Games crash on Steam after 1-5 minutes
This begun happening about two months ago. It doesn’t matter if it is Steam native, runtime or flatpack. Different games crash within a few minutes, sometimes won’t even launch. I tried going back to the LTS kernel, with no results.
Any help is welcome!
steam.sh[5513]: Running Steam on manjarolinux 25.0.6 64-bit
steam.sh[5513]: STEAM_RUNTIME is enabled automatically
setup.sh[5565]: Steam runtime environment up-to-date!
steam.sh[5513]: Log already open
steam.sh[5513]: Steam client's requirements are satisfied
CProcessEnvironmentManager is ready, 6 preallocated environment variables.
[2025-07-20 19:09:11] Startup - updater built Jun 28 2025 01:05:05
[2025-07-20 19:09:11] Startup - Steam Client launched with: '/home/juancho/.local/share/Steam/ubuntu12_32/steam' '-srt-logger-opened'
[2025-07-20 19:09:11] Process started with command-line: '/home/juancho/.local/share/Steam/ubuntu12_32/steam' '-child-update-ui' '-child-update-ui-socket' '8' '-srt-logger-opened'
07/20 19:09:11 minidumps folder is set to /tmp/dumps
[2025-07-20 19:09:11] Using update UI: xwin
07/20 19:09:11 Init: Installing breakpad exception handler for appid(steam)/version(0)/tid(5632)
[2025-07-20 19:09:11] Create window
[2025-07-20 19:09:11] Loading cached metrics from disk (/home/juancho/.local/share/Steam/package/steam_client_metrics.bin)
[2025-07-20 19:09:11] Using the following download hosts for Public, Realm steamglobal
[2025-07-20 19:09:11] 1. https://client-update.fastly.steamstatic.com, /, Realm 'steamglobal', weight was 900, source = 'update_hosts_cached.vdf'
[2025-07-20 19:09:11] 2. https://client-update.akamai.steamstatic.com, /, Realm 'steamglobal', weight was 400, source = 'update_hosts_cached.vdf'
[2025-07-20 19:09:11] 3. https://client-update.steamstatic.com, /, Realm 'steamglobal', weight was 1, source = 'baked in'
[2025-07-20 19:09:11] Verifying installation...
[2025-07-20 19:09:11] Verifying file sizes only
[2025-07-20 19:09:11] Verification complete
UpdateUI: skip show logo
[2025-07-20 19:09:11] Set percent complete: 0
[2025-07-20 19:09:11] Set percent complete: -1
[2025-07-20 19:09:11] Set status message: Verifying installation...
Steam logging initialized: directory: /home/juancho/.local/share/Steam/logs
[2025-07-20 19:09:11] ProcessNextMessage: socket disconnected
[2025-07-20 19:09:11] No more messages are expected - exiting
/usr/share/themes/Adwaita-dark/gtk-2.0/main.rc:733: error: unexpected identifier 'direction', expected character '}'
/usr/share/themes/Adwaita-dark/gtk-2.0/hacks.rc:28: error: invalid string constant "normal_entry", expected valid string constant
XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xf730adc0
XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xf7309500
07/20 19:09:14 minidumps folder is set to /tmp/dumps
07/20 19:09:14 Init: Installing breakpad exception handler for appid(steamsysinfo)/version(1751405894)/tid(5646)
Running query: 1 - GpuTopology
Response: gpu_topology {
  gpus {
    name: "NVIDIA GeForce RTX 3050 6GB Laptop GPU"
    vram_size_bytes: 6442450944
    driver_id: k_EGpuDriverId_NvidiaProprietary
    driver_version_major: 575
    driver_version_minor: 64
    driver_version_patch: 3
  gpus {
    name: "Intel(R) Graphics (RPL-P)"
    vram_size_bytes: 25004909568
    driver_id: k_EGpuDriverId_MesaIntel
    driver_version_major: 25
    driver_version_minor: 1
    driver_version_patch: 6
  default_gpu_id: 1
Exit code: 0
Saving response to: /tmp/steamPepnPP - 108 bytes
steamwebhelper.sh[5654]: Starting steamwebhelper under bootstrap steamrt steam runtime via: /home/juancho/.local/share/Steam/steamrt64/steam-runtime-steamrt/_v2-entry-point
steamwebhelper.sh[5654]: Starting steamwebhelper with steamrt steam runtime at /home/juancho/.local/share/Steam/steamrt64/steam-runtime-steamrt/_v2-entry-point
Steam Runtime Launch Service: starting steam-runtime-launcher-service
Steam Runtime Launch Service: steam-runtime-launcher-service is running pid 5760
bus_name=com.steampowered.PressureVessel.LaunchAlongsideSteam
exec ./steamwebhelper -nocrashdialog -lang=en_US -cachedir=/home/juancho/.local/share/Steam/config/htmlcache -steampid=5631 -buildid=1751405894 -steamid=0 -logdir=/home/juancho/.local/share/Steam/logs -uimode=7 -startcount=0 -steamuniverse=Public -realm=Global -clientui=/home/juancho/.local/share/Steam/clientui -steampath=/home/juancho/.local/share/Steam/ubuntu12_32/steam -launcher=0 -use_xcomposite_workaround --valve-initial-threadpool-size=4 --valve-enable-site-isolation --enable-smooth-scrolling --disable-gpu-compositing --disable-gpu --password-store=basic --log-file=/home/juancho/.local/share/Steam/logs/cef_log.txt --disable-quick-menu --disable-component-update --disable-features=SpareRendererForSitePerProcess,DcheckIsFatal,BlockPromptsIfIgnoredOften,ValveFFmpegAllowLowDelayHEVC
Desktop state changed: desktop: { pos:    0,   0 size: 1920,1080 } primary: { pos:    0,   0 size: 1920,1080 }
Caching cursor image for , size 32x32, serial 593, cache size = 0
reaping pid: 5632 -- steam
wine: using kernel write watches, use_kernel_writewatch 1.
fsync: up and running.
chdir "/home/juancho/.local/share/Steam/steamapps/common/Age of Wonders 4"
ERROR: ld.so: object '/home/juancho/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
ERROR: ld.so: object '/home/juancho/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
Game Recording - would start recording game 1669000, but recording for this game is disabled
Adding process 6299 for gameID 1669000
Adding process 6300 for gameID 1669000
Adding process 6301 for gameID 1669000
Adding process 6408 for gameID 1669000
Adding process 6409 for gameID 1669000
Adding process 6410 for gameID 1669000
Adding process 6411 for gameID 1669000
Adding process 6414 for gameID 1669000
Adding process 6416 for gameID 1669000
Adding process 6419 for gameID 1669000
Adding process 6429 for gameID 1669000
Adding process 6443 for gameID 1669000
Adding process 6449 for gameID 1669000
Adding process 6468 for gameID 1669000
Setting breakpad minidump AppID = 1669000
Steam_SetMinidumpSteamID:  Caching Steam ID:  76561198090519695 [API loaded no]
Adding process 6485 for gameID 1669000
Adding process 6502 for gameID 1669000
Adding process 6513 for gameID 1669000
Adding process 6517 for gameID 1669000
Adding process 6519 for gameID 1669000
Adding process 6540 for gameID 1669000
Adding process 6577 for gameID 1669000
Adding process 6580 for gameID 1669000
Adding process 6588 for gameID 1669000
Adding process 6637 for gameID 1669000
Fossilize INFO: Overriding serialization path: "/home/juancho/.local/share/Steam/steamapps/shadercache/1669000/fozpipelinesv6/steamapprun_pipeline_cache".
07/20 19:10:50 minidumps folder is set to /tmp/dumps
07/20 19:10:50 Init: Installing breakpad exception handler for appid(gameoverlayui)/version(20250628010609)/tid(6748)
07/20 19:10:50 Init: Installing breakpad exception handler for appid(gameoverlayui)/version(1.0)/tid(6748)
[2025-07-20 19:11:14] Background update loop checking for update. . .
[2025-07-20 19:11:14] Checking for available updates...
[2025-07-20 19:11:14] Downloading manifest: https://client-update.fastly.steamstatic.com/steam_client_ubuntu12
[2025-07-20 19:11:15] Manifest download: send request
[2025-07-20 19:11:15] Manifest download: waiting for download to finish
[2025-07-20 19:11:16] Manifest download: finished
[2025-07-20 19:11:16] Download skipped: /steam_client_ubuntu12 version 1751405894, installed version 1751405894, existing pending version 0
[2025-07-20 19:11:16] Nothing to do
pid 6412 != 6411, skipping destruction (fork without exec?)
Game Recording - game stopped [gameid=1669000]
Removing process 6637 for gameID 1669000
Removing process 6588 for gameID 1669000
Removing process 6580 for gameID 1669000
Removing process 6577 for gameID 1669000
Removing process 6540 for gameID 1669000
Removing process 6519 for gameID 1669000
Removing process 6517 for gameID 1669000
Removing process 6513 for gameID 1669000
Removing process 6502 for gameID 1669000
Removing process 6485 for gameID 1669000
Removing process 6468 for gameID 1669000
Removing process 6449 for gameID 1669000
Removing process 6443 for gameID 1669000
Removing process 6429 for gameID 1669000
Removing process 6419 for gameID 1669000
Removing process 6416 for gameID 1669000
Removing process 6414 for gameID 1669000
Removing process 6411 for gameID 1669000
Removing process 6410 for gameID 1669000
Removing process 6409 for gameID 1669000
Removing process 6408 for gameID 1669000
Removing process 6301 for gameID 1669000
Removing process 6300 for gameID 1669000
Removing process 6299 for gameID 1669000
(process:6748): GLib-GObject-CRITICAL **: 19:14:44.638: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
reaping pid: 6748 -- gameoverlayui
 ██████████████████  ████████     juancho@Kalgan
 ██████████████████  ████████     OS: Manjaro 25.0.6 Zetar
 ██████████████████  ████████     Kernel: x86_64 Linux 6.15.7-1-MANJARO
 ██████████████████  ████████     Uptime: 1d 1h 20m
 ████████            ████████     Packages: 1592
 ████████  ████████  ████████     Shell: bash
 ████████  ████████  ████████     Resolution: No X Server
 ████████  ████████  ████████     DE: Xfce4
 ████████  ████████  ████████     WM: Xfwm4
 ████████  ████████  ████████     WM Theme: Matcha-sea
 ████████  ████████  ████████     GTK Theme: Adwaita-dark [GTK2]
 ████████  ████████  ████████     Icon Theme: Papirus-Maia
 ████████  ████████  ████████     Font: Noto Sans 10
 ████████  ████████  ████████     Disk: 782G / 1,1T (78%)
                                  CPU: 13th Gen Intel Core i5-13420H @ 12x 4.6GHz [47.0°C]
                                  GPU: NVIDIA GeForce RTX 3050 6GB Laptop GPU
                                  RAM: 6926MiB / 31795MiB
This looks like it could be contributing.
Beyond that, I can only encourage you to provide further detail. Please provide system information as described (below).
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Highly Recommended
Required Reading
Technical Resources
This sounds to me like Nvidia 575xx
test out 550xx Version from the AUR:
nvidia-550xx-dkms 550.163.01-2
nvidia-550xx-utils 550.163.01-2
And get rid of anything of version 575.64.0…
 sudo pacman -Q | grep 575.64.0
But keep:
nvidia-settings 575.64.03-1
opencl-nvidia 575.64.03-1
Maybe try disabling the Steam Overlay under Steam Settings > In Game.
I’m not sure if that’s actually related to the error since the gameoverlayui flag is default, however at least that will rule it out if not.
Highly doubtful. Remember, Gtk 2 is dead. However, for some reason, xfce4-settings depends on gnome-themes-extra and Steam might be looking for a system Gtk 2 theme. :man_shrugging:
How? What do you mean?
Why?
Remember, the AUR is neither officially supported by Arch nor Manjaro.
Also, you’re contradicting yourself. One cannot both “get rid of” and “keep” something at the same time. All driver packages must have matching versions.
Here is the inxi output:
  Kernel: 6.15.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.15-x86_64
    root=UUID=bb0ec3d4-d1f9-419b-8a27-5efd419e287b rw quiet splash apparmor=1
  Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 v: 4.20.0
    with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: Acer product: Nitro ANV15-51 v: V1.10
  Mobo: RPL model: Sportage_RTH v: V1.10 serial: <superuser required>
    part-nu: 0000000000000000 uuid: <superuser required> UEFI: INSYDE v: 1.10
    date: 02/19/2024
  ID-1: BAT1 charge: 54.9 Wh (100.0%) condition: 54.9/57.5 Wh (95.5%)
    volts: 17.2 min: 15.4 model: LGC AP21D8M type: Li-ion serial: <filter>
    status: full cycles: 51
  System RAM: total: 32 GiB available: 31.05 GiB used: 6.01 GiB (19.4%)
  Device-1: Controller0-ChannelA-DIMM0 type: DDR5 detail: synchronous
    size: 16 GiB speed: 5200 MT/s volts: curr: 1 width (bits): data: 64
    total: 64 manufacturer: N/A part-no: NET516G5200SO52 serial: <filter>
  Device-2: Controller1-ChannelA-DIMM0 type: DDR5 detail: synchronous
  Info: model: 13th Gen Intel Core i5-13420H bits: 64 type: MST AMCP
    arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
    process: Intel 7 (10nm) family: 6 model-id: 0xBA (186) stepping: 2
    microcode: 0x4128
  Topology: cpus: 1x dies: 1 clusters: 5 cores: 8 threads: 12 mt: 4 tpc: 2
    st: 4 smt: enabled cache: L1: 704 KiB desc: d-4x32 KiB, 4x48 KiB; i-4x32
    KiB, 4x64 KiB L2: 7 MiB desc: 4x1.2 MiB, 1x2 MiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 400 min/max: 400/4600:3400 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
    8: 400 9: 400 10: 400 11: 400 12: 400 bogomips: 62668
    de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
    msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
    rdtscp rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect
    ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    xtopology xtpr
    conditional; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Intel Raptor Lake-P [UHD Graphics] vendor: Acer Incorporated ALI
    driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
    built: 2020-21 ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1
    bus-ID: 0000:00:02.0 chip-ID: 8086:a7a8 class-ID: 0300
  Device-2: NVIDIA GA107BM / GN20-P0-R-K2 [GeForce RTX 3050 6GB Laptop GPU]
    vendor: Acer Incorporated ALI driver: nvidia v: 575.64.03
    alternate: nouveau,nova_core,nvidia_drm non-free: 550-570.xx+
    status: current (as of 2025-04; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 ports: active: none
    empty: HDMI-A-2 bus-ID: 0000:01:00.0 chip-ID: 10de:25ac class-ID: 0300
  Device-3: Quanta ACER HD User Facing driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:3 chip-ID: 0408:403a
  Display: x11 server: X.org v: 1.21.1.18 compositor: xfwm4 v: 4.20.0
    driver: X: loaded: modesetting,nvidia unloaded: nouveau
    alternate: fbdev,nv,vesa dri: iris gpu: i915 display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: eDP-1 model: LG Display 0x0742 built: 2021 res: mode: 1920x1080
    hz: 144 scale: 100% (1) dpi: 142 gamma: 1.2 chroma: red: x: 0.596 y: 0.369
    green: x: 0.357 y: 0.561 blue: x: 0.153 y: 0.106 white: x: 0.314 y: 0.329
    size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
    modes: 1920x1080
  EDID-Warnings: 1: parse_edid: unknown tag 112
    drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.1.6-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-P)
    device-ID: 8086:a7a8 memory: 30.32 GiB unified: yes
    gpu: nvidia-settings,nvidia-smi x11: xprop,xrandr
  Device-1: Intel Raptor Lake-P/U/H cAVS vendor: Acer Incorporated ALI
    driver: sof-audio-pci-intel-tgl alternate: snd_hda_intel, snd_soc_avs,
    snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:51ca
    class-ID: 0401
  Device-2: NVIDIA GA107 High Definition Audio vendor: Acer Incorporated ALI
    driver: snd_hda_intel v: kernel alternate: nova_core bus-ID: 0000:01:00.1
    chip-ID: 10de:2291 class-ID: 0403
  API: ALSA v: k6.15.7-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.6 status: active with: 1: pipewire-pulse
  Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
    vendor: Lite-On driver: mt7921e v: kernel bus-ID: 0000:3e:00.0
    chip-ID: 14c3:7961 class-ID: 0280
  IF: wlp62s0 state: up mac: <filter>
    vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
    bus-ID: 0000:3f:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp63s0 state: down mac: <filter>
  Device-1: Lite-On Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-10:4 chip-ID: 04ca:3802
  Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
    driver: vmd v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:a77f rev:
    class-ID: 0104
  Local Storage: total: 1.38 TiB used: 779.95 GiB (55.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S1000G
    lanes: 4 tech: SSD serial: <filter> fw-rev: SBM02103 temp: 42.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Silicon Motion
    model: SM2P41C8-512GC1 size: 476.94 GiB block-size: physical: 512 B
    fw-rev: V1223C0 temp: 40.9 C scheme: GPT
  ID-1: / raw-size: 150.21 GiB size: 146.8 GiB (97.73%)
    used: 69.23 GiB (47.2%) fs: ext4 dev: /dev/nvme1n1p4 maj-min: 259:6
    label: N/A uuid: bb0ec3d4-d1f9-419b-8a27-5efd419e287b
    used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3 label: N/A
    uuid: C5CA-6CA6
  ID-3: /home raw-size: 931.51 GiB size: 915.81 GiB (98.31%)
    used: 710.49 GiB (77.6%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:2
    label: N/A uuid: 58050af3-24a7-44e6-a8a3-08b1614d62b9
  ID-1: swap-1 type: partition size: 32.7 GiB used: 226.4 MiB (0.7%)
    priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:5 label: N/A
    uuid: 811cb515-6c83-400f-ab96-c6c5fe7307d8
  ID-1: /dev/nvme1n1p2 maj-min: 259:4 size: 293.73 GiB fs: ext4 label: N/A
    uuid: bc192992-2fa9-4083-bd0f-f3efa5ce27be
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-2: 2-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-3:2 info: Maxxter Wireless Receiver type: mouse,keyboard
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 50mA chip-ID: 248a:8514 class-ID: 0301
  Device-2: 3-6:3 info: Quanta ACER HD User Facing type: video
    driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 0408:403a class-ID: fe01
    serial: <filter>
  Device-3: 3-10:4 info: Lite-On Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 04ca:3802 class-ID: e001 serial: <filter>
  System Temperatures: cpu: 42.5 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 1643 pm: pacman pkgs: 1581 libs: 509 tools: pamac pm: flatpak
    pkgs: 50 pm: snap pkgs: 12
    1: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    2: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://mirror.init7.net/manjaro/stable/$repo/$arch
    5: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    6: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    7: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    8: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 307
  1: cpu: 6.3% command: chromium pid: 3454 mem: 280.0 MiB (0.8%)
  2: cpu: 3.9% command: chromium pid: 45957 mem: 568.3 MiB (1.7%)
  3: cpu: 3.6% command: Xorg pid: 1208 mem: 173.1 MiB (0.5%)
  4: cpu: 1.3% command: chromium pid: 3416 mem: 515.9 MiB (1.6%)
  5: cpu: 0.8% command: xfwm4 pid: 1407 mem: 66.5 MiB (0.2%)
  Memory top: 5 of 307
  1: mem: 568.3 MiB (1.7%) command: chromium pid: 45957 cpu: 3.9%
  2: mem: 515.9 MiB (1.6%) command: chromium pid: 3416 cpu: 1.3%
  3: mem: 505.2 MiB (1.5%) command: chromium pid: 32396 cpu: 0.6%
  4: mem: 386.6 MiB (1.2%) command: chromium pid: 10755 cpu: 0.2%
  5: mem: 299.0 MiB (0.9%) command: chromium pid: 54388 cpu: 0.2%
  Processes: 307 Power: uptime: 1d 13h 53m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 0 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 12.39 GiB
    services: upowerd,xfce4-power-manager Init: systemd v: 257
  Compilers: clang: 20.1.8 gcc: 15.1.1 alt: 13 Shell: Bash v: 5.3.0
    running-in: xfce4-terminal inxi: 3.3.38
I have tried this a few times, the games still crash.
Thank you! I will try this if nothing else helps.
because 550xx only works for me since:
It was just my suggestion for now.
It’s nice that you use the “reply” functionality, but please, reply to the person you wished to reply to (there is a Reply button beneath each post)…
Please use the correct button for the person you intend replying to (@Yochanan) rather than clicking the first Reply that you happen to see.
The replay was to your inxi outpout request that you post, but while I have Post my Post @juancho has already posted he’s System info.
So that part I have deleted.
From the output - I’d say this could become critical.
Your graphics appear to run with the - by Nvidia - recommend driver
Check for dust in the vents - overheating will cause instability - though it does not look like
I’m not sure I understood most of that, but I’ll give you the benefit of the doubt. :wink:
Well, thank you for your kindness.
You mean, running out of space? Yesterday I did a Steam Flatpak installation in addition to the native package. Once I get a solution I will delete the redundant packages.
The laptop is only six months old and I monitor the temperature.
There is a big Intel problem with dieing or unstable 13th/14th Intel Gen. CPU’s, idk if Laptop CPU’s are effect the same as normal PC CPU’s from Intel.
For that reason, Intel rolled out massive Bios updates that reduced the voltage… to stop or delay the silicon rot.
Im not saying that this is the case here… but it could be related.
After the big medial ■■■■ storm, Intel extended Warrantys for the effected 13th/14th gen to 5 year’s.
But, did you…
1. Which specific games are crashing, and are they all Windows based (do they require WINE)?
2. Are you multi-booting and sharing an NTFS partition between Manjaro and Windows to run those games from?
Not yet.
Only have 3 games installed now: Age of Wonders 4, Galactic Civilizations 3, and No Man’s Sky. They all crash. They all require Wine/Proton.
No. It’s only Manjaro.
In the Stable Update (2025-06-23) announcement, the following item was posted under Known Issues and Solutions:
As your games are using WINE, then any 32-bit prefixes need to be recreated, in any case; I suspect this could be contributing to the crashing, especially considering only these games are affected.
Thank you. The post does not tell how to recreate these prefixes. I appreciate any light on this.
For that illumination you might need to ask Steam (for example). Different versions of WINE may be used, depending on whether it’s Proton, or one of the other variants.
Some random links that might be useful;
Most will likely presume some understanding of WINE, but again, it depends on which WINE the game is running on. You would need to put your researching cap on.
For recreating WINE prefixes on Manjaro, it means deleting any existing 32-bit prefixes, and creating new ones. Familiarity with WINE is an advantage, and there are tools to help, albeit mostly command-line.
Your games are likely not using the system WINE.
Any other 32-bit (Windows) applications that you have previously configured, likely are. Naturally, if you have never configured any 32-bit Windows software to run in WINE on Manjaro, then there won’t be any 32-bit wineprefixes to recreate.
I had it cleaned. The games still crash.
That is the case. I never configured wineprefixes.
I have tried different versions of Proton and disabling Steam overlay. Nothing works…
Have you tried Lutris?
I have never used Lutris and know virtually nothing about it; I notice it mentioned occasionally on the forum as being easy to setup and use. Maybe it’s worth investigating as an alternative to your current environment.
