.15 with: Xwayland v: 24.1.5
    compositor: Picom v: 12.5 driver: X: loaded: amdgpu unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 6400x1814 s-dpi: 96 s-size: 1694x480mm (66.69x18.90")
    s-diag: 1761mm (69.32")
  Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,top-center
    model: Dell P2421D serial: <filter> built: 2020 res: mode: 2560x1440 hz: 60
    scale: 100% (1) dpi: 123 gamma: 1.2 chroma: red: x: 0.663 y: 0.329 green:
    x: 0.302 y: 0.616 blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9
    modes: 2560x1440, 1920x1200, 2048x1080, 1920x1080, 1600x1200, 1680x1050,
    1280x1024, 1440x900, 1280x800, 1152x864, 1280x720, 1024x768, 800x600,
    720x576, 720x480, 640x480, 720x400
  Monitor-2: DP-2 mapped: DisplayPort-1 pos: top-left model: DP1080P60
    built: 2018 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 102 gamma: 1.2
    chroma: red: x: 0.651 y: 0.337 green: x: 0.282 y: 0.604 blue: x: 0.141
    y: 0.071 white: x: 0.314 y: 0.329 size: 480x270mm (18.9x10.63")
    diag: 595mm (23.4") ratio: 16:9 modes: 1920x1080, 3840x2160, 2560x1600,
    2560x1440, 1920x1200, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800,
    1152x864, 1280x720, 1024x768, 800x600, 640x480
  Monitor-3: HDMI-A-1 mapped: HDMI-A-0 pos: bottom-r model: Cintiq 13HD
    serial: <filter> built: 2017 res: mode: 1920x1080 hz: 60 scale: 100% (1)
    dpi: 166 gamma: 1.2 chroma: red: x: 0.651 y: 0.337 green: x: 0.329
    y: 0.608 blue: x: 0.149 y: 0.047 white: x: 0.314 y: 0.337
    size: 293x165mm (11.54x6.5") diag: 336mm (13.2") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960, 1360x768,
    1280x800, 1280x768, 1280x720, 1024x768, 800x600, 640x480
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 570 Series (radeonsi
    polaris10 LLVM 19.1.7 DRM 3.59 6.12.12-2-MANJARO) device-ID: 1002:67df
    memory: 3.91 GiB unified: no
  API: Vulkan v: 1.4.303 layers: 11 device: 0 type: discrete-gpu name: AMD
    Radeon RX 570 Series (RADV POLARIS10) driver: N/A device-ID: 1002:67df
    surfaces: xcb,xlib
  Info: Tools: api: eglinfo, glxinfo, vulkaninfo de: xfce4-display-settings
    gpu: amdgpu_top,radeontop x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Comet Lake PCH-V cAVS vendor: ASUSTeK driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
    chip-ID: 8086:a3f0 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Ellesmere HDMI Audio [Radeon
    RX 470/480 / 570/580/590] vendor: ASRock driver: snd_hda_intel v: kernel
    pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0
    class-ID: 0403
  Device-3: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4.3:12
    chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
  Device-4: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
  API: ALSA v: k6.12.12-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: off tools: pw-cli
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active
    with: pulseaudio-alsa type: plugin tools: pacat,pactl,pamixer,pavucontrol
    vendor: ASUSTeK RTL8111H driver: N/A modules: r8169 pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 04:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  Device-2: Intel 82574L Gigabit Network driver: e1000e v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 05:00.0
    chip-ID: 8086:10d3 class-ID: 0200
  IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IP v6: <filter> virtual: proto kernel_ll scope: link
  Info: services: NetworkManager, sshd, systemd-timesyncd
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4.1:8 chip-ID: 0bda:8771
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.1
    lmp-v: 10 status: discoverable: no pairing: no class-ID: 6c0104
  Local Storage: total: 2.8 TiB used: 1.35 TiB (48.1%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480GB
    size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 6315 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37480G
    tech: SSD serial: <filter> fw-rev: 0107 scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST2000DM008-2FR102
    tech: HDD rpm: 7200 serial: <filter> fw-rev: 0001 scheme: MBR
  ID-4: /dev/sdd maj-min: 8:48 vendor: Crucial model: CT120BX500SSD1
    size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: R013 scheme: GPT
  ID-1: / raw-size: 92.77 GiB size: 90.76 GiB (97.83%) used: 44.3 GiB (48.8%)
    fs: ext4 dev: /dev/sdd3 maj-min: 8:51 label: N/A
    uuid: e5ae375f-b004-40eb-9a0d-a705dd99a2d0
  ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
    used: 288 KiB (0.1%) fs: vfat dev: /dev/sdd1 maj-min: 8:49 label: EFI
    uuid: 3486-3F11
  ID-3: /home raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
    used: 874.92 GiB (47.7%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33 label: N/A
    uuid: 753ea844-52a7-4e43-975a-9a18763e0923
  ID-4: /var/games raw-size: 427.6 GiB size: 419.82 GiB (98.18%)
    used: 258.26 GiB (61.5%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 6f4e603a-d875-446a-8506-76eef2a685d3
  ID-5: /var/games2 raw-size: 432.48 GiB size: 424.63 GiB (98.18%)
    used: 200.75 GiB (47.3%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: N/A
    uuid: 702b559c-2bb9-4915-b1fb-971db0b995fa
  ID-1: swap-1 type: partition size: 3.91 GiB used: 1.43 GiB (36.6%)
    priority: -2 dev: /dev/sdd2 maj-min: 8:50 label: N/A
    uuid: 21555b3b-4d5b-4c11-93c5-b237ece7a615
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-1:2 info: MediaTek 2207117BPG type: still imaging driver: N/A
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 0e8d:200c class-ID: 0601 serial: <filter>
  Hub-2: 1-4:3 info: Microchip (formerly SMSC) USB2734 ports: 5 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0424:2734
  Device-1: 1-4.1:8 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
  Device-2: 1-4.2:10 info: Logitech F710 Wireless Gamepad [XInput Mode]
    type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
    chip-ID: 046d:c21f class-ID: ff00 serial: <filter>
  Device-3: 1-4.3:12 info: C-Media Blue Snowball type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
  Device-4: 1-4.4:13 info: Logitech HD Pro Webcam C920 type: video,audio
  Device-5: 1-4.5:14 info: Microchip (formerly SMSC) Hub Controller
    type: HID driver: hid-generic,usbhid interfaces: 1 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0424:274c
    class-ID: 0300
  Hub-3: 1-6:4 info: Wacom Cintiq 13HD USB Hub ports: 3 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 2mA
    chip-ID: 056a:0305 class-ID: 0900
  Device-1: 1-6.1:11 info: Wacom DTK-1300 [Cintiq 13HD] type: mouse
    driver: usbhid,wacom interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 chip-ID: 056a:0304 class-ID: 0301
  Device-2: 1-6.3:6 info: Silicon Labs CP210x UART Bridge
    type: <vendor specific> driver: cp210x interfaces: 1 rev: 1.1
    chip-ID: 10c4:ea60 class-ID: 0000
  Device-3: 1-7:5 info: SINOWEALTH Game Mouse type: mouse,keyboard
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 256mA chip-ID: 258a:1007 class-ID: 0301
  Device-4: 1-8:7 info: Microdia USB DEVICE type: keyboard,mouse
    lanes: 1 mode: 1.1 power: 400mA chip-ID: 0c45:672e class-ID: 0301
  Device-5: 1-12:9 info: Super Top microSD card reader (SY-T18)
    type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
    chip-ID: 14cd:1212 class-ID: 0806 serial: <filter>
  Hub-4: 2-0:1 info: super-speed hub ports: 8 rev: 3.0
  Hub-5: 2-4:2 info: Microchip (formerly SMSC) USB5734 ports: 2 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0424:5734
  System Temperatures: cpu: 47.5 C mobo: 43.0 C gpu: amdgpu temp: 54.0 C
  Fan Speeds (rpm): fan-1: 1194 fan-2: 1912 fan-3: 0 fan-4: 0 fan-5: 0
    fan-6: 0 fan-7: 0 gpu: amdgpu fan: 1492
  Packages: pm: pacman pkgs: 1947 libs: 496 tools: pamac
    1: https://linorg.usp.br/manjaro/stable/$repo/$arch
    2: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    4: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    6: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    7: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    8: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 324
  1: cpu: 28.9% command: firefox pid: 118975 mem: 578.3 MiB (3.6%)
  2: cpu: 15.0% command: firefox pid: 119288 mem: 287.1 MiB (1.8%)
  3: cpu: 8.6% command: alacritty pid: 123532 mem: 191.0 MiB (1.2%)
  4: cpu: 7.1% command: fish pid: 123549 mem: 14.1 MiB (0.0%)
  5: cpu: 6.1% command: firefox pid: 119221 mem: 378.9 MiB (2.3%)
  Memory top: 5 of 324
  1: mem: 578.3 MiB (3.6%) command: firefox pid: 118975 cpu: 28.9%
  2: mem: 378.9 MiB (2.3%) command: firefox pid: 119221 cpu: 6.1%
  3: mem: 297.9 MiB (1.8%) command: steamwebhelper pid: 5137 cpu: 0.4%
  4: mem: 287.1 MiB (1.8%) command: firefox pid: 119288 cpu: 15.0%
  5: mem: 269.4 MiB (1.6%) command: firefox pid: 119298 cpu: 4.2%
  Processes: 324 Power: uptime: 1h 57m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.19 GiB services: upowerd Init: systemd
    v: 257 default: graphical tool: systemctl
  Compilers: clang: 19.1.7 gcc: 14.2.1 alt: 13 Shell: fish v: 3.7.1
    running-in: alacritty inxi: 3.3.37
downgrade is a package in de extra repo, it can be used (if there is a package in de cache or remote) to downgrade specific packages to test if that solves the issue. This does bring the installation in an unsupported state so this is only a temporary solution.
man downgrade will explain the details.
Edit: the other user had succes with wayland, this might be something to try, however from what I quickly can learn bspwm does not support wayland.
And we also have manjaro-downgrade which should probably be preferred.
Thanks for the replies. I’ll try to figure out if downgrading is possible, temporarily, and it it doesn’t break anything else.
I also just tried building gamescope from the github source instructions and it seems to work >.>
(at least it worked in a quick test with glxgears and heroic)
I guess that’s good news?
Closed as old, abandoned topic.
