Games don't render on external monitor
About two weeks ago, after some upgrades (Plasma 6.2.4 was part of them), I noticed that full screen games don’t render properly on the external monitor. On the built-in they are fine. On an external monitor the game starts, sound is playing, the game engine seems to be running properly, just the screen is frozen. When I switch to other app with alt+tab and back to the game, I see that another frame was rendered, and it’s frozen.
Is it a plasma issue?
inxi -v7azy
  Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=bb33fe7a-f0ad-4c1f-a738-7e8ee3d7ae11 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
  Type: Laptop System: ASUSTeK product: ROG Zephyrus G14 GA402RK_GA402RK v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: GA402RK v: 1.0 serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: GA402RK.319
    date: 06/06/2023
  ID-1: BAT0 charge: 56.9 Wh (89.5%) condition: 63.6/76.0 Wh (83.7%)
    volts: 15.9 min: 15.9 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
    status: not charging
  Device-1: hidpp_battery_0 model: Logitech Signature M650 serial: <filter>
    charge: 30% rechargeable: yes status: discharging
  System RAM: total: 32 GiB available: 30.58 GiB used: 15.3 GiB (50.0%)
  Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: 4800 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Samsung
    part-no: M425R2GA3BB0-CQKOD serial: N/A
  Device-2: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Hynix
    part-no: HMCG78MEBSA092N serial: <filter>
  Info: model: AMD Ryzen 7 6800HS with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3+ gen: 3 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
    family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404107
    desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1273 min/max: 400/4785 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1273 2: 1273 3: 1273
    4: 1273 5: 1273 6: 1273 7: 1273 8: 1273 9: 1273 10: 1273 11: 1273 12: 1273
    13: 1273 14: 1273 15: 1273 16: 1273 bogomips: 102245
    cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
    x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 23 [Radeon RX 6650 XT /
    6700S 6800S] vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2
    code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1
    empty: DP-1,Writeback-1,eDP-1 bus-ID: 03:00.0 chip-ID: 1002:73ef
    class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt [Radeon 680M]
    vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16
    ports: active: eDP-2 empty: DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, DP-8,
    DP-9, Writeback-2 bus-ID: 07:00.0 chip-ID: 1002:1681 class-ID: 0300
    temp: 55.0 C
  Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2 chip-ID: 13d3:56eb
  Device-4: Jieli USB PHY 2.0 driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-1.2:3
    chip-ID: 1224:2a25 class-ID: 0102
  Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu,amdgpu d-rect: 4389x2583 display-ID: 0
  Monitor-1: HDMI-A-1 pos: primary,top-left res: 2560x1440 size: N/A
    modes: N/A
  Monitor-2: eDP-2 pos: bottom-r res: 1829x1143 size: N/A modes: N/A
    device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
    surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon 680M (radeonsi rembrandt
    LLVM 18.1.8 DRM 3.59 6.12.4-1-MANJARO) device-ID: 1002:1681 memory: 500 MiB
    unified: no display-ID: :1.0
  API: Vulkan v: 1.4.303 layers: 4 device: 0 type: discrete-gpu name: AMD
    Radeon RX 6800S (RADV NAVI23) driver: N/A device-ID: 1002:73ef
    surfaces: xcb,xlib,wayland device: 1 type: integrated-gpu name: AMD Radeon
    680M (RADV REMBRANDT) driver: N/A device-ID: 1002:1681
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High
    Definition Audio driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 07:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-3: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
    vendor: ASUSTeK driver: snd_pci_acp6x v: kernel alternate: snd_pci_acp3x,
    snd_rn_pci_acp3x, snd_pci_acp5x, snd_acp_pci, snd_rpl_pci_acp6x,
    snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
    snd_sof_amd_vangogh, snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 07:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-4: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
    lanes: 16 bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-5: Jieli USB PHY 2.0 driver: snd-usb-audio,uvcvideo type: USB
  API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    vendor: Foxconn driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    bus-ID: 05:00.0 chip-ID: 14c3:0616 class-ID: 0280
  IF: wlp5s0 state: up mac: <filter>
  IF-ID-1: br-d04dbdfe9e81 state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IP v6: <filter> virtual: proto kernel_ll scope: link
  IF-ID-2: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
  IF-ID-3: veth7dc02d2 state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-4: veth84abd96 state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-5: veth9d9e2c3 state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-6: vethffb2b7e state: up speed: 10000 Mbps duplex: full mac: <filter>
  Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 0489:e0e2
  Local Storage: total: 953.87 GiB used: 503.07 GiB (52.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2450 MTFDKBA1T0TFK
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: V5MA010 temp: 43.9 C
    scheme: GPT
  ID-1: / raw-size: 820.8 GiB size: 806.84 GiB (98.30%)
    used: 503.01 GiB (62.3%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
    label: N/A uuid: bb33fe7a-f0ad-4c1f-a738-7e8ee3d7ae11
    used: 58.7 MiB (61.2%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 7CE2-94B4
  ID-1: swap-1 type: file size: 64 GiB used: 27.8 MiB (0.0%) priority: -2
    file: /swapfile
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 132.46 GiB fs: ntfs label: N/A
    uuid: 5A0C19BA0C1991DD
  Device-1: 1-3:2 info: ASUSTek N-KEY Device type: keyboard
    driver: asus,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 0b05:19b6 class-ID: 0301
  Device-2: 1-4:3 info: ASUSTek ITE Device(8910) type: keyboard driver: usbfs
    interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 100mA chip-ID: 0b05:193b class-ID: 0301
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 3 rev: 2.0
  Device-1: 3-3:2 info: IMC Networks USB2.0 HD UVC WebCam type: video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 13d3:56eb class-ID: fe01 serial: <filter>
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 5-1:2 info: Foxconn / Hon Hai Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 0489:e0e2 class-ID: e001 serial: <filter>
  Hub-6: 6-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
  Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-8: 7-1:2 info: Huasheng USB2.0 HUB ports: 4 rev: 2.0
    chip-ID: 214b:7250 class-ID: 0900
  Device-1: 7-1.2:3 info: Jieli USB PHY 2.0 type: video,audio
  Device-2: 7-1.3:4 info: ShenZhen ShanWan ZD-V+ Wired Gaming Controller
    type: HID driver: hid-generic,usbhid interfaces: 1 rev: 1.1
    chip-ID: 2563:0575 class-ID: 0300
  Hub-9: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-10: 9-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-11: 10-0:1 info: super-speed hub ports: 1 rev: 3.1
  System Temperatures: cpu: 56.8 C mobo: 54.0 C
  Fan Speeds (rpm): cpu: 2000
  GPU: device: amdgpu temp: 56.0 C device: amdgpu temp: 55.0 C mem: 56.0 C
    fan: 0 watts: 5.00
  Processes: 461 Power: uptime: 3h 29m states: freeze,mem,disk suspend: s2idle
    image: 12.21 GiB services: org_kde_powerdevil, power-profiles-daemon,
    upowerd Init: systemd v: 256 default: graphical tool: systemctl
  Packages: 1574 pm: pacman pkgs: 1561 libs: 407 tools: pamac pm: flatpak
    pkgs: 0 pm: snap pkgs: 13 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh
    v: 5.9 default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.36
I just signed up to reply to this, but yes I have the exact same issue. I have exactly the same laptop as you, 2022 G14, with the same GPU and GPU, but I’m running Fedora.
My fix is to add KWIN_DRM_DEVICES="/dev/dri/card1:/dev/dri/card2" to /etc/environment, which solves the issue but results in terrible battery life in hybrid mode. Outside of that I have no other fix, other than to connect the external display to the iGPU through the left side USB-C port and not via HDMI or the right side USB-C port (as the right one is connected directly to the dGPU).
I did see somewhere that downgrading kwin might solve it, but I want to avoid that if I can.
I’ve tried connecting through UBC-C and only left one works correctly (game is rendered). I think I’ll wait for the new kwin version and use USB-C in the meantime. Thanks!
