Games switching audio headset quality
I use bluetooth headphones for audio, and every time I start a game the audio profile gets switched from “High Fidelity Playback” to “Headset Head Unit”. Every time I start a game I have to manually go and switch it back to high fidelity, and if I don’t do it fast enough high fidelity actually disappears from the options and I’m forced to reset my headphones.
I’ve run into this issue on multiple different headphones, though it’s all bluetooth. I just want it to stay on the profile I’ve selected, and I can’t find anyway to disable the other profiles.
I’ve been having this issue literally since I started using Manjaro, and have looked for solutions but somehow just cannot find anything on it. I’d greatly appreciate any solution for this issue.
Welcome to the Manjaro community! It may help of you post some system info e.g. inxi -zv8 and use the </> button at the top of the reply window to format the selected, pasted text. :wink:
This is a known issue with e.g. Skype. When using a BT headset it switches to “telephony” mode (or otherwise known as “muffle mode”).
I too would like to see a solution for that, in other words to force A2DP. I prefer to use the camera’s built-in microphone anyway. It seems quite reliable these days when connecting for media playback (browser or smplayer, etc.) at least with the current LTS kernels. I’m on 6.6 at present.
I guess these games are expecting headset mode, like Skype does. This is still food for thought for me, unfortunately.
Bluetooth headset - Disable PulseAudio auto switching headset to HSP/HFP - Archwiki
Bluetooth headset - Disable PipeWire HSP/HFP profile - ArchWiki
  Kernel: 6.10.13-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64
    root=UUID=ece4606b-53ba-4929-bc72-23d5d06ac209 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
  Type: Desktop System: Gigabyte product: X570 AORUS ELITE v: -CF
    serial: <superuser required>
  Mobo: Gigabyte model: X570 AORUS ELITE serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: F37a
    date: 02/16/2022
  System RAM: total: 32 GiB available: 31.26 GiB used: 6.46 GiB (20.7%)
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 16 GiB speed: 3600 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: G.Skill
    part-no: F4-3600C16-16GTZNC serial: N/A
  Device-3: Channel-B DIMM 0 type: no module installed
  Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 2 microcode: 0xA201205
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 12 threads: 24 tpc: 2
    smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB
    desc: 12x512 KiB L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 3619 min/max: 2200/4950 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 3619 2: 3619 3: 3619
    4: 3619 5: 3619 6: 3619 7: 3619 8: 3619 9: 3619 10: 3619 11: 3619 12: 3619
    13: 3619 14: 3619 15: 3619 16: 3619 17: 3619 18: 3619 19: 3619 20: 3619
    21: 3619 22: 3619 23: 3619 24: 3619 bogomips: 177684
    xsaves xtopology
  Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 21 [Radeon RX 6800/6800 XT
    / 6900 XT] vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2
    code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-3
    empty: DP-2,HDMI-A-1,Writeback-1 bus-ID: 0b:00.0 chip-ID: 1002:73bf
    class-ID: 0300
  Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu d-rect: 6560x4000 display-ID: 0
  Monitor-1: DP-1 pos: bottom-r res: 5120x1440 size: N/A modes: N/A
  Monitor-2: DP-3 pos: primary,top-left res: 1440x2560 size: N/A modes: N/A
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.7-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6800 XT (radeonsi
    navi21 LLVM 18.1.8 DRM 3.57 6.10.13-3-MANJARO) device-ID: 1002:73bf
    memory: 15.62 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.3.295 layers: 9 device: 0 type: discrete-gpu name: AMD
    Radeon RX 6800 XT (RADV NAVI21) driver: mesa radv v: 24.2.7-arch1.1
    device-ID: 1002:73bf surfaces: xcb,xlib,wayland
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
    bus-ID: 0b:00.1 chip-ID: 1002:ab28 class-ID: 0403
    vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Kingston HyperX SoloCast
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-3.1:4 chip-ID: 0951:170f class-ID: 0300
  API: ALSA v: k6.10.13-3-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
  IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:2 chip-ID: 2357:0604
  Local Storage: total: 14.69 TiB used: 2.62 TiB (17.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:2 model: Predator SSD GM7000 4TB
    size: 3.73 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 3.A.J.CR temp: 46.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO with
    Heatsink 2TB size: 1.82 TiB block-size: physical: 512 B logical: 512 B
    speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QGXA7
    temp: 39.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Silicon Power
    model: SPCC Solid State Disk size: 1.86 TiB block-size: physical: 512 B
    logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 6A0
    scheme: MBR
  ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST8000DM004-2CX188
    size: 7.28 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 5425 serial: <filter> fw-rev: 0001 scheme: GPT
  ID-1: / raw-size: 3.63 TiB size: 3.57 TiB (98.40%) used: 2.62 TiB (73.5%)
    fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:7 label: N/A
    uuid: ece4606b-53ba-4929-bc72-23d5d06ac209
    used: 30.7 MiB (32.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
    label: N/A uuid: 3CE2-F9DD
  ID-1: /dev/nvme0n1p2 maj-min: 259:4 size: 16 MiB fs: ext4 label: N/A
    uuid: b57b9ff0-0426-4915-8ba9-1c1eb40cd0fc
  ID-2: /dev/nvme0n1p3 maj-min: 259:5 size: 97.03 GiB fs: ntfs label: N/A
    uuid: F85AF1755AF1314C
  ID-3: /dev/nvme0n1p4 maj-min: 259:6 size: 522 MiB fs: ntfs label: N/A
    uuid: 0CF6F115F6F0FFAE
  ID-4: /dev/nvme1n1p1 maj-min: 259:1 size: 1.82 TiB fs: ext4
    label: 980Pro Storage uuid: ceeb3e45-8d36-458b-ad39-6a50f865b234
  ID-5: /dev/sda1 maj-min: 8:1 size: 1.86 TiB fs: ntfs label: SSD Storage
    uuid: E2606B0E606AE92D
  ID-6: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-7: /dev/sdb2 maj-min: 8:18 size: 7.28 TiB fs: ntfs
    label: Internal Backup uuid: EA2EE6292EE5EE8F
  Hub-2: 1-3:2 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-3.1:4 info: Kingston HyperX SoloCast type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
  Device-2: 1-3.2:5 info: Keychron V6 type: keyboard,HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 3434:0361 class-ID: 0300
  Hub-3: 1-3.3:6 info: Genesys Logic Hub ports: 4 rev: 2.1
  Hub-4: 1-3.3.1:7 info: Genesys Logic Hub ports: 4 rev: 2.1
  Hub-5: 1-3.3.2:8 info: Genesys Logic Hub ports: 4 rev: 2.1
  Device-1: 1-3.3.2.1:10 info: CHERRY XTRFY 1K Mouse Receiver
    type: keyboard,HID,mouse driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046a:0330 class-ID: 0301
  Hub-6: 1-3.3.3:9 info: Genesys Logic Hub ports: 4 rev: 2.1
  Device-1: 1-4:3 info: Integrated Express IT8297 RGB LED Controller
    type: keyboard driver: hid-generic,usbhid interfaces: 1 rev: 2.0
    chip-ID: 048d:8297 class-ID: 0301
  Hub-7: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-8: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 3-4:2 info: TP-Link UB500 Adapter type: bluetooth driver: btusb
    interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 500mA chip-ID: 2357:0604 class-ID: e001 serial: <filter>
  Hub-9: 3-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 3-6.1:4 info: Corsair iCUE Commander ST type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 1b1c:0c32 class-ID: 0300
    serial: <filter>
  Hub-10: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-11: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-12: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 52.1 C mobo: 29.0 C gpu: amdgpu temp: 57.0 C
    mem: 54.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
  Packages: 1579 pm: pacman pkgs: 1563 libs: 432 tools: pamac pm: flatpak
    pkgs: 16
    1: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    2: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    3: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    4: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    5: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    6: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    7: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    8: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 474
  1: cpu: 11.2% command: Discord pid: 45643 mem: 314.8 MiB (0.9%)
  2: cpu: 11.2% command: Discord pid: 45739 mem: 569.1 MiB (1.7%)
  3: cpu: 6.5% command: kwin_wayland pid: 2972 mem: 341.3 MiB (1.0%)
  4: cpu: 4.9% command: brave pid: 49109 mem: 366.8 MiB (1.1%)
  5: cpu: 4.6% command: steam pid: 4818 mem: 429.5 MiB (1.3%)
  Memory top: 5 of 474
  1: mem: 648.7 MiB (2.0%) command: plasmashell pid: 3201 cpu: 4.5%
  2: mem: 570.6 MiB (1.7%) command: ./steamwebhelper pid: 5101 cpu: 0.3%
  3: mem: 569.1 MiB (1.7%) command: Discord pid: 45739 cpu: 11.2%
  4: mem: 552.8 MiB (1.7%) command: steamwebhelper pid: 5205 cpu: 1.9%
  5: mem: 550.3 MiB (1.7%) command: brave pid: 4036 cpu: 0.7%
  Processes: 474 Power: uptime: 5h 5m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.36
I’ll try and remember to add that in the future.
That seems to be the solution, however there’s no default.pa in my /etc/pulse/ folder do you know if I can manually generate it or if I just need to create the file. Please forgive my lack of knowledge, I’m still on the newbie end of the spectrum.
System data shows PipeWire in use rather than PulseAudio
PipeWire - Automatic profile selection - ArchWiki
WirePlumber has profile auto-switching enabled by default. It can automatically switch between HSP/HFP and A2DP profiles whenever an input stream is detected. You can disable it with the following command:
wpctl settings --save bluetooth.autoswitch-to-headset-profile false
Thanks for that. That was my mistake, I still mix up pulse and pipewire. I did get it fixed by creating the file mentioned in the pipewire link you originally sent. Once again thanks for the help, this has been driving me crazy for close to a year now.
