Kernel: 5.16.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=97dd37d5-1395-4fe9-91a1-5c5335a75b8a rw nouveau.modeset=0 quiet
splash apparmor=1 security=apparmor udev.log_priority=3
Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Type: Laptop System: ASUSTeK product: ROG Strix G733ZW_G733ZW v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: G733ZW v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: G733ZW.303 date: 12/27/2021
ID-1: BAT0 charge: 88.8 Wh (100.0%) condition: 88.8/88.1 Wh (100.8%)
volts: 17.5 min: 15.6 model: AS3GWYF3KC GA50358 type: Unknown
serial: <filter> status: Full
RAM: total: 31.01 GiB used: 6.96 GiB (22.4%)
RAM Report:
Info: model: 12th Gen Intel Core i9-12900H bits: 64 type: MST AMCP
arch: Alder Lake family: 6 model-id: 0x9A (154) stepping: 3 microcode: 0x413
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 1775 high: 3938 min/max: 400/6300:6400:3800 scaling:
driver: intel_pstate governor: performance cores: 1: 1040 2: 3938 3: 1849
4: 635 5: 1034 6: 1111 7: 976 8: 946 9: 1242 10: 1423 11: 1097 12: 1203
13: 1739 14: 1960 15: 1952 16: 3765 17: 1552 18: 3278 19: 1872 20: 2895
bogomips: 116780
arch_capabilities arch_lbr arch_perfmon art avx avx2 avx_vnni bmi1 bmi2 bts
cat_l2 cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault
cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe
pcid pclmulqdq pconfig pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36
pts rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni
smap smep smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tme tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic
Device-1: Intel Alder Lake-P Integrated Graphics vendor: ASUSTeK
driver: i915 v: kernel bus-ID: 0000:00:02.0 chip-ID: 8086:46a6
class-ID: 0300
Device-2: NVIDIA GA104 [Geforce RTX 3070 Ti Laptop GPU] vendor: ASUSTeK
driver: nvidia v: 510.47.03 alternate: nouveau,nvidia_drm
bus-ID: 0000:01:00.0 chip-ID: 10de:24a0 class-ID: 0300
Display: x11 server: X.Org 1.21.1.3 compositor: gnome-shell driver:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
display-ID: :1 screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1185x381mm (46.7x15.0")
s-diag: 1245mm (49")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
Monitor-2: eDP-1-1 res: 2560x1440 hz: 60 dpi: 171
size: 381x214mm (15.0x8.4") diag: 437mm (17.2")
OpenGL: renderer: NVIDIA GeForce RTX 3070 Ti Laptop GPU/PCIe/SSE2
v: 4.6.0 NVIDIA 510.47.03 direct render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 0000:00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:228b
class-ID: 0403
Sound Server-1: ALSA v: k5.16.7-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.45 running: yes
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
port: 3000 bus-ID: 0000:2c:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp44s0 state: down mac: <filter>
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 3-10:4
chip-ID: 8087:0033 class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 953.87 GiB used: 683.17 GiB (71.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 3400 MTFDKBA1T0TFH
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 type: SSD serial: <filter> rev: P7MA001 temp: 48.9 C scheme: GPT
ID-1: / raw-size: 953.57 GiB size: 937.53 GiB (98.32%)
used: 683.17 GiB (72.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 97dd37d5-1395-4fe9-91a1-5c5335a75b8a
label: NO_LABEL uuid: 0641-9146
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 20 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-3:2 info: ASUSTek N-KEY Device type: Keyboard
driver: asus,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 0b05:19b6 class-ID: 0301
Device-2: 3-6:3 info: Razer USA DeathAdder Elite type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 1532:005c class-ID: 0300
Device-3: 3-10:4 info: Intel type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0033 class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 48.0 C mobo: N/A gpu: nvidia temp: 51 C
Processes: 488 Uptime: 13m wakeups: 2 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 Packages: 1432 pacman: 1415 lib: 468 flatpak: 8
snap: 9 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.12
Hi! I’ve been having issues with only certain games. They were using my iGPU only, and now that I have set my dGPU as the sole renderer (using the ArchWiki, they crash with the following error
X Error of failed request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 149 ()
Minor opcode of failed request: 4
Serial number of failed request: 304
Current serial number in output stream: 309
Today I tried to run Star Citizen and succeeded. However, when I start the game I get a prompt telling me that my default GPU (dGPU) is less powerful than another GPU it found (my iGPU, which is of course way less powerful). If I tell it to launch with the default GPU anyway, it works fine. If I allow it to switch to the iGPU, it crashes with the above error
Is there a way to completely cut off my iGPU so that absolutely nothing recognises it? (I’ve checked my BIOS options, no luck). Or to simply be able to tell a game to actually use my dGPU?
