Games on hard drive/mounted drive do not run, but games on main drive do
Hello, incredibly new linux user here (i’ve only used manjaro for ~4 months). I have run into an issue where games installed via steam on my second drive will NOT launch, but when they are moved to my main/OS drive, they boot perfectly. Is there a solution to this besides moving dysfunctional games to my main drive? Any help would be greatly appreciated.
Sound like a classic permissions issue. Do you by any chance dual boot with windows? What filesystem is the second drive and how do you mount it?
Please provide the output of inxi -zv8 using the </> button.
I do not dual boot with windows, the second drive is BTRFS mounted under /mnt/.
  Kernel: 6.12.64-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=afccfe9b-c951-4de7-a5f2-a4d340672ed6 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.5.4 tk: Qt v: N/A info: frameworks v: 6.21.0
  Type: Desktop Mobo: Micro-Star model: MAG X670E TOMAHAWK WIFI (MS-7E12)
    v: 1.0 serial: <superuser required> uuid: <superuser required>
    Firmware: UEFI vendor: American Megatrends LLC. v: 1.F1 date: 08/29/2024
  System RAM: total: 48 GiB available: 46.15 GiB used: 17.78 GiB (38.5%)
  Device-1: DIMMA1 type: no module installed
  Device-2: DIMMA2 type: DDR5 detail: synchronous unbuffered (unregistered)
    size: 24 GiB speed: spec: 4800 MT/s actual: 5200 MT/s volts: note: check
    curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: N/A
    part-no: F5-5200J4040A24G serial: <filter>
  Device-3: DIMMB1 type: no module installed
  Device-4: DIMMB2 type: DDR5 detail: synchronous unbuffered (unregistered)
  Info: model: AMD Ryzen 9 7950X3D bits: 64 type: MT MCP arch: Zen 4 gen: 4
    level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
    model-id: 0x61 (97) stepping: 2 microcode: 0xA60120A
  Topology: cpus: 1x dies: 2 clusters: 2x1 cores: 16 threads: 32 tpc: 2
    smt: enabled cache: L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 16 MiB
    desc: 16x1024 KiB L3: 128 MiB desc: 1x32 MiB, 1x96 MiB
  Speed (MHz): avg: 2982 min/max: 545/5759 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 2982 2: 2982 3: 2982
    4: 2982 5: 2982 6: 2982 7: 2982 8: 2982 9: 2982 10: 2982 11: 2982 12: 2982
    13: 2982 14: 2982 15: 2982 16: 2982 17: 2982 18: 2982 19: 2982 20: 2982
    21: 2982 22: 2982 23: 2982 24: 2982 25: 2982 26: 2982 27: 2982 28: 2982
    29: 2982 30: 2982 31: 2982 32: 2982 bogomips: 268927
    apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
    avx512ifma avx512vbmi avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
    clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cppc cpuid cqm
    cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de
    decodeassists erms extapic extd_apicid f16c flush_l1d flushbyasid fma fpu
    fsgsbase fsrm fxsr fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs
    invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
    movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
    overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
    perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni popcnt pse
    pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
    succor svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk
    v_spec_ctrl vaes vgif vmcb_clean vme vmmcall vnmi vpclmulqdq wbnoinvd wdt
    x2avic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
    conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
    affected
^[[CGraphics:
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900
    XTX/7900 GRE/7900M] vendor: Tul / PowerColor driver: amdgpu v: kernel
    arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie:
    gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-2
    empty: DP-3,HDMI-A-1,Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:744c
    class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: Micro-Star MSI
    driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
    built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
    empty: DP-4, DP-5, DP-6, HDMI-A-2, Writeback-2 bus-ID: 17:00.0
    chip-ID: 1002:164e class-ID: 0300 temp: 48.0 C
  Device-3: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3
    chip-ID: 046d:08e5 class-ID: 0102 serial: <filter>
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu d-rect: 5120x1440 display-ID: 0
  Monitor-1: DP-1 pos: primary,left model: LG (GoldStar) ULTRAGEAR
    serial: <filter> built: 2023 res: mode: 2560x1440 hz: 165 scale: 100% (1)
    dpi: 93 gamma: 1.2 chroma: red: x: 0.667 y: 0.329 green: x: 0.302 y: 0.604
    blue: x: 0.141 y: 0.055 white: x: 0.314 y: 0.329
    size: 697x392mm (27.44x15.43") diag: 800mm (31.5") ratio: 16:9
    modes: 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024,
    1440x900, 1280x800, 1280x720, 1024x768, 800x600, 720x480, 640x480
  EDID-Warnings: 1: parse_edid: unknown tag 112
  Monitor-2: DP-2 pos: right model: LG (GoldStar) ULTRAWIDE serial: <filter>
    built: 2017 res: mode: 2560x1080 hz: 144 scale: 100% (1) dpi: 81 gamma: 1.2
    chroma: red: x: 0.651 y: 0.333 green: x: 0.306 y: 0.631 blue: x: 0.149
    y: 0.059 white: x: 0.314 y: 0.329 size: 798x334mm (31.42x13.15")
    diag: 869mm (34.2") modes: 2560x1080, 4096x2160, 1920x1080, 1680x1050,
    1600x900, 1280x1024, 1440x900, 1280x800, 1152x864, 1280x720, 1024x768,
    832x624, 800x600, 720x480, 640x480
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 90 2: parse_edid:
    unhandled CEA mode 91 3: parse_edid: unhandled CEA mode 92
    device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: radeonsi
    surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.3-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7900 XT (radeonsi
    navi31 LLVM 21.1.6 DRM 3.61 6.12.64-1-MANJARO) device-ID: 1002:744c
    memory: 19.53 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.335 layers: 13 device: 0 type: discrete-gpu name: AMD
    Radeon RX 7900 XT (RADV NAVI31) driver: mesa radv v: 25.3.3-arch1.1
    device-ID: 1002:744c surfaces: N/A device: 1 type: integrated-gpu name: AMD
    Ryzen 9 7950X3D 16-Core Processor (RADV RAPHAEL_MENDOCINO)
    driver: mesa radv v: 25.3.3-arch1.1 device-ID: 1002:164e surfaces: N/A
    device: 2 type: cpu name: llvmpipe (LLVM 21.1.6 256 bits)
    driver: mesa llvmpipe v: 25.3.3-arch1.1 (LLVM 21.1.6)
    device-ID: 10005:0000 surfaces: N/A
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
    bus-ID: 03:00.1 chip-ID: 1002:ab30 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 17:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio
    speed: 16 GT/s lanes: 16 bus-ID: 17:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-4: Conexant Systems (Rockwell) Hi-Res Audio
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-2:2 chip-ID: 0572:1b09 class-ID: 0300
    serial: <filter>
  Device-5: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
  Device-6: Samson Q9U driver: snd-usb-audio type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 17a0:0243
  API: ALSA v: k6.12.64-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 07:00.0
  IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    bus-ID: 0e:00.0 chip-ID: 14c3:0616 class-ID: 0280
  IF: wlp14s0 state: down mac: <filter>
  Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:4 chip-ID: 0e8d:0616
  Local Storage: total: 8.19 TiB used: 4.09 TiB (49.9%)
    model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 111110WD temp: 40.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST8000VN004-3CP101
    size: 7.28 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: SC60 scheme: GPT
  ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
    used: 231.75 GiB (24.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: afccfe9b-c951-4de7-a5f2-a4d340672ed6
    used: 648 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 221E-1FB2
  ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
  ID-4: /mnt/storage raw-size: 7.28 TiB size: 7.28 TiB (100.00%)
    used: 3.86 TiB (53.0%) fs: btrfs dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: a6aeb7c7-baf7-47d7-ba37-8d11dd0a1eea
  ID-5: /var/cache raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
  ID-6: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-2:2 info: Conexant Systems (Rockwell) Hi-Res Audio
    type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 28mA
    chip-ID: 0572:1b09 class-ID: 0300 serial: <filter>
  Device-2: 1-5:3 info: Logitech C920 PRO HD Webcam type: video,audio
  Device-3: 1-7:4 info: Micro Star MYSTIC LIGHT type: HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 0db0:0076 class-ID: 0300
    serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-1:2 info: Samson Q9U type: audio driver: snd-usb-audio
    interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 170mA chip-ID: 17a0:0243 class-ID: 0102 serial: <filter>
  Device-2: 3-5:3 info: USB HID GMMK 2 Full Size 96% type: keyboard,mouse
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 320f:504b class-ID: 0300
  Device-3: 3-7:4 info: MediaTek Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 0e8d:0616 class-ID: e001 serial: <filter>
  Hub-4: 3-10:5 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 3-10.2:7 info: Corsair iCUE Commander CORE type: HID
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 1b1c:0c1c class-ID: 0300 serial: <filter>
  Device-2: 3-10.4:8 info: Corsair HX1000i Power Supply type: HID
    driver: corsair-psu,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 1b1c:1c07 class-ID: 0300
  Hub-5: 3-12:6 info: Genesys Logic Hub ports: 4 rev: 2.0
  Hub-6: 4-0:1 info: super-speed hub ports: 5 rev: 3.1
  Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Device-1: 5-2:2 info: SINOWEALTH Wired Gaming Mouse type: mouse,keyboard
    driver: glorious,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 480mA chip-ID: 258a:0033 class-ID: 0301
  Hub-8: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-9: 7-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Device-1: 7-1:2 info: Google Nexus/Pixel Device (charging + debug)
    type: <vendor specific> driver: usbfs interfaces: 1 rev: 2.1
    chip-ID: 18d1:4ee7 class-ID: 0000 serial: <filter>
  Hub-10: 8-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-11: 9-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  System Temperatures: cpu: 50.5 C mobo: 40.0 C
  Fan Speeds (rpm): N/A
  GPU: device: amdgpu temp: 48.0 C device: amdgpu temp: 48.0 C mem: 58.0 C
    fan: 879 watts: 61.00
  Packages: 1847 pm: pacman pkgs: 1827 libs: 539 tools: pamac,yay pm: flatpak
    pkgs: 20
    1: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    3: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    4: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    5: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    6: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    7: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    8: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 655
  1: cpu: 12.1% command: firefox pid: 24348 mem: 949.7 MiB (2.0%)
  2: cpu: 5.3% command: steam pid: 26174 mem: 526.1 MiB (1.1%)
  3: cpu: 3.3% command: steamwebhelper pid: 26527 mem: 793.1 MiB (1.6%)
  4: cpu: 1.9% command: exe pid: 4394 mem: 671.4 MiB (1.4%)
  5: cpu: 1.7% command: java pid: 8285 mem: 8491.5 MiB (17.9%)
  Memory top: 5 of 655
  1: mem: 8491.5 MiB (17.9%) command: java pid: 8285 cpu: 1.7%
  2: mem: 949.7 MiB (2.0%) command: firefox pid: 24348 cpu: 12.1%
  3: mem: 911.8 MiB (1.9%) command: firefox pid: 35373 cpu: 1.7%
  4: mem: 793.1 MiB (1.6%) command: steamwebhelper pid: 26527 cpu: 3.3%
  5: mem: 773.6 MiB (1.6%) command: falkon pid: 24034 cpu: 0.0%
  Processes: 655 Power: uptime: 14h 28m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 18.44 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
    tool: systemctl
  Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole
    inxi: 3.3.40
Mnt/storage btrfs. Should be an easy fix.
Is this permanently mounted on boot or do you have to click on it in the file manager and are you asked for password when you click on it if this is the case?
Can you also provide /etc/fstab
Permanently mounted on boot.
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
UUID=221E-1FB2                              /boot/efi      vfat    umask=0077                       0 2
UUID=afccfe9b-c951-4de7-a5f2-a4d340672ed6   /              btrfs   subvol=/@,compress=zstd:1        0 0
UUID=afccfe9b-c951-4de7-a5f2-a4d340672ed6   /home          btrfs   subvol=/@home,compress=zstd:1    0 0
UUID=afccfe9b-c951-4de7-a5f2-a4d340672ed6   /var/cache     btrfs   subvol=/@cache,compress=zstd:1   0 0
UUID=afccfe9b-c951-4de7-a5f2-a4d340672ed6   /var/log       btrfs   subvol=/@log,compress=zstd:1     0 0
tmpfs                                       /tmp           tmpfs   noatime,mode=1777                0 0
/dev/sda1                                   /mnt/storage   btrfs   nofail,users                     0 0
Found a solution, simply adding “exec” to my fstab options for the drive fixed it. Thank you @Teo for pointing me in the right direction :saluting_face:
