Hi,
I wish move from Win11 to Manjaro but I having issues.
I’ve a high level pc that I usually use with Windows11.
I installed Manjaro to check if was possible to switch on Linux but both game doesn’t start even if on protondb they seems easy to run.
Any of you knows why?
My Computer Information:
PRIME Z790-P WIFI
CPU Brand: 13th Gen Intel(R) Core™ i5-13600K
Operating System Version:
“Manjaro Linux” (64 bit)
Kernel Version: 6.6.19-1-MANJARO
X Server Release: 12302004
X Window Manager: GNOME Shell
Video Card:
Driver: Mesa NV174
Driver Version: 4.3 (Compatibility Profile) Mesa 24.0.2-manjaro1.1
OpenGL Version: 4.3
Desktop Color Depth: 24 bits per pixel
Monitor Refresh Rate: 59 Hz
RAM: 31838 Mb
PS
Just saw that the video card is not Driver: NVIDIA GeForce RTX 3070 Ti
and the monitor refesh is very low!
Hi @Salvodif ,
I’m guessing you don’t have the correct GPU drivers installed. Please see here:
You might also glean something useful from the ArchWiki:
Additionally, if your BIOS has such an option: Look for PCI-E Speed (or similar) and change it from auto to gen4 or gen5 (whichever may be applicable). This may help once you have your Nvidia driver properly installed.
Cheers.
Nouveau driver installed. Last I heard that is 30% slower than proprietary driver. So I didn’t even bother with it. It’s been around for years, open-source driver.
There is an open-source effort going on called NVK but it is still early days. NVK — The Mesa 3D Graphics Library latest documentation . Idea is you only need Mesa like on AMD. Much easier to deal with.
system
Closed
3 April 2024 21:59
5
